Old 11-13-2007, 11:39 AM   #41
revue
revue is on a distinguished road
revue's Avatar
Default Re: VUe BULB sizes and replacement Guide!!
I put a set of HIR lamps in my low beams and love them.
No extra heat or current, whiter(not that blueish crap),
75% brighter than stock, no short life, and the HIR low
beam puts out more light than a standard high beam.
http://hirheadlights.com/index.htm
Add to revue's Reputation
Rate the quality of this post and help revue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
revue is offline   Reply With Quote
Old 11-13-2007, 05:17 PM   #42
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Re: VUe BULB sizes and replacement Guide!!
Originally Posted by David 93 SL2m View Post
No, I did not have to re-aim the lights. However proper headlight aim is very important for seeing well at night, and I would recommend making sure the headlight aim is correct before using a brighter bulb to avoid annoying other drivers. That would be anti-social as well as dangerous. Car dealers and most service garages can check and possibly re-aim headlights rather quickly and for low cost. You could also do this yourself if you have patience and a nice dark level area in front of a wall or the like.
I forgot to mention that adjusting the headlights up and down is very easy. The adjusters are located at the top of each headlamp assembly between the low beam bulb and the turn signal bulb, and the adjusters are accessible when the hood is raised. They look like a small gray 6-pointed star with a silver bolt behind pointed toward the windshield. We need to use a Torx E8 socket to turn the adjusters. The "E" means external.
As of Feb 2018
∙ 2004 VUE 122K
∙ 2007 ION3 110K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline   Reply With Quote
Old 11-25-2007, 10:33 AM   #43
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
I've tryed
Silverstars= no better then stock
Silverstar Ultras= hardly better then stock
Nighthawks= no better then stock
CUZO Hyper white= worthless
NOKYA Arctic white= worthless
and ended up with MATRIX Ultra whites from Summit racing at the cost of $15.95 a pair. I have the 80w low beams 100w high beam. I adjusted my lamps a touch lower and the lighting is outstanding. I had MATRIX in my 2001 SL2 and when I sold it I put those bulbs in my wifes 2006 VUE. When I sold the VUE we put them in my SONS 2007 Redline VUE. I have MATRIX 9007 UltraWhite in two of the four ION3's here at the house including the fog lamps
Add to SaturnSdn's Reputation
Rate the quality of this post and help SaturnSdn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnSdn is offline   Reply With Quote
Old 12-12-2007, 10:04 PM   #44
m4gician
m4gician has a spectacular aura aboutm4gician has a spectacular aura about
they dont make bulbs for H7 size for my volvo
2005 Black Saturn Vue AWD V6
Aftermarket additions:
- Webasto Panorama Sunroof
Add to m4gician's Reputation
Rate the quality of this post and help m4gician reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
m4gician is offline   Reply With Quote
Old 12-13-2007, 07:17 AM   #45
revue
revue's Avatar
Wrong forum. Isn't a volvo a part of the human anatomy?
Old 01-24-2008, 04:05 PM   #46
My 1st Ute
My 1st Ute is on a distinguished road
My 1st Ute's Avatar
I installed a pair of lowbeam HIRs on my 04 Vue, and after just one year one of the bulbs blew up inside the headlight assembly and I could never get all the frangments out... I'll stick with the stock bulbs.
Add to My 1st Ute's Reputation
Rate the quality of this post and help My 1st Ute reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
My 1st Ute is offline   Reply With Quote
Old 03-01-2008, 01:15 AM   #47
jjl303
jjl303 is on a distinguished road
Just wanted to throw this out:
I use Euro Dezigns bulbs in my vue and they rock!
Check em out!
I use them in both the high and low beam with no problems whatsoever....
https://www.eurodezigns.com/index.htm
Add to jjl303's Reputation
Rate the quality of this post and help jjl303 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjl303 is offline   Reply With Quote
Old 04-15-2008, 03:37 PM   #48
john95SW2
john95SW2 will become famous soon enough
john95SW2's Avatar
2004 VUE 2.2L
Odometer Bulb - Saturn P/N 21019273
Add to john95SW2's Reputation
Rate the quality of this post and help john95SW2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
john95SW2 is offline   Reply With Quote
Old 07-22-2008, 11:44 AM   #49
LotusLord
LotusLord is on a distinguished road
1996 SL1
Sorry if this is a dumb question, but could I use the 3157 LED bulbs from SuperBrightLEDs.com in place of the 3057s the Vue uses for brake and rear lights?
Add to LotusLord's Reputation
Rate the quality of this post and help LotusLord reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LotusLord is offline   Reply With Quote
Old 11-27-2008, 12:54 AM   #50
vidonediv
vidonediv is on a distinguished road
2004 VUE 2.2L
Is the list for the 2006 the same as the 2004?
Add to vidonediv's Reputation
Rate the quality of this post and help vidonediv reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vidonediv is offline   Reply With Quote
Old 02-19-2009, 03:58 PM   #51
Bismarck318
Location: Heart of the Rustbelt, AKA The Angry White Planet Ohth
Curious to the difference between the 2825 Bulbs (or lamps as GE refers to them) & the 194/168.
I'm surprised that LED's were not used in the dash & other hard to maintain areas.
