Old 05-29-2006, 09:22 PM   #1
f3qu3t
f3qu3t is on a distinguished road
f3qu3t's Avatar
2008 Outlook XR
Default What caused my wet trunk
So, I was talking with my service advisor and asked him how difficult it would be to remove the rear quarter panel (to find the source of the leak), "Oh, not hard at all. There's like only three bolts holding it on" he says. Alright, sounds good. I had some time yesterday so I figured I'd work on it. Turns out, there's more like nine! Four of them are nice and hidden. Regardless, it wasn't all that complicated. Just removed the tail_light, bumper, and ground effects(?) under the door. Perfect, removed the quarter panel.... and there it is! Stupid crack. I threw some silicon everywhere to ensure no more leakage. Next time I'll attack the other side. It should be a little easier, not to mention quicker, now that I know (somewhat) what I am doing.
Add to f3qu3t's Reputation
Rate the quality of this post and help f3qu3t reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
f3qu3t is offline   Reply With Quote
Old 05-29-2006, 09:55 PM   #2
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
Default Re: What caused my wet trunk
Did you have to remove the quarter panel to find it? I just bought a 97 SC2 where it's obvious that the trunk has been leaking for a long time. The Spare tire well cover and trunk carpet are moldy, and the jack and spare tire are completely rusted.
Add to blackeagle1's Reputation
Rate the quality of this post and help blackeagle1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackeagle1 is offline   Reply With Quote
Old 05-30-2006, 03:49 AM   #3
mikewms
mikewms is on a distinguished road
mikewms's Avatar
2000 SC1
I have the same problem. I figured it was under the rear quarter panel. I was looking at the bolts. It looked like they were torx. Is that true and if so what size are they?
"If you don't know where you're going any road will take you there."
Add to mikewms's Reputation
Rate the quality of this post and help mikewms reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikewms is offline   Reply With Quote
Old 05-30-2006, 10:25 AM   #4
f3qu3t
f3qu3t's Avatar
2008 Outlook XR
Yes, I did have to remove the quarter panel. It really isn't all that difficult. I could give you step by step if you like. When I get home this afternoon I could see if I have a better picture of the process.
There is four torx screws (of the nine). Two of them are in the door, surrounded by rubber. The other two are at the tail.light. I am not sure of the exact size, though I can get that for you later today.
Old 05-30-2006, 10:34 AM   #5
Uzzy
Uzzy's Avatar
2002 SC1
Mine will be going in this week (or at least very soon) for a leaky trunk fix. It was already mis-diagnosed as a bad trunk seal, which was not covered under warranty. The rear quarter will have to come off. But this time it'll be warranty.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 05-30-2006, 07:15 PM   #6
f3qu3t
f3qu3t's Avatar
2008 Outlook XR
torx screws sizes T-15 & T-30 (locations shown in green)
socket sizes 10mm & 7mm (locations shown in blue - I can't remember if I used any other sizes)
I am not a professional, and by no means do I know what I am doing!
1. Remove the 2 T-30 torx screws inside of the door. They are surrounded by rubber.
2. Removed the tail.light with the 2 T-15 torx screws. Pull the tail.light straight back, then disconnect the cable.
3. The best part of all. Remove all of the 'black plastic plugs' (not sure of their proper name) from the wheel-well, ground effects(?)(the thing below the door) and the bumper.
--If you don't know how to remove them, just seperate & remove the cap (start with the wheel-well, they are easier), now pull out the plug - some look as if they don't have a cap, they do, it is just flush with the plug--
The wheel-well has 5 plugs & 3 screws (7mm)
The bumper has 4 or 5 on the top as well as 5 or 6 underneath.
With the plugs removed from the ground effects, just simply slide it towards the front, and then pull it towards you.
4. There are 2 screws (10mm) that hold the bumper to the quarter panel. Access them through the wheel well (if you haven't removed the wheel-well guard, now would be a good time). There isn't a lot of room, just enough . The bumper can now be pulled away. Take note of the white thing circled in pink (for re-assembly).
5. Remove the 2 screws where the tail.light would be. Look inside to see how the little latch thing clips into the panel. (shown on the other pic)
6. Don't forget that bolt that's on top (usually covered by the trunk lid), and the 2 bolts that were hiding behind the ground effects.
