Old 07-16-2006, 02:29 PM   #1
m4gician
m4gician has a spectacular aura aboutm4gician has a spectacular aura about
Default VUe BULB sizes and replacement Guide!!
2006 SATURN Vue
Low beam headlamp
9006
High beam headlamp
9005
Parking light
3157NALL
Front turn signal
3157NALL
Rear turn signal
3057
Tail light
3057
Stop light
3057
High mount stop light
2825
Fog/Driving light
880
if you want a BRIGHTER bulb, get a 3100K - 5000K 885 BULB, it fits and it uses a higher wattage that is safe, and works well
License plate
168
Back up light
3156
Front sidemarker
168
Map light
906
Dome light
561
Step/Courtesy light
6418
Trunk/Cargo area
562
Instrument-general
194
Automatic transmission indicator
194
A tip is try eBay or superbrightleds.com for CHEAP LED replacement lights that have a brighter light, with a lower power consumption. IMHO the 194 replacement LEDS look really nice against a Vue at night for your license plate. Complement those with replacement bulbs or even a 4300-5000K HID conversion KIT and you have an instant hit with your Vue. Also, changing the Reverse lights to BRIGHT white ones only help aesthethically. These are cheap and easy to DIY mods, and will help really bring your car outta the cheap GM plastic look. Happy modding!
If I missed something, or made a mistake please post below, I thikn some peopel say that the fogs on the 06 vues are H7s, but this what I researched and found. Happy modding!
2005 Black Saturn Vue AWD V6
Aftermarket additions:
- Webasto Panorama Sunroof
Add to m4gician's Reputation
Rate the quality of this post and help m4gician reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
m4gician is offline   Reply With Quote
Old 07-16-2006, 03:46 PM   #2
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Default Re: VUe BULB sizes and replacement Guide!!
Thanks for all numbers!
I hardly ever had any lamps fail on my 92 SC, just alternators...
Add to BobbyP's Reputation
Old 07-17-2006, 01:56 PM   #3
m4gician
BTW, using the 9005 in your 9006 is a GREAT mod if you don't want to get the HID kit.
Old 07-17-2006, 04:44 PM   #4
SylenThunder
SylenThunder is on a distinguished road
SylenThunder's Avatar
2003 VUE 2.2L
2004 VUE 2.2L
I have often considered doing just that, how hard is it to midify the bulb/opening to get it to go in?
2004 FWD, Vti, 2.2L
Custom CAI
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline   Reply With Quote
Old 07-17-2006, 06:02 PM   #5
jks06
jks06 is on a distinguished road
jks06's Avatar
I have to disagree on your listing for the fog lights on the 06 Vue. Mine has H11's in there at 55 watts, not the normal 27.5 watt version. It's not fun finding a nice bright white light, but I have found them.
06 FWD V6 silver, stock for now........Jason.
Add to jks06's Reputation
Rate the quality of this post and help jks06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jks06 is offline   Reply With Quote
Old 07-17-2006, 10:52 PM   #6
irish_loveAWD
irish_loveAWD is on a distinguished road
irish_loveAWD's Avatar
2002 VUE 3.0L
Thanks for the info...
Add to irish_loveAWD's Reputation
Rate the quality of this post and help irish_loveAWD reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
irish_loveAWD is offline   Reply With Quote
Old 07-17-2006, 11:11 PM   #7
MrSeabass
MrSeabass is on a distinguished road
2004 VUE 2.2L
Has anyone here done a LED swap for the tail lights? Legality being a non-issue for now, I just want to know if it's worth it/if they work.
Edit: Oops, already found a thread for it.
http://www.saturnfans.com/forums/sho...light=led+tail
Add to MrSeabass's Reputation
Rate the quality of this post and help MrSeabass reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MrSeabass is offline   Reply With Quote
Old 07-18-2006, 01:13 AM   #8
m4gician
Okay well here, I'll link a picture, and then all you have to do, is shave it down with a razor blade, or a thin screw driver thats sharp, or an exacto knife blade, or a retractable...well you get the picture. A razor blade works best, and keep shaving it down until it fits in the holder snuggly. It doesn't have to be a perfect click, though if it is, you did a good job sanding . Test the bulbs by turing the power on through them to see if they flow.
Why using a 9005 bulb: 9005 bulbs are 65W and are not capped at the end, 9006 bulbs are 55W and have a cap at the end. You have to slightly modify the 9005 bulb to fit the 9006 socket. A 9005 bulb has 70% more lumens than the 9006 (1700 lumens vs 1000 lumens). HID has 3200 lumens.
Here's a pic of the bulb exactly.
What you have to do, is check the AIMING (check your manual) basically look at a white wall and see if your lighting is even. The colour and intensity WILL surprise you , it actualy may want to make you drive at night more often.
Old 07-22-2006, 03:51 PM   #9
m4gician
BTW, USE SILVERSTARS 9005 FOR BRIGHT HID-like WHITE LIGHT.
