what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Ion > Ion General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 03-05-2002, 07:56 PM   #1
josh93sc2
josh93sc2 is on a distinguished road
Devil Best way to intentionally disable car?
Okay, I figure the best way to disable a car if you don't care about permanent damage is put a handful of dirt in the throttle body. Car starts, engine stops.
However if you don't want to do anything permanent, what's the best way to disable a car? You could do something simple like pull the plug wires, but what if someone has basic knowledge of cars? I figure removing the clutch sensor is the best because it causes no damage, car won't start, and it's not an obvious first place to look.
Don't worry I'm not out for vengeance, I'm just plum curious.
Add to josh93sc2's Reputation
Rate the quality of this post and help josh93sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
josh93sc2 is offline
Old 03-05-2002, 07:59 PM   #2
sweet2002sc2
sweet2002sc2 is on a distinguished road
Default
pull the maxi-fuse for the fuel pump.... then it will even crank over!
Add to sweet2002sc2's Reputation
Rate the quality of this post and help sweet2002sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sweet2002sc2 is offline
Old 03-05-2002, 08:03 PM   #3
piney
piney will become famous soon enoughpiney will become famous soon enough
piney's Avatar
Default
I would think that if you pulled one of the big fuses from the fuse box that this would likely stop it from starting or turning over (depending upon which one you pulled).
Of course up in Boca, all you'd have to do is have it not be a 2000 or newer Mercedes, Jag, or BMW & nobody up there would steal it anyhow...
Although, I do remember as a little tot hearing how my dad and his buddy poured molases in the crank case of a local kid who refused to slow down while on our street. His car lasted something less than a week after that. The molases probably saved his life or someone elses.
Add to piney's Reputation
Rate the quality of this post and help piney reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
piney is offline
Old 03-05-2002, 10:31 PM   #4
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
Default
Some people wiring kill switches ... not sure if you are looking for an extra step of security or what.
Even a little thing would really throw off someone trying to steal your car. Its a bit unexpected, takes too much time to diagnose the problem (afterall, you are stealing a car), no one wants to steal a broken car, etc.
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Old 03-06-2002, 07:56 AM   #5
djenning
djenning is on a distinguished road
Default
Are you trying to stop the kids from taking the car?
Add to djenning's Reputation
Rate the quality of this post and help djenning reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djenning is offline
Old 03-06-2002, 09:24 AM   #6
Doug_E_95_SL2
Doug_E_95_SL2 is on a distinguished road
Doug_E_95_SL2's Avatar
Default
It would be easy to disconnect the connection going into the DIS unit. This is the equivalent of the Coil, and provides the spark for the spark plugs.
This is a rather obvious method.
You could also fit an empty plastic container into the air intake, stopping it up.
-Doug
Add to Doug_E_95_SL2's Reputation
Rate the quality of this post and help Doug_E_95_SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Doug_E_95_SL2 is offline
Old 03-06-2002, 09:33 AM   #7
Galileo
Galileo is on a distinguished road
Galileo's Avatar
2007 AURA XE
Default
Just let the air out of the tires....
Beautiful People First~
Add to Galileo's Reputation
Rate the quality of this post and help Galileo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Galileo is offline
Old 03-06-2002, 09:44 AM   #8
Doug_E_95_SL2
Default
Bwaaaa! Ha haa! yes.
No tires? No go.
Can you imagine a car thief working really hard to get into a car, get it started then realize he has 4 flats?
Haaa!
-Doug
Old 03-06-2002, 10:07 AM   #9
pkschul
pkschul is on a distinguished road
pkschul's Avatar
Default
If you don't mind resetting your clock all the time... mount your battery in the trunk and install a battery cable connection switch under the seat. My friend always wanted to do that with his Chevelle... not sure if he did. This might not be a good idea with newer cars... lol.
Paul
Add to pkschul's Reputation
Rate the quality of this post and help pkschul reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pkschul is offline
Old 03-06-2002, 10:02 PM   #10
josh93sc2
Default
CLOSE! Actually a friend of our family's tried to do that (didn't work, I forget what exactly he tried) so it just got me thinking how I would do it if I had kids. Maybe just run a chain through the wheels and lock it? Simple, quick, effective....
Old 03-07-2002, 07:35 AM   #11
Phil
Phil is on a distinguished road
Default
I would start by not giving them any keys.
Failing in that, Just put it up on jackstands, remove the wheels, and hide the lug nuts.
Add to Phil's Reputation
Rate the quality of this post and help Phil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phil is offline
Old 03-07-2002, 11:50 AM   #12
Qlara
Qlara's Avatar
Idea
Like Phil said:
NO KEYS! as simple as that, why need to go through all the hassles? Or simply Sell the car, as you already leave it on the driveway and let your kids take it. (Hint: You're not using it?)
If the No-key policy failed, simply remove both License Plates and lock it in some place. Let the police gives those kids a lesson, about responsiblity and liability.....
Add to Qlara's Reputation
Qlara is offline
Disable Overdrive Hobo_wes S-Series Tech 2 10-27-2009 03:42 PM
Disable headlamps whne car is unlocked? mlandusk Aura General 10 09-22-2009 03:02 PM
My first post! Disable Car Alarm on 97 SC2? Wesley123 S-Series Tech 1 12-26-2006 11:12 PM
Do you intentionally squeeze your Saturn into tight parking spots? Admiral Beez S-Series General 23 11-25-2005 04:10 PM
Do You Intentionally Park Next to Other Saturns? Charlie Polls and Questions 84 09-27-2005 09:35 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
