Old 05-17-2006, 06:01 AM   #1
alfieferenzo84
alfieferenzo84 is on a distinguished road
2004 ION-1 Sedan
Default Is it the throw out bearing???
Okay if i put the car into n and let it idle it sounds like i have a rod knock starting but if i push the clutch in and leave it in n the knock goes away! Also if i put it into gear i have no noise!
My friend told me its the throw out bearing but i dont know much about trans so i let me know what you all know!
Also it has been kinda hard every now and then going into gears when i down shift!
Any ideas or thoughts would be great Thanks
I wish it would end and just run like a normal car without somthing going wrong everytime i drive it!
Add to alfieferenzo84's Reputation
Rate the quality of this post and help alfieferenzo84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alfieferenzo84 is offline   Reply With Quote
Old 05-17-2006, 11:46 AM   #2
andy_95sl2
andy_95sl2 is on a distinguished road
andy_95sl2's Avatar
Default Re: Is it the throw out bearing???
knocking while clutch is engaged=throwout bearing has gone bad
hard to shift while driving=bad clutch
i'd get a CLUTCH KIT because it has EVERYTHING needed for a full clutch job.
2004 Jeep Wrangler Rubicon -> daily & toy =)
2009 BMW 128i -> sold
2003 VW GTI 1.8T -> wrecked
1998 Saturn SL2 -> parted out
1995 Saturn SL2 -> sold
Add to andy_95sl2's Reputation
Rate the quality of this post and help andy_95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andy_95sl2 is offline   Reply With Quote
Old 05-17-2006, 12:40 PM   #3
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
...except he said it happens when the clutch is NOT engaged. (clutch pedal out).
Hard to shift while driving could also be the hydraulics. Check the fluid level of the transaxle and the fluid in the clutch maste.r cylinder. (intentional misuse of punctuation, I hate in-post ads.)
Does the knocking stay at one pace or does it pick up when the engine is rev'd?
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 05-17-2006, 12:42 PM   #4
Um, when the clutch pedal is out, the clutch IS engaged.
Add to madpogue's Reputation
Old 05-17-2006, 01:02 PM   #5
RangerRover
1999 SW2
LOL that was dumb.. doh! I had a similar sound before I replaced my clutch. The throwout bearing had somehow "eaten" into the spring fingers - about half had more wear on them than the others.
Old 05-17-2006, 04:22 PM   #6
alfieferenzo84
2004 ION-1 Sedan
I have a oem clutch master/slave with only 3k on it and yes it was a little low so i filled it up it did seem to help but the noise is still there just a little quiter!
I am thinking its the throw out bearing i did replace the clutch with a luke kit about 7k ago!!! When i did the auto to manual swap~!
But i learned on it so maybe it is all bad??? Thanks everyone
Last thing i dont think it get much louder with rpms kinda hard to tell with that 2 1/4 exhaust lol
Old 05-17-2006, 10:11 PM   #7
wolfman
wolfman's Avatar
For the throw out bearing, with the car in NUETRAL clutch pedal OUT (released) and the noise happening, SLOWLY and GRADUALLY depress the clutch pedal. If the noise quiets right about the time you just start to get resistance to the pedal being pushed, odds are it IS the throwout bearing that is the cause of the noise. IF the pedal is depressed far enough that you can actually put the transaxle in gear, it may not be the throwout bearing at all, but this suggests that the THRUST BEARING on the CRANKSHAFT is worn and the crankshaft is "walking"
Add to wolfman's Reputation
Old 05-18-2006, 10:40 AM   #8
black92sc
black92sc is on a distinguished road
1992 SC
I have this same problem. The noise happened a few months after I had my clutch and hydraulics replaced and it's been having that noise for a couple of years. Is it OK to leave or do I need to fix it?
Add to black92sc's Reputation
Rate the quality of this post and help black92sc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
black92sc is offline   Reply With Quote
Old 05-18-2006, 01:03 PM   #9
saturnPr!de
saturnPr!de is on a distinguished road
saturnPr!de's Avatar
i had the same problem, but i got the clicking sound when the clutch pedal was IN and like someone said it was wearing into the teeth. i replaced the whole thing with a sport clutch package.
Add to saturnPr!de's Reputation
Rate the quality of this post and help saturnPr!de reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnPr!de is offline   Reply With Quote
Old 05-18-2006, 05:42 PM   #10
alfieferenzo84
2004 ION-1 Sedan
Wolfman i have to push the pedal half way down to make the noise 100% gone but it does get lower as i push the pedal in,
I dont think it goes up or down with the rpms!
Old 05-18-2006, 08:44 PM   #11
zoso007
zoso007 is on a distinguished road
1997 SC1
hmm... alfie listen to this, does it sound like it?
Its what my car is doing to, I am hoping I just need a new clutch kit.
Click here to watch engine_noise-85
Add to zoso007's Reputation
Rate the quality of this post and help zoso007 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zoso007 is offline   Reply With Quote
Old 05-19-2006, 01:05 AM   #12
alfieferenzo84
2004 ION-1 Sedan
no where that loud but kinda close, mine dont go up with rpms
not to scare you but how many miles you got? And does that go away when you push the clutch in? Sounds like rod knock or a lifter put a post up!!!
throw out bearing??? slowion06 Ion Tech 7 07-16-2009 06:28 PM
throw out bearing tehwarrior S-Series Tech 8 11-03-2007 09:02 AM
throw out bearing zoso007 S-Series Tech 1 08-15-2006 10:10 PM
Throw away bearing? bobke1 S-Series Tech 13 05-15-2005 12:28 AM
throw out bearing? SLeepr S-Series Tech 12 12-30-2003 05:13 PM
