Old 06-22-2006, 10:35 AM   #1
jamiet757
jamiet757 is on a distinguished road
Default fog light wiring harness?
I have a 2001 SC1 and I just got some OEM foglights from an SC2 that I am going to put in. I know I don't have to wire them the way they come from the factory in the SC2's, but I want to know where I can find a wiring harness just so I can plug the wire into the bulb socket. I don't want to jury rig something and have it catch on fire or fall apart. I am going to use 899 bulbs, and I need to know where I can find a plug for them...thanks!
Add to jamiet757's Reputation
Rate the quality of this post and help jamiet757 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jamiet757 is offline   Reply With Quote
Old 06-22-2006, 12:03 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: fog light wiring harness?
If you want to wire it up like stock you neeed to purchase:
-Interior fog light switch
-Underhood fuse box
-Forward lamp wiring harness
You can wire it yourself and have it be safe and last as long as the stock components would if done correctly. All you need is a few feet of wire, a relay and a few electrical connectors. You could even use the stock switch.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 06-22-2006, 06:13 PM   #3
Is that something unpluggable from a car with fog lights? My parts SC2 seems to be the loaded version.
Old 06-22-2006, 08:18 PM   #4
wolfman
wolfman's Avatar
If you are going to use wattage bulbs higher than the OEM ones (880 IIRC) don't bother to make things too fancy. The higher wattage bulbs will run too hot for the OEM housings and they will MELT within a month or two...so you'll be taking everything back out anyway. (Seen this MANY times) The OEM houings were designed for 35 watt bulbs. Don't use anything higher than that, or you'll be sorrryyyy....
Add to wolfman's Reputation
Old 06-22-2006, 09:44 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
the stock fog lamp bulbs are 880X. I recently upgraded mine with Sylvania Silverstars. now I can actually tell if they're "on" or not when looking over the hood from the drivers seat
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 06-24-2006, 09:56 AM   #6
petdmc
petdmc is on a distinguished road
i have pics of the wiring harness in my photos.
you'll need some other things too, like clips and junk. If you can get a spare fuse block that would be great, if not i got a few lying around.
Add to petdmc's Reputation
Rate the quality of this post and help petdmc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
petdmc is offline   Reply With Quote
Old 06-24-2006, 11:00 AM   #7
I've got a loaded '97 SC2 to match my '97 SC1. I've got everything I need, I think.
Old 06-24-2006, 11:04 AM   #8
jamiet757
no you guys dont get it...thats not what i need...I need the plug that plugs into the back of the light bulb, not a wiring harness or fuse blocks, just the little plastic plug that goes into the light bulb and has wires coming out the end...if anyone has 2 or if you know where i can find them, let me know! thanks!
Old 06-24-2006, 11:14 AM   #9
Isn't the plug part of the wire harness? (I've got the rear of the car in the air, front bumper on the ground, can't see fog lights)
If not then...junkyard (pick&pull/whatever you call it) would be a usefull place, unless you've already looked.
Old 06-24-2006, 11:21 AM   #10
Uzzy
Uzzy's Avatar
2002 SC1
If you want to go fully stock, you need the wiring harness, fuse box, and switch, if you're gonna splice it all up together yourself, go to a junk yard with some side cutters and just cut them off.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 08-25-2011, 03:59 PM   #11
ModeOne4Ever
ModeOne4Ever is on a distinguished road
Where do you buy all that is needed for fog light installation?
Add to ModeOne4Ever's Reputation
Rate the quality of this post and help ModeOne4Ever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ModeOne4Ever is offline   Reply With Quote
Old 08-25-2011, 04:12 PM   #12
Low Saturn
Low Saturn's Avatar
2000 SC2
Default
Junkyards.
Old 08-25-2011, 05:08 PM   #13
jamiet757
I bought 880 bulb plugs on ebay, then you can just run the wire, use a relay to turn them on when your headlights are on.
I also bought the housings on ebay, but you could find them in junkyards too.
question about fog light wiring... nmoyer23 S-Series Mods 9 07-21-2008 05:00 PM
Wiring Harness kelso 2008 Vue 4 05-05-2008 04:30 AM
Fog light wiring PlasticCarsRock S-Series Tech 4 12-27-2007 09:36 PM
fog light wiring is it there mroverkill S-Series General 7 06-24-2007 08:19 PM
2001 SC2 wiring diagram? (trailer wiring harness) gumpish S-Series General 1 04-30-2005 11:45 PM
