Old 06-25-2006, 09:00 PM   #1
Cowboygrad04
Cowboygrad04 is on a distinguished road
Default front wheel bearing/hub assembly
I am 99% confident that the left front wheel bearing on my '03 Vue is going out. I did a search and the whirring noise (sounds like a B-17 taking off) seems to fit with all the posts about wheel bearings going out. I'm not to worried because I think that it's covered under my service contract.
Is the hub and bearing a one piece replacement? I.E. they don't sell them seperately? I've looked on Napa and Autozone's websites and they both list a wheel bearing/hub assembly for around $160. They just don't sell the bearing by itself.
I need to know this because if it's not covered under the service contract, I'll just change it myself. I grew up on a farm and have changed countless numbers of bearings on combines, tractors, and implements.
Add to Cowboygrad04's Reputation
Rate the quality of this post and help Cowboygrad04 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cowboygrad04 is offline   Reply With Quote
Old 06-25-2006, 09:19 PM   #2
IMkenNY
IMkenNY is on a distinguished road
Default Re: front wheel bearing/hub assembly
Yes its only sold as a one piece hub unit.
Your noise description is exactly what it sounds like and its a fairly common failure
Its a fairly easy job as long as the half shaft isnt seized in the hub ~1.0 to 1.5 hours labor (Remove half shaft nut and three bolts for the hub that are removed from the back side of the knuckel)
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
Stubborn wheel bearing hub assembly 2005 Vue, help! tkearsey Vue General 50 04-26-2019 11:02 PM
Wheel Bearing Hub Assembly Question sledgehammer777 Relay Tech 3 03-08-2010 11:45 PM
Wheel Bearing/Hub Assembly-Front/Rear dildog S-Series Tech 3 05-23-2007 11:58 AM
Front Wheel Hub/Bearing Assembly JD7 Ion General 2 06-21-2005 05:52 AM
Wheel Bearing/Hub assembly SLeepr S-Series General 9 08-24-2004 10:23 PM
