Old 07-05-2006, 10:03 PM   #1
remedys
remedys is on a distinguished road
remedys's Avatar
2001 SC1
Default Bcm?
When doing a motor swap on a 2001, I have the PCM, but the guy doing the swap said I need the BCM(body control mod.) from the same car or it will not run. He said I could get the tech 2 to run it, and it should work. I assume this is like flashing the PCM. Should I just get try and get the BCM, will the car start without it if I am using a 2001 pcm from a dohc and a 2001 dohc motor?
Add to remedys's Reputation
Rate the quality of this post and help remedys reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
remedys is offline   Reply With Quote
Old 07-06-2006, 11:47 AM   #2
remedys
remedys's Avatar
2001 SC1
Default Re: Bcm?
Anybody have any idea?
Old 07-06-2006, 07:59 PM   #3
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
Default Re: Bcm?
You don't need the BCM. Swapping engines involves changing nothing that the BCM would have any control over for running the engine. The BCM will control starter activation, theft deterent systems and the like but it does not care if you have a different engine from the factory one.
Add to ssicarman's Reputation
Old 07-06-2006, 08:11 PM   #4
remedys
remedys's Avatar
2001 SC1
Default Re: Bcm?
Its not the motor, its the VIN that is coded into the PCM that talks to the BCM. My guy told me that it would not start if the PCM and BCM didn;t have matching vins. But I picked up the set today for 50 bucks, so either way my ass is covered
Could this be another BCM Al10453 L-Series Tech 6 07-17-2008 10:24 AM
Is it the BCM or something else? birdieluvr76 Vue Tech 2 04-16-2007 02:08 PM
Bcm 1stSaturnowner L-Series Tech 4 05-31-2006 04:29 PM
What does the BCM do, exactly? kpatz General Saturn Discussion 4 03-21-2006 02:26 AM
BCM went out... VUEnumber1 Vue General 6 08-22-2005 04:09 PM
