Old 04-21-2006, 05:53 PM   #1
freedomflame200
freedomflame200 is on a distinguished road
1993 SC1
Default tire pressure?
i got the fuzions hri's and the shop that installed them put 30 psi in front and 26 in the back. the max psi is 44 .... i dont know that much about tires and such but is that proper for my car/tires and the way i drive? i deliver pizza mostly on paved potholey backroads at 40-60 mph (cant have late pizzas)
94 saturn sl1 manual 117,000 miles RIP
93 saturn sc1 auto 168,000 miles bought 02-23-06
97 saturn sc2 manual 159,000 miles bought 01-22-05
Add to freedomflame200's Reputation
Rate the quality of this post and help freedomflame200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
freedomflame200 is offline   Reply With Quote
Old 04-21-2006, 06:46 PM   #2
Titanium48
Titanium48 is on a distinguished road
Default Re: tire pressure?
Those are the standard inflation pressures for Saturn S-series cars. You will get better handling and fuel economy at somewhat higher pressures at the expense of a bumpier ride. Don't go all the way to 44 psi though, that is too high. I think optimum cornering grip occurs somewhere in the mid-30s.
Add to Titanium48's Reputation
Rate the quality of this post and help Titanium48 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Titanium48 is offline   Reply With Quote
Old 04-21-2006, 07:08 PM   #3
ym42
ym42 is on a distinguished road
That is the right pressure. More pressure will cause your wheels to lock up more easily when you hit the brakes in emergency, especially if you do not have ABS. Also, if you have bigger tires with higher load capacity ( in case you put 205 size ), you can get away with even less air pressure than the manual says, not that you have to.
Add to ym42's Reputation
Rate the quality of this post and help ym42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ym42 is offline   Reply With Quote
Old 04-21-2006, 07:45 PM   #4
99blacktop
99blacktop is on a distinguished road
99blacktop's Avatar
I have always run my SC2 (and prior to that my SL2) at 30 front, 26 rear as indicated on the sticker. The car handles great and I have exceeded 40MPG on the highway, so it isn't hurting my gas mileage any.
Running them higher might give you better mileage, but it will reduce the contact patch between the tire and the road, which won't increase your handling, not to mention the fact that your tires will wear faster in the center than the sides. Less tire touching the road means less traction.
My Saturn history:
1993 SL2 100,406 miles ('94-'98)
1999 SC2 118,537 miles ('98-'12)
2005 VUE 25,705 miles ('05-'09)
2008 Astra 27,014 miles ('09-'12)
Add to 99blacktop's Reputation
Rate the quality of this post and help 99blacktop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99blacktop is offline   Reply With Quote
Old 04-21-2006, 09:06 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
as long as they have a load index of 87 or more then use 30 psi front and 26 psi rear. if the load index is less than 87 then you need to put more air in them. also if you are autocrossing on them you would need more air for sure.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 04-22-2006, 04:41 AM   #6
BullyCanadian
BullyCanadian has a spectacular aura aboutBullyCanadian has a spectacular aura about
2003 VUE 2.2L
is that the standard tire pressures for all saturns ? I never really checked cause after (a long time ago) I had my tires installed from a shop they said to keep it at 35psi all around, if its supposed to be 30 front, 26 rear that what I should put mine at. My car slides around VERY easily in the rain, maybe this will remedy it
1992 Saturn SL2 has been sold as of June 2007...
2003 4.6L v8 Mustang 5speed Sold as of March 2014...
Daily Driver ... 2003 i4 5speed Vue
Mileage Currently @ (09/30/2014) 268,000 km (166,500 mi)
Add to BullyCanadian's Reputation
Rate the quality of this post and help BullyCanadian reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BullyCanadian is offline   Reply With Quote
Old 04-22-2006, 06:26 AM   #7
99blacktop
99blacktop's Avatar
I think all S-series were designated 30f/26r, but I could be wrong. There should be a sticker either in the trunk or inside the driver side door.
My Saturn history:
Old 04-22-2006, 02:13 PM   #8
JADEDSL2
JADEDSL2 will become famous soon enough
JADEDSL2's Avatar
Location: Sullivan, Missouri, USA, North America, Northern West Hemisphere, Earth, Solar System, Left Galactic Arm, Milky Way Galaxy, Local Galactic Cluster, Universe
1993 SL2
1991 SL2
Depends on the tire. High performance anything holds best, lasts longest, and feels "tightest" at around 39-40, if max is 44psi. My Falken's max was 52psi, and I kept them at 51. Ran NICE. Of course, I like to feel any tiny pebble I drive over. Some don't.
"1G8ZJ5472MZ134321"-my Jaded, I will never forget.
"1G8ZF5594PZ249184"-Trinity, for three are now one.
