#1 | ||||
![]() Join Date: May 2006
2003 Saturn Vue V-6 AWD. No major problems except now. Key wouldn't turn in ignition yesterday (for the 1st time). Was finally able to get it to turn after turning wheel to the right (hard). Got home, called the dealership, they said that it was either the ignition cylinder or the key could be worn. I got my spare key and noticed that there were 2 pieces missing out of the current key. I tried the spare and it has worked fine ever since. I am taking my car in on Saturday to get the oil changed but my question is, do I need to have them check the ignition? Do I still need to worry about this?
Thanks for your help!
#2 | |||||
![]() Join Date: Jul 2005
2006 VUE 2.2L
As regards to the regualar and spare keys looking different, on some occasions, keys cut from the factory code will have one cut different than the keys that came with the car (and any that were duplicated in a machine from those original keys). I have found that to be the case on many of my GM cars over the past 10 years. It is usually the closest cut to the head of the key, and has never seemed to make much of a difference. Hope this helps, and in short, it seems to me it was a one time thing based on the parking at the time, and not something broken with the car. Mike
#3 | ||||
Thanks for your Reply Mike. I do appreciate it. In short, the Original Key that I have been using for the past 3 years, will only work if I lock the steering column and turn the steering wheel to a "Hard Right". The Spare Key that also came with the car, works whether I crank the steering wheel or not. The differences that I noticed in the 2 keys, was that 2 "chunks" were missing from the Original Key and had visibly broken off.
I still am unsure whether this is just that the key finally wore down, or if I have a much larger problem with the Ignition cylinder.
#4 | ||||
Sounds like you need a new key.
Mine sticks sometimes as well. But like Mike said, it's related to when the steering column lock has been engaged. I had an '82 Celebrity that I HAD to turn the wheel while turning the key in order to make the electrical connection to get it to start. Pretty weird. That car was a pile of junk though. --Tom ... 2012 Ford Escape V6 Limited AWD 2004 VUE 2.2L 5 speed 1997 Ford Explorer XLT 4x4
#5 | ||||
Try lubricating the lock cylinder.
Even though ignition cylinders are not subjected to the outside elements that the door locks get hit, they still require periodic lubrication.
#6 | ||||
![]() Join Date: Dec 2003
2000 L-Series 3.0L Wagon
Bad Key for my 2003 Vue also. Get the Saturn Parts dude to make you a new key and keep another spare in your wallet. They can determine the keys code from the vehicles VIN. If you lubricate your ignition cylinder use graphite (dry black powder) and not use any kind of oil, especially WD-40. That will gum up your locks quicker than anything.
#7 | ||||
![]() Join Date: Jul 2004
2006 ION-2 Sedan
Before lubricating the lock cylinder, get an air duster for a computer keyboard, and blow out the debris from the cylinder using the nozzle..... then lube it with either grapite or a very thin lubricating oil..... I use air tool oil to lube them at work, lubes beautifully!
... GM, Saturn, and ASE certified Technician. Always glad to try to help, just ask!!! Now own an 06 ION.2 as of 7/2/06 with 2988 and counting (7/28/06) 13131 as of (1/8/07) 24901 as of (7/30/07)
#8 | ||||
Had the same issue with mine recently. I also had the ability to pull the key out after starting the car. They said the lock cylinder was bad and replaced it.
... Dont criticise someone till you walk a mile in their shoes. Then you'll not only be a mile in front of them but you'll also have a new pair of shoes.
#9 | ||||
![]() Join Date: Apr 2006
2003 VUE 2.2L
I had the same problem with my 03 vue. Dealer cut me two new keys and had not had a problem since then.
#10 | ||||
I had the problem when I first bought my Saturn Vue (2002 4-cyl 5-spd).
I got it out, but it happened a few days later. I was watching it carefully after the first time it stuck. I noticed that when I pulled out the switch, there was a clunk, which was the locking mechanism locking. Both times when it locked, I had turned the car off and started to remove the key, but pushed it back it so I could roll up the windows. With that bit of information, I now remove the key differently. When I cut the car off, I remove the key in one smooth quick stroke. It has never hung up again. Mike
| Thread Tools | |
| Display Modes | |
| Can't remove Key from Ignition or turn off engine!! | stickdog | Ion Tech | 12 | 07-18-2010 11:48 AM |
| Ignition Key Stuck, Will NOT Turn or Come Out | Quadragin | S-Series Tech | 5 | 11-29-2009 07:09 PM |
| Key doesn't turn in ignition | 98SaturnSL1 | S-Series General | 5 | 01-27-2009 03:55 PM |
| 1999 SL - Ignition key will not turn AT ALL!!! HELP! | 2002SaturnMan | S-Series Tech | 6 | 08-13-2008 09:48 PM |
| '98 SL2, Hard to turn key in ignition - will not start | C130Flyboy | S-Series Tech | 3 | 03-09-2008 10:39 PM |
