Old 07-11-2006, 01:34 AM   #1
cruzr
cruzr is on a distinguished road
Default Headlights won't turn off
I turned on my high beams while driving and now the headlights, high or low beam, will not turn off at all. No amount of flicking or turning the rotary switch at the end of the stock will stop the light. The only way that i was able to turn off my headlights was to unplug my battery. The high beam light on the dashboard is also always on.
Please Help!
Any postings will be very much appreciated
-Cruzr
Add to cruzr's Reputation
Rate the quality of this post and help cruzr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cruzr is offline   Reply With Quote
Old 07-11-2006, 01:50 AM   #2
SaturnManiac
SaturnManiac's Avatar
Default Re: Headlights won't turn off
Perhaps a model and year would help. You can list mileage, but I don't think anyone would need that info, although it might help. What were the symptoms before this started happening?!
But to me it sounds like the switch/level/knob is bad.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-11-2006, 07:34 AM   #3
Uzzy
Uzzy's Avatar
2002 SC1
Your turn signal arm switch is bad. It's not cheap, and is not a fun job. I've never heard of that happeneing before.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 07-11-2006, 08:58 AM   #4
cruzr
Thanks for the help!! Sorry I didn't provide more info as to year and make it is a 2002 SL1 with only 40,0000 km's. There was no hint of anything about to go wrong before this started. I have since pulled the fuses out so at least I can turn the car off and not have to disconnect the battery. Again, thank-you for you're advice.
Old 07-11-2006, 09:08 AM   #5
itsmesillybubba
itsmesillybubba is on a distinguished road
itsmesillybubba's Avatar
2006 ION-3 Quad Coupe
Just dont drive at night any more
Or
Go to a junk yard and get everything you need....and spend next Saturday tinkering
Friendship is like peeing your pants, everyone can see it, but only you can feel the true warmth.
My 95 SL1 is gone :(
Add to itsmesillybubba's Reputation
Rate the quality of this post and help itsmesillybubba reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
itsmesillybubba is offline   Reply With Quote
Old 07-11-2006, 09:14 AM   #6
Uzzy
Uzzy's Avatar
2002 SC1
Or
Well tinkering with a steering wheel that has an air bag, and bolts on the whole wiper arm, turn signal contraction that are one time use. (that means you need a hammer and chisel to remove them ) is why I said it's not a fun job.
I don't suppose you opted for the extended warranty?
Old 07-11-2006, 09:18 AM   #7
itsmesillybubba
Hmmmmm...you are right.....ummmmm Dont drive at night
Old 07-11-2006, 09:21 AM   #8
Uzzy
Uzzy's Avatar
2002 SC1
Old 07-11-2006, 10:29 AM   #9
itsmesillybubba
But seriously....It seems like something you should go to your mechanic about.
Old 07-11-2006, 05:01 PM   #10
cruzr
thank you guys for all the help,
i took my car the the saturn dealer, and the problem was fixed in a matter of minutes! turns out it was just a wire for the front passanger headlight that was rubbing against the headlight bracket, causing it to short out. A little bit of electrical tape fixed the problem.
Thanks Again
-Cruzr
Old 07-11-2006, 06:04 PM   #11
Uzzy
Uzzy's Avatar
2002 SC1
Thanks Again
-Cruzr
Oh, good. That's really weird. The switches go from time to time, but normally they won't turn on the lights, or signals, or wipers.
Turn on headlights and radio scrambles?? Project 50MPG S-Series General 3 08-18-2009 04:53 AM
Headlights won`t turn off michael1944 L-Series Tech 1 05-12-2009 08:51 AM
Headlights keep going off, and need to tap lens to turn on... Kristine S-Series General 5 12-29-2008 10:27 AM
Headlights/Turn Signal ?s (n00b questions?) tehSaturn S-Series Mods 3 11-18-2008 09:47 AM
Headlights (How do I turn the darn things off) stormcrow Vue General 57 05-05-2005 06:11 PM