Add to JADEDSL2's Reputation
Rate the quality of this post and help JADEDSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JADEDSL2 is offline   Reply With Quote
Old 04-22-2006, 02:25 PM   #9
eRic 02sc2
eRic 02sc2's Avatar
that's the standard tire pressure for S-Series Saturns. Look at the sticker on the door. forget what the shop told you unless they have "Saturn of" on the front of the building 35 psi in an S-Series makes for a stiffer bumpier ride. it will probably slide more in the rain now...
eRic 02sc2
Old 08-04-2015, 09:39 AM   #10
Bdpennington
Bdpennington is on a distinguished road
2000 SL2
I once heard that the factory tires only had a max psi of 35.
Add to Bdpennington's Reputation
Rate the quality of this post and help Bdpennington reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bdpennington is offline   Reply With Quote
Old 08-04-2015, 12:14 PM   #11
bumpdraft
bumpdraft's Avatar
1998 SW2
I have my second set (of O.E. Firehawks) on spare rims they are 1190 pounds at 35 psi max.
The tires I have now are 1135 pounds max. They seem best at 34 psi front.
Competition Clutch 10Lb. Flywheel. 13 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 08-04-2015, 06:23 PM   #12
saturnsctwo
you obey the sticker which states that on the door jamb. the tires are used on a lot of other cars as well, but all cars use their own specific tire pressure taylored to their specific weight & handling...
Old 08-04-2015, 07:50 PM   #13
NWSaturn247
NWSaturn247 is on a distinguished road
NWSaturn247's Avatar
1993 SL2
I currently have Sumic GTA 195/60-15 installed with 41.5k miles with lots of tread left running about 40psi all around.
1993 SL2 AT - 184k miles
running Pennzoil HM 10w-40 + MMO & D3422
TCW3 dosed fuel
Goldie: a dame to kill for...watch out squirrels!
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 08-04-2015, 08:35 PM   #14
Bildo Baggins
Bildo Baggins is a jewel in the roughBildo Baggins is a jewel in the roughBildo Baggins is a jewel in the rough
This is very interesting. I have Toyo Extensa at 33-35 all around. Never even thought about going other than tire recommendation.
This is where they were after shop mounted them.
Bill from Extreme Southern North Carolina
'97 Satty SL2
280Kish miles
Add to Bildo Baggins's Reputation
Rate the quality of this post and help Bildo Baggins reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bildo Baggins is offline   Reply With Quote
Old 08-04-2015, 09:00 PM   #15
saturnsctwo
not all tire shops employ or lots of other shops for that matter employ certified mechanics as they command big bucks. a lot of them do what walmart does, employ knuckleheads who don't even know how to properly tighten an oil drain valve plug as they love to strip the threads. tire pressure recommendation is always on the car's tire placard inside of the door jamb. those who over inflate their tires over the recommended placard just cause a rough ride & uneven tire wear... to each his own though...
Old 08-04-2015, 09:16 PM   #16
Look on the side wall and note the max cold pressure and the max load rating. Now from that info and using an inverse exponential decay curve estimate the pressure for the individual wheel load. 750lb each front wheel and 500lb each rear wheel with no passenger and luggage load in the car and increase pressure proportionally for the load as it is on each of the tires evenly. That means that a total additional load relatively evenly distributed of 400lb total adds 100 lb to each wheel load.
http://www.revisemri.com/tools/timeconst/1_exp_x400
1.0 on the graph is max pressure and 2000 to 0 represents the wheel load with 2000 being the max rated load. There is math for this but fitting it to the curve will be easier and works well to find the starting point.
Do not load the car to exceed the max tire load at max cold max pressure.
Old 08-04-2015, 09:33 PM   #17
jhonky
jhonky is on a distinguished road
I do about 34-35 front and 30 rear
98 SL2
5th gear swap- .643 gear
245,000 miles
215/45 17"
I burn about a quart about every 1500 miles.
If it ain't broke, fix it some more.
Add to jhonky's Reputation
Rate the quality of this post and help jhonky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhonky is offline   Reply With Quote
Old 08-04-2015, 09:39 PM   #18
Bildo Baggins
That is some splodey head stuff right there. I'll probably drop my back down a few because it does feel a bit harsh.
'97 Satty SL2
280Kish miles
Old 08-04-2015, 09:43 PM   #19
Generally speaking a 4-5 psi difference front to back and the fronts inflated to the point it does not feel squishy when you turn corners works.
Old 08-04-2015, 09:50 PM   #20
Bildo Baggins
Most of my automotive experience centered around big blocks and big tube headers melting pavement until the Saturn. Pressure in the Mickey Thompson cheater slicks and pizza cutter fronts were an afterthought and clorox made smokiness.
'97 Satty SL2
280Kish miles
tire pressure ? saturn_94 S-Series Tech 5 04-23-2007 07:50 PM
Tire Pressure: What should it be at? TIMSPEED S-Series Tech 16 09-09-2002 02:13 PM
Tire Pressure sfc47 Mods and Performance 12 04-11-2002 11:11 AM
Tire Pressure? cracker455 S-Series Tech 8 03-11-2001 06:01 PM
Best Tire Pressure? SpeedPlayer 97sl2 General Saturn Discussion 4 08-04-2000 09:12 PM