7. The panel can now be removed. !!!There is a clip (circled in yellow) holding the panel on. I did not know this at the time, and just pulled the panel away---everything was fine. After inspecting the panel, it looks as if, to remove the panel, somehow(?) slide it forward. I did not do this. When I took it off, I pulled. When I put it back on, I pushed - no damage(for me).
Remember: I am not a professional, and by no means do I know what I am doing!
This process was extremely easy.
Try to remember where everything goes when removing pieces. I was left with an extra plastic plug. -One less to remove next time!
Any questions, feel free to ask, email, I'll do what I can to help!
Old 05-30-2006, 07:54 PM   #7
mikewms
mikewms's Avatar
2000 SC1
I think these instructions are great. I will be doing this over the weekend. I will let you know how it goes. A big thanks as the Saturn Chilton's manual doesn't tell you how to remove the rear quarter panel.
Old 05-30-2006, 11:25 PM   #8
f3qu3t
f3qu3t's Avatar
2008 Outlook XR
...a little more concise.
For the clip that holds the panel under the window (circled in yellow), before you try to remove it, take a look at it by lifting the seal up a bit. As you are looking at it, run your finger along, towards the back, to see if you can see the "lip" gradually thin out. I think this may be the proper way to remove the panel - by sliding the panel towards the front, to position the thinned out lip at the clip.
I'd hate for someone to pull their panel off and have some damage done to it.
Again, like I know what I'm talking about.
Old 05-30-2006, 11:41 PM   #9
Uzzy
Uzzy's Avatar
2002 SC1
"Uzzy's Instructions for Fixing a Mysterious Trunk Leak"
Step 1: Buy lease return SC1, AND the Saturn factory extended bumper-to-bumper warranty.
Step 2: After first diagnosis for leaky trunk seal is wrong, and seal is not covered under warranty, let Saturn of Windsor's service advisor know about it
Step 3: Book 2nd appointment for the wet trunk.
Step 4: Demand the loaner car you were promised by the idiot that told you that you would get one when you signed up for the warranty.
Step 5: Hope for the best, and be glad you got the warranty, because not everyone is so lucky.
To all you without, sorry, guys/gals, that sucks. It's something I could easily do myself, but why would I, when one of my best friend's can get paid to do it? He's getting it dropped off on Monday morning. Good Luck to all of you on your own. Seems to be a common complaint
Old 06-02-2006, 12:50 PM   #10
mikewms
mikewms's Avatar
2000 SC1
Well, thanks to your patient posting of instructions I now have a very dry trunk. I found the crack in the silicone in virtually the same place as yours. I siliconed the crap out of it and everywhere else it looked like it might leak in the future. I let it cure for a day and today washed the car. I would usually get water in the trunk during a wash. Today it was as dry as a bone. Tonight will be the real test as we are expecting heavy thunderstorms. Thanks again.
Old 06-04-2006, 03:45 PM   #11
f3qu3t
f3qu3t's Avatar
2008 Outlook XR
Hey, that's great to hear!
It had rained here most of this last week, I tell ya, what a relief it was to find a dry trunk. It feels good knowing, after it rains or a wash, there is no longer a need to dry out the trunk.
I'm glad I could help.
Old 06-05-2006, 07:13 PM   #12
Uzzy
Uzzy's Avatar
2002 SC1
Ok let me make an addendum: IT'S NOT COVERED UNDER THE BUMPER TO BUMPER WARRANTY!
They told my buddy working on it, after he had the rear quarter panel off. Normally the job would charge over 4.5hrs, but they are charging me only 2 for the whole thing. And it was in for a rough idle as well, and it turns out it's not a bad upper engine mount, it's leaky intake. So that's good news to my friend that would have lost his shirt on my car. It's covered under warranty and it's a gravy job for him. So either way, it was nicer for him to remove the panels in the air conditioned shop with a hoist rather than both of us busting our nuts in his driveway in the hot summer sun. It was weird to pull into the Saturn of Windsor parking lot and see my car driving around the lot without a rear right quarter tho.
Old 06-05-2006, 07:30 PM   #13
f3qu3t
f3qu3t's Avatar
2008 Outlook XR
Well that sucks.
Though, paying for 2 hrs labour is a lot better than 4.5!
Old 06-05-2006, 07:43 PM   #14
Uzzy
Uzzy's Avatar
2002 SC1
Originally Posted by f3qu3t
Well that sucks.
