Old 06-16-2006, 10:34 PM   #1
GySgt_V
GySgt_V is on a distinguished road
Default 95 SL1 SES codes 22 and 76
I have a 95 SL1 keeps on throwing out codes 22 Throttle position Sensor is too low and code 76 MAP does not follow Throttle Postion Sensor. So far I have replaced the TPS the MAP and the Ambiant Air Temp sensor in the air box, also within the last 6 months I have also replaced both temp sonsors and connectors. I have no other noticable problems just the SES light comming on and turning off at radom intervals and the RPMS vary from 500 to 1500 when idling. Any suggestions would be helpful.
Gy V
Add to GySgt_V's Reputation
Rate the quality of this post and help GySgt_V reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GySgt_V is offline   Reply With Quote
Old 06-16-2006, 10:48 PM   #2
rectifryer
rectifryer is on a distinguished road
Default Re: 95 SL1 SES codes 22 and 76
I would clean the throttle body really good with carb cleaner.
the computer controls idle via a motorised screw in the throttle body, if theres gunk in the way it blocks air that the computer would want to be there.
wont hurt to try.
Add to rectifryer's Reputation
Rate the quality of this post and help rectifryer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rectifryer is offline   Reply With Quote
Old 06-16-2006, 11:07 PM   #3
wolfman
wolfman's Avatar
Bad connection (perhaps a wire broken internally INSIDE the insulation where you can't see it) at the TPS or MAP harness or harness to sensor connector.
Or LOOSE main harness plug or corroded contacts at the PCM main harness plug connector.
(Hence the intermittant nature of the problem)
Add to wolfman's Reputation
2000 SL1 SES with codes HELP Iceman15154 S-Series General 2 11-08-2009 08:22 AM
93 SL1 ses codes 32 & 45 loweyj S-Series Tech 8 04-17-2007 05:43 PM
SES Codes- 2002 SL1 Ohmyohmyohmy S-Series Tech 2 01-06-2007 06:27 PM
94 Saturn SL1 - 6 SES Codes jimidonovan S-Series General 4 07-20-2006 04:16 PM
95 SL1 SES codes 22 and 76 GySgt_V S-Series General 0 06-12-2006 07:04 PM
