Old 04-27-2006, 07:27 AM   #1
Lizzy
Lizzy is on a distinguished road
Lizzy's Avatar
2007 ION-2 Quad Coupe
2007 VUE Green Line
Dizzy HELP!!! Tach / Engine Problems!!! Still need someone to help!!!
Okay, going to try to make this short. My car has been acting crazy for about a month now. I go to stop at an intersection or something, and my car will pop up 500+ rpm and try to take off (you literally feel the car move forward a foot or two). No matter how hard you are on your brakes, it still moves. It was only doing this when stopped / stopping, but now it is doing it while actually driving. My car has been at the dealer now for 3 days and they can't find anything wrong. No codes. No visual problems.
There is two problems known to the car at the moment. My belt tensioner is out of alignment and needs to be replace (have the part in my trunk to do tomorrow) and my oil pan is leaking (have the sealant to fix problem for that also). Everyone says that the belt needing changing and belt tensioner has nothing to do with the pushing forward that my car is doing. Does it??? If not, anyone know what is wrong with my car??? I am scared I am going to hit someone!!!
Add to Lizzy's Reputation
Rate the quality of this post and help Lizzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lizzy is offline   Reply With Quote
Old 04-27-2006, 08:19 AM   #2
agoldslsaturn
agoldslsaturn is on a distinguished road
agoldslsaturn's Avatar
Default Re: HELP!!! Tach / Engine Problems!!! Still need someone to help!!!
are you running your a/c? (you are by me so most likely yes, lol). If so the compressor takes a lot of energy and that could be the reason, my car does same so i shut a/c off at lights. Other than that, well i dont know?
Cause when push comes to shove
You taste what you're made of
You might bend, till you break
Cause its all you can take
Add to agoldslsaturn's Reputation
Rate the quality of this post and help agoldslsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
agoldslsaturn is offline   Reply With Quote
Old 04-27-2006, 08:26 AM   #3
Lizzy
Lizzy's Avatar
2007 VUE Green Line
No, don't run the A/C. I smoke, so my windows are always down, so I never really use it, at least not till August or so, even then, not really.
Old 04-27-2006, 08:29 AM   #4
agoldslsaturn
Hmmm, I dunno then, that was the extent of my knowledge there, unless maybe you need to clean some things up, change an ects, clean an egr valve, change some spark plugs and possible wires.(Oh and this probably has no relation but check your motor mount also, I notice mines not as bad anymore when I use the a/c...)
Someone will help you out though Good people on this board!
Old 04-27-2006, 09:33 AM   #5
thawk
thawk is on a distinguished road
not too technical, but check around your pedals for something that may have rolled up there or your floor mats getting out of control.
Add to thawk's Reputation
Rate the quality of this post and help thawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thawk is offline   Reply With Quote
Old 04-27-2006, 05:42 PM   #6
zosoppp
zosoppp is on a distinguished road
zosoppp's Avatar
1994 SC2
Sounds like a vacuum leak somewhere, or perhaps the EGR is getting stuck open when it shouldn't. A vacuum leak would allow more air past the throttle, and the car would behave as though you hit the gas pedal. More RPM and more torque against your brakes.
The belt tensioner will only make your accessories work bad or squeak. The accessories are the alternator, water pump, PS if you have it, and AC which you say you don't use. if the belt is slipping you will hear it, that nice squeal from the right side (passenger side) of the engine compartment. While it's squealing you might notice hard steering, dimmer lights, and if it squeals for a while it might affect the engine temperature. None of those things (with the exception of really bad drops in voltage) should have any effect on your idle speed.
zosoppp
John Mayer
ozzyoz <at> optonline <dot> net
94 SC2
Add to zosoppp's Reputation
Rate the quality of this post and help zosoppp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zosoppp is offline   Reply With Quote
Old 04-27-2006, 05:56 PM   #7
Kevin94SL
Kevin94SL is on a distinguished road
Kevin94SL's Avatar
2006 ION-3 Sedan
Check for vacuum leak. This would cause the revs to increase giving you the pull at lights. I've driven with a vacuum leak and experienced teh same symptoms.
Kevin
Add to Kevin94SL's Reputation
Rate the quality of this post and help Kevin94SL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kevin94SL is offline   Reply With Quote
Old 04-28-2006, 03:20 PM   #8
Lizzy
Lizzy's Avatar
2007 VUE Green Line
Happy Re: HELP!!! Tach / Engine Problems!!! Still need someone to help!!!
Thanks everyone for your help I picked it up after 4 days at the dealer here, and they never found any leaks or any codes, nothing and of course now it is driving fine I changed my belt last night, as well as my air filter (which really needed it ) All noises have stopped, and it is fine at the stops / lights. I just think it gets *****y (guess that's why cars are referenced as "her" and "she" ) Anyways, I will keep an eye out, and I now have a manual so I can figure out what a throttle is so next time it happens, I can maybe fix it without having to take it in for another 4 days!
p.s. I don't know about your guy's experiance with Saturn Dealerships, but ours here is great. 4 days of diagnostics, and they fixed my brake calipers, NO CHARGE!!! Thanks Saturn!!!
Old 04-28-2006, 03:32 PM   #9
Uzzy
Uzzy's Avatar
2002 SC1
Well good luck with it.
Free? I get free work, but it's in my friend's garage (well it usually coasts me a lunch or two, but he's a Saturn Tech) Free work at the dealer tho, I don't even get that (well now I do WARRANTY! ) and they love me their, I'm always there. Free work, geeze, Saturn of Windsor is gonna hear about this one.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 04-28-2006, 03:45 PM   #10
agoldslsaturn
there <ducks>
lizzy what dealership? I have been going to one near my work and they like to screw me big time....Im in palm beach which is not far from you (city not county well county too but i live in palm beach , florida xxxxx LOL) and id like a nice dealership.
Glad you got everything fixed! and my car is same as yours also. man my car has like two twins...
Old 05-02-2006, 09:15 PM   #11
UForgotten
UForgotten is on a distinguished road
UForgotten's Avatar
2007 AURA XR
This sounds like classic ECTS (Engine Coolant Temperature Sensor) failure. Searching for ECTS will show tons of threads like yours. It's intermittent, and when it does it, it's totally out of the blue. If it went out like mine did, the engine revs up and your temperature gauge will go up and down much faster (as in makes a split-second jump instead of a gradual slide). If you're stopped, the revving is enough to make the car lurch forward, and you have to apply the brakes much harder.
It revs because the sensor makes the computer think the engine is too cold (note the temperature gauge will drop very low from very high) so it runs the engine harder to get the temperature back up (when in reality, it's already hot).
Very easy fix, the dealer can do it for $150 or you can do it yourself for $15-30
Add to UForgotten's Reputation
Rate the quality of this post and help UForgotten reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
UForgotten is offline   Reply With Quote
Tach pulsating after shutting engine off klmiller37 S-Series Tech 1 06-24-2008 08:37 AM
No Tach, speedo or engine temp hammand S-Series Tech 4 09-05-2006 06:37 PM
Tach Problems Paul H. S-Series Tech 2 11-09-2005 12:15 AM
Stock Tach Problems Paul H. S-Series General 0 11-07-2005 07:35 PM
Tach problems, and intermittent SES iced_theater Miscellaneous Tech 3 02-28-2004 01:46 AM