Yeah, it's good thing they like me there.
Old 06-05-2006, 07:46 PM   #15
DeCaff2006
DeCaff2006 is on a distinguished road
DeCaff2006's Avatar
1994 SC2
OK I am sooooo glad I read this post. I am having the same problem with my 94 SC2 but I didn't want to post it just yet as I though the spoiler seals were leaking. Now, armed with this post and the uber sweet How-To by f3qu3t, this will be my weekend project.
That How-To should seriously be posted in the How-To section.
Add to DeCaff2006's Reputation
Rate the quality of this post and help DeCaff2006 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DeCaff2006 is offline   Reply With Quote
Old 03-19-2007, 03:54 PM   #16
mlt01SC2
mlt01SC2 is on a distinguished road
mlt01SC2's Avatar
Thanks for posting. I bought my 2001 SC2 second hand, 50,000+ miles on it and when I washed it, I found out why is was a lower priced than most. Too bad the original owner didnt get it fixed first!
I had been hunting the net for such pictures and instructions. This will be a sweet fix, should only take about an hour or so!
Add to mlt01SC2's Reputation
Rate the quality of this post and help mlt01SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mlt01SC2 is offline   Reply With Quote
Old 03-19-2007, 04:55 PM   #17
orangekid13
orangekid13 is on a distinguished road
wow I wish I had seen this before I did it without instructions or any idea of how to get it off last wednesday... scraped off a bunch of the other sealant on there and found a couple other tiny rust spots and another gap... sealed them up with roofing tar caulking and put it back together the next morning...
anyways, i had the EXACT same problem
I drilled out those two rivets on the edge by the door too... oops. had to take my mom's car to the hardware store to get some rivets/washers to put those little brackets back on.
I also washed it the day i put it back together cause it hasn't had a bath since august, even though i knew it was going to rain that night. there has not been any more water in my trunk since.
Guess that's what I get for buying a car that had always slept in a garage...
still need to find time to jack up the front, take out that wheel well liner and figure out why the fender isn't fully secured there... it's only cosmetic so it'll prolly have to wait til i'm home for the summer in may. that's right, my summer starts may 5th!
Add to orangekid13's Reputation
Rate the quality of this post and help orangekid13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
orangekid13 is offline   Reply With Quote
Old 03-19-2007, 05:08 PM   #18
RickKlages
RickKlages is on a distinguished road
RickKlages's Avatar
This summer I think I will remove all plastic body panels and drive around that way.
ick
Add to RickKlages's Reputation
Rate the quality of this post and help RickKlages reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RickKlages is offline   Reply With Quote
Old 04-28-2009, 09:23 AM   #19
Carl26
Carl26 is on a distinguished road
Carl26's Avatar
So do those two rivets that are on the front edge of the quarter panel near the door need to be drilled out or removed? According to f3qu3t's instructions, they don't. That is what stopped me from removing the quarter panel.
Thanks for the instructions though, I need to fix the trunk leak in my '98 SC2. I'll probably be doing it very soon.
Add to Carl26's Reputation
Rate the quality of this post and help Carl26 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Carl26 is offline   Reply With Quote
Old 01-21-2017, 08:53 PM   #20
This thread helped me quite a bit to remove the quarters on my 02 SC2 to seal leaks, so I'll add my pics and comments here
On my car, just the lower one on each side was surrounded by a rubber bumper. Top bolt was in clear sight (yellow arrows)
Do not try to remove the small black bolt thingie (blue arrow) - it does not need to come out, just the two T30 bolts
These are our old friends, the push-pin. Different from the fender ones. It helps to use the special tool sold at auto stores, or a tack puller to get the pin started out
One bolt is on the bottom (see pic) and the other is on the top. Both are vertical 10mm head bolts
My Wet Trunk Jsolts S-Series General 13 12-29-2013 08:38 PM
Trunk is wet in my '94 SL1 Pega_de S-Series Tech 5 03-19-2009 06:46 PM
2000 sc1 - Wet trunk julibill S-Series Tech 6 04-27-2008 03:01 AM
Trunk problems (not wet though) fetchitfido S-Series Tech 2 06-05-2006 05:43 AM
Wet trunk anyone?? green_sc2man99 S-Series Tech 17 05-16-2006 11:13 PM
