Old 06-02-2006, 01:46 AM   #1
WopMaster8
WopMaster8 is on a distinguished road
WopMaster8's Avatar
1994 SC2
Default 0 - 4,000 vs. 4,000+ RPM Acceleration
I know these cars are designed more for economy than performance but what's with the slow acceleration up to 4,000 RPMs even with the pedal floored? Is there some type of restriction device put in by Saturn to help lead footers save some gas money (possibly even PCM programming)? From 0 - 4,000 it's like driving through tar but as soon as the tach hits that mark it feels like the car wants to smoke the tires right off it. It literally jerks my head back every time I take it up that high even when I'm expecting it. I wouldn't mind having that sort of acceleration all the way through if it's possible. So what's the deal?
I couldn't think of a way to search for the information I was looking for without getting a bunch of useless stuff back so if the explanation is already around sorry for starting another thread.
Add to WopMaster8's Reputation
Rate the quality of this post and help WopMaster8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WopMaster8 is offline   Reply With Quote
Old 06-02-2006, 01:49 AM   #2
wolfman
wolfman's Avatar
Default Re: 0 - 4,000 vs. 4,000+ RPM Acceleration
The "S" series are cammed and timed to reach peak torque right around ~4k rpm. Shy of changing the camshaft (with a custom ground one) you are stuck with what you have.
If you are getting sluggish acceleration even at WOT (Wide open throttle) investigate the possibility of clogged fuel injectors or a bad TPS (Thottle Position Sensor)
Add to wolfman's Reputation
Old 06-02-2006, 08:46 AM   #3
eljefino
eljefino's Avatar
1995 SW1
I've found data that suggest the PCM ignores the knock sensor above 3500 RPM or so.
You could try loading up on high-test gas, then going home, disconnecting the battery a while, and going back out there.
It won't cure it but might make the jump feel a little softer if you were previously living with a little knock retard. A good scan tool would tell you.
Add to eljefino's Reputation
4,000 rpm @ idle Bruce Rock S-Series Tech 1 11-19-2008 09:21 PM
Rattle at 4,000 RPM paulff3 Astra General 21 10-23-2008 11:17 AM
'01 SL2 Rumbling Noise at 1,000 rpm Splops S-Series Tech 3 08-31-2007 03:15 PM
Just reached 180,000 km (112,000 miles) on my 2000 SL2 Admiral Beez S-Series General 1 03-04-2005 08:29 PM
