what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 02-28-2002, 12:14 PM   #1
TimberWolfe21a
TimberWolfe21a is on a distinguished road
Default VUE -- What's that noise?
Got a new one that I haven't seen mentioned anywhere.
With the engine (V6) running, I was walking around the left rear near the wheel well and heard what I thought was a lot of air leaking from the tire. Well, tire was good, but the sound was still there. So, where's the hissing sound coming from?
Add to TimberWolfe21a's Reputation
Rate the quality of this post and help TimberWolfe21a reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TimberWolfe21a is offline
Old 02-28-2002, 02:35 PM   #2
Galileo
Galileo is on a distinguished road
Galileo's Avatar
2007 AURA XE
Default
My first thought is that it might be the exhaust that you're hearing since the tailpipe is at the left rear of the VUE. Then I remembered that the fuel tank straddles the axle shaft which requires it to have two fuel pumps..... one to pump fuel to the other side of the tank and the second to pump fuel to the engine. I'm not sure how much noise these two pumps make together so you might want to have your retailer take a listen..... hope this is helpful!
Beautiful People First~
Add to Galileo's Reputation
Rate the quality of this post and help Galileo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Galileo is offline
Old 02-28-2002, 02:37 PM   #3
BobL
BobL is on a distinguished road
Default
Gosh,
What would it cost to replace the pair if they die?
Couldn't the engineers do better than that?
Add to BobL's Reputation
Rate the quality of this post and help BobL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BobL is offline
Old 02-28-2002, 07:58 PM   #4
sattech
sattech is on a distinguished road
Default
Only one fuel pump is electric. The other pump is called a venturi type pump. The fuel returning from the fuel filter passes over the venturi pump and acts as a siphon to move the fuel. The venturi pump just pumps the fuel from one side of the tank to the other
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
Old 02-28-2002, 10:02 PM   #5
BobL
Default
Thanks.
Appreciate your explanation. Two electric pumps just sounded a little much for a car.
BobL is offline
03 Vue Wheel Noise and Engnie Noise buffalo Vue General 8 04-15-2005 08:48 PM
Vue Noise DMK's Vue Vue General 1 12-23-2002 09:13 AM
VUE sunroof noise rrbckx Vue General 9 09-25-2002 05:18 PM
VUE Transmission Noise suxcess Vue Tech 6 09-12-2002 10:32 AM
Vue Noise, Anyone Heard This One? DAC94SL2 Vue General 7 05-13-2002 01:20 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
