Old 07-20-2006, 07:56 AM   #1
lonelywolf8588
lonelywolf8588 is on a distinguished road
Default Transaxle Range Switch\Neutral Start Safety Switch
I just put in a new transaxle safety switch/neutral start safety switch in my 02 SC2. Now it starts and idles fine but when I put it in drive it doesn't want to upshift from first gear. It drives fine in second and third when I put it in second or third manually. There are no check engine codes or anything going wrong. Anyone have any ideas as to what is wrong?
Add to lonelywolf8588's Reputation
Rate the quality of this post and help lonelywolf8588 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lonelywolf8588 is offline   Reply With Quote
Old 07-20-2006, 08:34 AM   #2
wolfman
wolfman's Avatar
Default Re: Transaxle Range Switch\Neutral Start Safety Switch
Was it working (shifting) ok before you replaced the switch, or did you replace the switch to try and cure a problem? (Need more information)
Add to wolfman's Reputation
Old 07-20-2006, 08:55 AM   #3
lonelywolf8588
It ran perfectly fine until that switch went out so I replaced it and now it will work sometimes perfect and other times it won't shift out of first gear while in drive. I am going to try to realign it because that is where the tranny guy said to start and then I think I'll take it in to him.
Neutral safety switch help Highmile S-Series Tech 2 12-15-2009 02:15 PM
Neutral Safety Switch????? Clickety_Clack S-Series General 10 12-03-2008 10:24 PM
Neutral Safety Switch Adjustment (Please Help) hipstershaun S-Series Tech 4 01-20-2007 07:57 PM
neutral safety switch staroffear S-Series General 1 04-16-2005 11:14 AM
Neutral Safety Switch Marlin Liew S-Series Tech 7 11-04-2004 12:55 AM
