Old 05-01-2006, 11:20 AM   #1
Rick85
Rick85 is on a distinguished road
Default How to remove a door lock cylinder
Hi all,
I have 1998 Saturn SL1, and I have been trying to change the door lock on the driver's side. I removed the inner door panel (plastic), but reaching the lock from inside is a problem. The manual says to remove the pin (although it doesn't say where the pin is and how to do it) I have a feeling I'm doing something wrong, but I don't know what. I can touch the lock, but I can't really see that pin or get good access to it with a tool. Please help!
Thanks,
R.
Add to Rick85's Reputation
Rate the quality of this post and help Rick85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rick85 is offline   Reply With Quote
Old 05-01-2006, 12:15 PM   #2
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: How to remove a door lock cylinder
Put the interior panel back on and remove the EXTERIOR panel (at least that's how it goes on my 92 SC).
Not too sure what the manual is referring to on the "pin". There are pin-like things holding the outer door handle on. The outer door handle needs to be removed before the outer door panel can be removed. Again, this is how it goes on my 92 SC.
Which manual do you have?
--Tom
Not a Saturn.
Add to Tom92SCm's Reputation
Old 05-01-2006, 12:49 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Heres how to remove the outer door panel on a 1991-1995, 1998 is very similar. There is a phillips screw holding the black outer seal strip from the backside at the rear of the door on the top of the panel thats not on the 91-95 in step #4
http://www.differentracing.com/tech_...uterpanel.html
Then unclip the retainer on the back of the cylinder, remove the rod, then unclip the metal clip holding the cylinder to the frame of the door. Done..
Mike
11.809 @ 116.488 mph
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 05-02-2006, 12:44 AM   #4
Rick85
I'll try removing the outer panel.
Thanks a bunch everybody!
How to remove ignition key cylinder with broken key in the cylinder, L-series? dejavu48 L-Series Tech 0 11-15-2008 11:46 AM
How-To: Dismantle Door Lock and Remove Key Fragments (w/pics) d_rock How-To Library 4 10-25-2008 09:16 PM
Debris in door lock cylinder Rivernut S-Series Tech 1 11-28-2007 05:30 PM
Door lock cylinder madpogue S-Series Tech 11 05-01-2007 12:28 PM
Installing a new door lock cylinder Adamgh L-Series Tech 1 09-11-2006 06:44 PM