Old 07-24-2006, 11:22 PM   #10
burnout
burnout's Avatar
What is the # of the bulbs that light up the instrument cluster?
74 perhaps? (wild guess) Does anybody know?
'13 VW CC 2.0T
'99 Volvo S70 AWD
Add to burnout's Reputation
Rate the quality of this post and help burnout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-31-2006, 10:35 PM   #11
SylenThunder
2003 VUE 2.2L
2004 VUE 2.2L
not sure you can replace those. I was thinking about puting blue bulbs in for the lights that light up the front of the dash, but once I got it opened up, I was dissapointed to see that they are soldered onto the board. Not sure if they can be replaced. Or if they would ever burn out.
Also, did the 9005/9006 swap with my silverstars and am absolutely lovin' it.
2004 FWD, Vti, 2.2L
Custom CAI
Old 07-31-2006, 10:49 PM   #12
smacmartin
smacmartin is on a distinguished road
Can't you just take a 9005 harness and cut 9006 end off and solder the 9005 end on?
Add to smacmartin's Reputation
Rate the quality of this post and help smacmartin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smacmartin is offline   Reply With Quote
Old 07-31-2006, 10:57 PM   #13
SylenThunder
2003 VUE 2.2L
2004 VUE 2.2L
yeah, but it's a heck of a lot easier to shave the inside on the bulb connection with my dremel. Reversable too.
2004 FWD, Vti, 2.2L
Custom CAI
Old 07-31-2006, 11:50 PM   #14
m4gician
can you post a picture of the beam pattern please?
Old 08-01-2006, 02:25 AM   #15
burnout
burnout's Avatar
I removed the instrument cluster and was able to twist out the little fixtures the bulbs are in, so they are definitely replaceable... I just can't find the replacement #'s anywhere.
'13 VW CC 2.0T
'99 Volvo S70 AWD
Old 08-01-2006, 07:53 AM   #16
James Gerber
James Gerber is on a distinguished road
James Gerber's Avatar
2003 VUE 2.2L
So are you basically modifying the low beam? If so, does it actually make the VUE 'safe' for night driving?
(I got the dealership to check my low beams and told them it's currenly unsafe for driving on highways unless i'm doing 60km/h (highways are 80km/h)
Any rate, they found one light socket was loose, and adjusted, but they still have an extremely short range.
I'm currently looking at options/mods that I can do to increase a safer low beam cast (like on my dads cargo van)... or is it no possible because of the placement of the headlights? (how they are placed high/horizontal).
thanks,
jg
Add to James Gerber's Reputation
Rate the quality of this post and help James Gerber reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
James Gerber is offline   Reply With Quote
Old 08-01-2006, 11:14 PM   #17
mellissam
mellissam will become famous soon enoughmellissam will become famous soon enough
mellissam's Avatar
2006 VUE 2.2L
I suppose I could look, but how easy is it to replace a low beam light bulb? I like the idea of modifying a 9005 and slapping it in there... Canadian Tire is calling me...come ...come....$24CDN/each is pricey (Silverstars), especially considering there is nothing wrong with my lights...my high beams blinded me on a road trip through the mountains a week ago....(beam would hit a road sign and the reflection had me ducking for cover). LOL
Add to mellissam's Reputation
Rate the quality of this post and help mellissam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mellissam is offline   Reply With Quote
Old 08-01-2006, 11:34 PM   #18
mellissam
mellissam's Avatar
2006 VUE 2.2L
Does anyoe have the 9005 Blue Sylvania's on thier rig? Curious to know if they prefer them over the silverstars 9005....
Old 08-01-2006, 11:56 PM   #19
SylenThunder
2003 VUE 2.2L
2004 VUE 2.2L
I used to use the Blues, now I use silverstars and probably won't use anything else until I get HID.
2004 FWD, Vti, 2.2L
Custom CAI
Old 08-02-2006, 01:53 AM   #20
mellissam
mellissam's Avatar
2006 VUE 2.2L
Before anyone tells me to RTFM, I was able to get the lights out without unscrewing the front...knew small fingers would come in handy one day...
I went with the Blues..as they were half the price, but the same Lumen #...can't figure that one out (price difference between high and low front beam lights is another mystery). Anyway, will post of photo, if I remember of the brightness difference between stock sylvania's 9006 and cool blue 9005 (front low lamps). See if all this chattering is worth the effort....ok, I am bored, nothing better to do...LOL
Astra Bulb sizes afk123 Astra Tech 0 04-29-2009 05:31 PM
2007 Bulb guide fotovue Vue General 2 04-26-2007 06:54 PM
Instrument Cluster LED/Bulb #'s/Sizes emptypockets S-Series Tech 2 02-07-2005 12:34 AM
Light Bulb Sizes?? xtremesc2 Ion Red Line 1 11-10-2004 12:15 PM
Bulb sizes for LS1 Hank3 L-Series General 11 12-05-2003 07:21 PM
