Old 06-04-2006, 12:50 AM   #1
burnout
burnout's Avatar
Default How to remove wheel balancing weights?
Is there a way for me to remove the wheel balancing weights at home, and be able to re-install them? Does the tire have to be unmounted from the rim, or taken to 0psi? (breaking the bead seal)
I want to paint my wheels a gunmetal color using Dupli-Color Wheel coating, but I can't have the balancing weights on there when I do it.
'13 VW CC 2.0T
'99 Volvo S70 AWD
Add to burnout's Reputation
Rate the quality of this post and help burnout reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-04-2006, 12:56 AM   #2
wolfman
wolfman's Avatar
Default Re: How to remove wheel balancing weights?
The wheel weights are put on AFTER the tire is inflated while it is on a spin balancing machine. While there is a "special tool" for just this purpose (removing and installing the weights) they can be worked off with careful prying with a flat bladed screw driver. To reinstall them, make sure the "U" shaped clip that goes over the tire rim is not opened up, place the weight in the desired location, and then TAP it on over the rim of the wheel with a small hammer, or hammer and a small flat bladed screw driver placed where the weight meets the clip. (The "special" installation tool is essentially just a small hammer with a narrow head.)
NOTE: Mark the TIRE first with a grease pencil or similiar marker so that you can be sure to get the weight(s) back on EXACTLY where they came off. DO NOT deflate or remove the tire from the wheel or it will need to be re-spin balanced.
Add to wolfman's Reputation
Old 06-04-2006, 01:11 AM   #3
burnout
burnout's Avatar
Thank you VERY much.
I planned on marking where the center of the weight goes on the tire.
When Sam's Club mounted my new tires on (235/60R16 Goodyear Integrities for those that are curious) I kinda got a good view through the window of them hitting it in... Now I know that's basically what they were doing :-P
'13 VW CC 2.0T
'99 Volvo S70 AWD
Old 06-04-2006, 07:26 AM   #4
D C
D C is on a distinguished road
D C's Avatar
If you're going through that much trouble, why not pay the $20-30 to have them re-balanced and ask them to use stick-on weights instead. Then there won't be any weight on the wheel lip at all.
Add to D C's Reputation
Rate the quality of this post and help D C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
D C is offline   Reply With Quote
Old 06-04-2006, 02:04 PM   #5
burnout
burnout's Avatar
Ahhh I forgot about that!
Its probably fine to drive with unbalanced wheels to the tire shop, correct?
What sucks, is that even though the dupli color paint is pretty durable, I don't trust any wheel shop to be careful with it. I'll look into it though.
'13 VW CC 2.0T
'99 Volvo S70 AWD
Old 06-04-2006, 02:25 PM   #6
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
I painted the wheels on my SC gun metal with that Dupicolor paint. Let me just warn you that if you don't prep the wheels ahead of time really well, the paint won't stick. You may also want to prime them first (something I didn't do). Also, a clear coat would be a good idea (again, something I didn't do). My paint was easily scratched off and I eventually took a wire brush to and now they have that brushed aluminum look.
And yes, driving a little ways with no wheel balancing weights will be fine. If you don't ever go fast enough, you might not ever know they aren't there.
Good luck.
--Tom
Not a Saturn.
Add to Tom92SCm's Reputation
Old 06-04-2006, 05:25 PM   #7
burnout
burnout's Avatar
Yikes, I can't get the weights off with my trusty flat blade screwdriver...
Should I just take the car to a shop to get them re-balanced using the sticky-weights?
'13 VW CC 2.0T
'99 Volvo S70 AWD
Old 06-04-2006, 06:21 PM   #8
Ritz
Ritz's Avatar
Any garage/repair shop will have the $10 special tool to pop the weights off. Chances are that if you ask nicely, someone would just pop them off for you. Putting them back on can be done with a rubber mallet (or a regular hammer if you're CAREFUL).
Cheers,
Add to Ritz's Reputation
Rate the quality of this post and help Ritz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-05-2006, 06:39 AM   #9
Mr Joe Handyman
Mr Joe Handyman is on a distinguished road
Mr Joe Handyman's Avatar
2003 VUE 2.2L
I used to work at a tire shop, and have seen this lots. the paint wil peel in a year or so. Unless you paint the entire tim. inside and out. Don't forget to rough the surface up so that the paint will adhere better, and be sure to put a couple of coats of clearcoat on after to protect it well. For best results your rims are going to be unusable for about a week. Painting rims is fun, but it's a lot of work if you want it to look good and last. if you don't have a spare set of rims, you might get some cheap steel ones at a junkyard. then you can swap to the steel ones while you are working on painting. Otherwise, have some blocks and another car to drive, get the tires taken off the wheels, (along with weights,) paint 'em up, and then go back and have them re-mounted. (Be sure to have them use the sticky weights so there's less chance of messing up your paint, also let them know that it's a newly painted rim and make them use coated equipment. It will cost a little more, and it's a bit of a pain, but it's the difference between your paint job lasting 1 year or 10.
Dont criticise someone till you walk a mile in their shoes.
Then you'll not only be a mile in front of them but you'll also have a new pair of shoes.
Add to Mr Joe Handyman's Reputation
Rate the quality of this post and help Mr Joe Handyman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mr Joe Handyman is offline   Reply With Quote
wheel weights falling off baydreamer Vue Tech 0 09-03-2007 06:19 AM
Wheel weights!!! quiksc2 S-Series Mods 4 02-12-2007 08:10 AM
Wheel weights djb383 Vue General 5 11-16-2006 05:37 PM
Cheap wheel weights alank Vue General 7 07-11-2005 01:00 PM
OEM wheel weights; how heavy are yours? RexSpeed S-Series General 1 08-24-2004 08:27 PM
