Old 06-02-2006, 09:13 AM   #1
sandybright
sandybright is on a distinguished road
sandybright's Avatar
Default Driver Side Mirror - Easy DIY Repair??
Well, my problem is exactly what my thread title says. My driver side mirror had a run in with a small tree and the tree won. The glass on the mirror didn't break, it was the plastic that held the mirror to the car that did. Called the dealership and they quoted me $200 to fix it.
So, my question is if you buy the part, how easy is it to fix it yourself, and if you can diy, then is there a how-to somewhere that someone can post? I have enough confidence in my skills to be able to fix it myself as long as it's not too detailed a procedure.
1999 Blackberry SC1 - 74,000 miles 2002-2005 :(
1999 Blackberry SL2 - 121,000 miles 2006-present
Add to sandybright's Reputation
Rate the quality of this post and help sandybright reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sandybright is offline   Reply With Quote
Old 06-02-2006, 10:05 AM   #2
Low Saturn
Low Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to allLow Saturn is a name known to all
Low Saturn's Avatar
2008 AURA XE
Default Re: Driver Side Mirror - Easy DIY Repair??
Its only one phillips screw, a very small allen wrench and three 10mm bolts. Should take no more than two minutes.
Remove screw from mirror trim panel, loosen forward edge of window frame garnish molding and pull trim panel rearward to disengage. On driver side, loosen set screw and disconnect cable from trim panel
Remove foam filler from mirror reinforcement area. On passenger side power mirror, disconnect harness connector.
Remove nuts from mirror assembly and remove mirror and seal.
Mike
1991 Saturn SL2 Dragster
11.809 @ 116.488 mph TURBO!!!
www.differentracing.com
2001 Light Pewter Metallic Chevrolet Suburban
2.0L 1995 Saturn SL2m
http://www.cardomain.com/id/lowsaturn
Mike
-2001 Chevy Suburban
-2008 Saturn Aura XE V6
Im out of EGR adaptors & ECTS connectors.
Old 06-02-2006, 10:07 AM   #3
hsv sc2
hsv sc2 is on a distinguished road
can't visualize what's broken......is it the plastic mount holding the glass inside the mirror....
or the plastic housing holding the mirror to the car door broken.
First is pretty easy (my dealer will get that specific part for me)
The other will force you to take the inside door panel off to attach the new housing to the car door.
Add to hsv sc2's Reputation
Rate the quality of this post and help hsv sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hsv sc2 is offline   Reply With Quote
Old 06-02-2006, 10:11 AM   #4
hsv sc2
Dizzy Re: Driver Side Mirror - Easy DIY Repair??
stand corrected...forgot about the little corner panel (you don't need to remove the door panel.
Old 06-02-2006, 03:37 PM   #5
davemac2
davemac2 is on a distinguished road
buy a used mirror on Ebay for $30 or so. Don't pay $200 for a new one. Waste of money. As already said, pretty easy to change out.
Dave mc
Add to davemac2's Reputation
Rate the quality of this post and help davemac2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
davemac2 is offline   Reply With Quote
Old 06-02-2006, 03:44 PM   #6
sandybright
If you are standing directly in front of the panel, with the mirror facing right, the part that is broken is the small panel part in the lower right hand corner.
Old 06-02-2006, 04:10 PM   #7
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
fixed mine ,
it was hanging by the cables that adjust mirror angle,
removed the assembly from door
on the back of the triangle shaped pannel
noticed there were assembly alighnment dowels
put a 1 inch drywall screw into each dowl position
pulled the assembly back in place with screwdriver
you will need to break off the plastic tabs (dowels )
then put the screw right into that spot
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Driver Side Mirror Replacement Panabear S-Series General 8 03-28-2008 04:19 PM
'07 ION Driver Side Mirror tbpowers Ion Tech 3 01-28-2007 11:48 AM
Needed, driver side mirror kleem Old Classifieds 1 07-15-2006 10:45 PM
Replacing the Driver Side Mirror FlipTopBox Ion General 1 08-31-2004 09:38 PM
driver side (auto-) dimming mirror? pmin S-Series Tech 0 08-29-2001 02:53 PM
