Go Back   SaturnFans.com Forums > Models > Saturn Relay > Relay General
Old 06-13-2006, 01:40 PM   #1
Scuba
Scuba is on a distinguished road
2005 RELAY-2
2004 VUE Red Line
Default Common problem noise in front end
The rattleing noise in the front end was caused by bad links, these links tie the Strut to the Sway bar, and have no provisions for grease, they went at 12,000 miles.... The mechanic said I should feel lucky some are going at as early as 6,000 miles. Sounds great, so I guess we can expect more to fail, since apparently there has been no changes made to them. Of course the dealer didn't stock the part, or at least enough of them. If you have a rattle in the front end the links should be the problem. Make sure the dealer has them in stock when you make the appointment, otherwise you will be going back. The service tech also told me that Saturn only allows them to stock certain parts and certain numbers. Just another problem wtih the Relay.
Scuba is offline   Reply With Quote
Noise from the front end simranika Vue Tech 3 07-24-2009 11:07 AM
Front End Noise BryanF Vue General 13 12-25-2008 03:15 AM
front end noise blkvue Vue General 31 01-09-2005 02:14 PM
New noise from front end! Freedom1955 Vue General 17 10-08-2004 11:28 AM
Noise from front end? JDub99SL2 S-Series Tech 3 08-26-2003 03:07 AM
