#1 | ||||
![]() Join Date: Mar 2006
1991 SL
so i was planing on replacing my trans soon with a manual but its gonna be sooner than i thought since it blew today lol
i was coming back from the jy (with my new 98 vavle cover [kick ass!!!]) and we started to hear this sound like squarls in my engine bay lol so we figuered a belt was going bad or soemthing. then when we came to stop we saw a ton of smoke so i got over as soon as i could and then we saw the trail of transfluid i was leaving everwhere lol. so ive looked and cant figure out where its coming from but its pretty much gushing and it needs to come out neways. so neways im going to do that swap very soon, like start tomarow or the next day so i will keep u posted but i just wanna make sure im getting everything? 1 the transmition itself 2 brand new clutch kit 3 all of the clutch pedel 4 all of the shifer assembly 5 brake pedel 6 shift cables and stuff is there anyting other than that? do i need like different mounts or does it use the same? omg! i dont know what im getting myself into do i!!!! lol ... mods i still need to do: struts that can handle H&R race springs rear sway bar stiffer fstb (maybe)
#2 | ||||
![]() ![]() Join Date: Jan 2006
2002 SC1
You need a PCM from a '95 Sx2 with a manual trans. You're PCM is going to throw a fit when it thinks the car doesn't have a transmission.
... Aut viam inveniam aut faciam ... If your ECTS is not brass...your ass is grass. ... If you have a problem, if no one else can help, and if you can find him, maybe you can hire Uzzy.
#3 | ||||
1991 SL
i can use the one i have cant i? my pcm already has the check engine light on cuz the way cooling fan is set up so i dont care about that cuz i cheack my codes about once a week, i know alot of people use the auto ones cuz they dont have rev limiter so im not worried about that unless it will not work but it should shouldnt it?
#4 | ||||
1991 SL
ok i just got off the phone with all the jys and it looks like its gonna be about 350 for everything i need, thats the cheapest i can find around me, i know some of u guys say u can get it cheaper where u are but i cant really drive up to ohio to get it lol. and its less than 6th planet told me, about 550.
they want my old auto for that price and im like ok if u say so lol. i just need to get a clutch and a cherry picker to do it all now again wow what am i getting myself into lol ... mods i still need to do: struts that can handle H&R race springs rear sway bar stiffer fstb (maybe)
#5 | ||||
dont forget hydrolics
#6 | ||||
Click here for a great guide for this job.
... There is nothing more frightening than ignorance in action.
#7 | |||||
2002 SC1
#8 | ||||||
Try: Hydraulics. More to the point, the hydraulics might be fine. Just make sure you DON'T "activate" them during the surgery. Put a block under the pedal, or tie it up in the top position, for the duration. If you don't, you probably WILL need new hydraulics.
#9 | ||||
Hmmm....I dont think he has any hydraulics to start with....
Matt
#10 | ||||
![]() Join Date: Jun 2002
Sounds like your differential pin went out of the housing.
Make sure you get your new tranny's differential pin WELDED. ... 85 GLH 89 Daytona Shelby 93 SL2 94 855
#11 | |||||
#12 | |||||
#13 | ||||
1991 SL
"Install Saturn engine support bar #SA9105E or use a 2" x 4" piece of lumber and a bike chain. See picture for reference."
ok i know what that tool looks like but how the hell would a bike chain and a 2x4 replace that? lol theres no pic for reference and this is kinda important since i dont have that tool and im most likely not gonna get it cuz it probably cost a couple hundred lol ... mods i still need to do: struts that can handle H&R race springs rear sway bar stiffer fstb (maybe)
#14 | ||||
Ok im not exactly sure but i believe it means use a metal bar from the height of the engine bay to support the engine and a chain to go around the metal bar and hooks onto the engine support? Pretty much its use is to support the engine when the transmission is out of there.
Matt
#15 | ||||
1991 SL
i think i know what ur saying, so pretty much like using a chery picker to just hold it but without the chery picker lol
god this whole thing is already starting to suck, but it must be done lol ... mods i still need to do: struts that can handle H&R race springs rear sway bar stiffer fstb (maybe)
#16 | ||||
Ya exactly!!! Anything will work thats strong enough definetly dont go buy anything!!!!!
Matt
#17 | ||||
Do it like this... If you don't have a nylon hold down strap, like for a pick up truck, try the dollar stores, I got one with a sweet ratchet for not much money... Though I left a junkyard with a transmission, a 2x4 like that, and the motor held up with a wagon's cargo net doubled over... no shame. ![]()
#18 | ||||
1991 SL
ok so heres an update on my progess...
i only half know what im doing and i have a couple friends that dont at all know what they are doing lol so u guys need to help me out on this! neways today at 9 me and my friend mat decided that we should start on some stuff today so its less we have to do tomarow... this was just so u can see how much tranny fluid it was leaking, this is after the car was off for about 6 hours, like i said before the entire exhoust was cover to about a foot past the cat ![]() my friend mat showing up to help, he hates rice but he has a riced out civic lol ![]() this is just before we started, the back is on ramps and the front is just on the ground ![]() mat showing we got the hood off ![]() got one fender off ![]() front bumper, 2 fenders and the splash guards off, man my hair was fro-ing lol ![]() ![]() strut bar, air box, and battery tray removed ![]() ![]() ![]() alot of grime on the engine ![]() parts we took off ![]() ![]() end of the night, other things we did was drain the oil, coolent, and trans fluid(not much lol) and u can see the front end is now jacked up ![]() ![]() i still havnt decided if im goign to pull it out the top like in hayes or out the bottom like on different racing so if u have done the swap please let me know how u did and how it went thanks alot guys ... mods i still need to do: struts that can handle H&R race springs rear sway bar stiffer fstb (maybe)
#19 | ||||
I would just do it from the top. Remove the engine and tranny together, and put the tranny on the engine from the outside. Its so much easier, and you dont have to install that support bar across the top. And, you dont have to worry about an alignment that much either. You can also clean EVERYTHING in the engine bay and clean the block when its out.
i envy you SO much for this swap. i wanna do the swap too ya know! ... 2004 Jeep Wrangler Rubicon -> daily & toy =) 2009 BMW 128i -> sold 2003 VW GTI 1.8T -> wrecked 1998 Saturn SL2 -> parted out 1995 Saturn SL2 -> sold 1995 Saturn SL2 -> sold
#20 | ||||
1991 SL
yeah i really wanna clean everything alot, it looks like my car was used for endurence rally racing lol
i want to do it from the bottom cuz thats how different racing says and its shows everything to do the swap but im looking at it and im like damn that is alot of work lol it seams alot easier just to pull it out the top, i dunno i keep chaning my mind how im goign to do it every 3 minutes lol this is gonna be so hard lol but i cant turn back now i already ordered the clutch ... mods i still need to do: struts that can handle H&R race springs rear sway bar stiffer fstb (maybe)
| Thread Tools | |
| Display Modes | |
| Should have done this sooner! | whiskywizard | Introductions & Greetings | 4 | 12-05-2009 10:18 AM |
| Just A Thought.. | boatmoter | S-Series Tech | 1 | 05-04-2008 11:19 AM |
| Just a thought? | Tek | Vue Mods | 25 | 02-28-2007 10:18 AM |
| Saturn may kill the L series sooner | haypops | General Saturn Discussion | 25 | 03-02-2004 09:37 AM |