Add to Bismarck318's Reputation
Rate the quality of this post and help Bismarck318 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-20-2009, 09:52 PM   #52
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Information Re: VUe BULB sizes and replacement Guide!!
signal_bulbs@danielsternlighting.com
As of Feb 2018
∙ 2004 VUE 122K
∙ 2007 ION3 110K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Old 02-22-2009, 10:13 PM   #53
AirGumby
AirGumby is on a distinguished road
Anyone use those PIAA lights for the fog lights? There are ones called like Xtreme or something.
2004 VUE V6 AWD
Add to AirGumby's Reputation
Rate the quality of this post and help AirGumby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AirGumby is offline   Reply With Quote
Old 02-24-2009, 01:18 PM   #54
Bismarck318
Using high beam bulbs where we are supposed to use low beam bulbs is not dramatically better, but it is noticeably better. Besides the bulb fitment (meaning the grooves inside the base of the bulbs that are present to prevent us from doing this), there are two primary differences in the characteristics of the bulbs. First, low beam bulbs are usually rated at 55 watts while high beam bulbs are rated at 65 watts, about an 18% increase in wattage. Second, low beam bulbs have some sort of painted "cap" at the end of the bulb so light is emitted from just the sides of the bulb while the high beam bulbs lack this "cap" so light is emitted from all sides of the bulb. Either of these differences generally mean the high beam bulbs give off more more light.
No, the pattern on the road did not change.
I did a similar mod on the Camaro foglamps by removing the glass & then the metal reflector, but the beam pattern did change, now throws the lights farther down the road illuminating far off freeway signs, I could go back now by just replacing the bulb with the equivalant bulb with a painted cap to go back to the original beam pattern... or at least I assume.
I was thinking there was a metal reflector within the Vue's headlamp housing.
A side note I did not see on the bulb conversion charts, but I had looked up once upon a time elsewhere, a great sub for the 194/168 bulb is the 161, burns cooler & longer with little or no sacrifice in light output. These are HTF, I had to get these in bulk through my local radio supply (which went under last year)
Chrysler used to use the 161 in dash applications.
Old 05-06-2009, 09:41 AM   #55
TopSpotOpt
TopSpotOpt is on a distinguished road
TopSpotOpt's Avatar
2006 VUE 2.4L
This is awesome. Thanks alot, I had been needing these for a long time.
Add to TopSpotOpt's Reputation
Rate the quality of this post and help TopSpotOpt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TopSpotOpt is offline   Reply With Quote
Old 05-27-2009, 04:19 PM   #56
XRL
XRL's Avatar
2004 VUE Red Line
Anyone found any good replacements for the Dome and Cargo area lights? They're weird bulbs that autolumination doesnt sell.
Add to XRL's Reputation
Old 08-26-2009, 11:37 PM   #57
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
I just briefly skimmed through this thread and see that no one has listed the p/n for the gauge cluster illumination.
The p/n for these bulbs (including opera lights) is Wagner # PC118. This should be correct for all 2002-2007 Vue, 2000-2002 S-Series, and 2000-2005 L-Series.
2007 Chevy Equinox LT 180K miles
Add to ruley73's Reputation
Old 01-16-2010, 09:36 AM   #58
BoDuke70
BoDuke70 is on a distinguished road
BoDuke70's Avatar
2004 ION-3 Quad Coupe
Originally Posted by BobbyP View Post
I hardly ever had any lamps fail on my 92 SC, just alternators...
Wow, does that bring back some memories...used to stock about 40 of each type (91-94, 95-97, 98 and up, and some of the internal-fan 97s) back in hot hot hot AZ, and we'd go through them in less than a week. Sometimes my core batch was almost a whole cage of alternators alone...and next to that, a stack of prorated batteries. You could hear those bad alternators a block away, too, and if you were really good, could tell the difference from that or a bad idler pulley.
A different kind of parts guy...now in a bow tie!
Add to BoDuke70's Reputation
Rate the quality of this post and help BoDuke70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BoDuke70 is offline   Reply With Quote
Old 02-04-2010, 01:36 PM   #59
My 1st Ute
My 1st Ute's Avatar
I just tried to replace my back up lights on my 2007 Vue, and it appears that the back up lights use the same double filament bulbs as the brake lights.
So for anyone with an 07 attempting to replace a back up light beware that you will need 3057 NOT 3156 bulbs.
Old 06-05-2010, 10:08 PM   #60
SaturnIONSLVUE
SaturnIONSLVUE is on a distinguished road
Just changed my Sliverstar head light out which only lasted a year in a half with Philips CrystalVision Ultra http://www.lighting.philips.com/us_e...30&id=&lang=en
I have used Philips in the past they last forever compared to the Sliverstars and they are whiter/brigter than Sliverstars.
How do I change the fog laps in the 06 VUE?
Add to SaturnIONSLVUE's Reputation
Rate the quality of this post and help SaturnIONSLVUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnIONSLVUE is offline   Reply With Quote
Astra Bulb sizes afk123 Astra Tech 0 04-29-2009 04:31 PM
2007 Bulb guide fotovue Vue General 2 04-26-2007 05:54 PM
Instrument Cluster LED/Bulb #'s/Sizes emptypockets S-Series Tech 2 02-06-2005 11:34 PM
Light Bulb Sizes?? xtremesc2 Ion Red Line 1 11-10-2004 11:15 AM
Bulb sizes for LS1 Hank3 L-Series General 11 12-05-2003 06:21 PM
