what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 02-22-2002, 09:05 AM   #1
Mark G
Mark G is on a distinguished road
Default What is the cartridge oil filter on the V6 Vue?
I received a brochure on the VUE yesterday. In it, it was talking about the new features that make it unique. It said that the VUE does not use regular spin on type oil filters, instead, it uses a cartridge filter that is supposed to be easier to replace. Does anyone know what this cartridge filter is?
Add to Mark G's Reputation
Rate the quality of this post and help Mark G reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark G is offline
Old 02-22-2002, 09:39 AM   #2
bigbird
bigbird is on a distinguished road
Default
The cartridge oil filter is just a pleated filter element without a metal canister to house it.In most cars this pleated filter is contained in a metal housing which screws onto the engine block.On the 2.2L and 3L engines in Saturns, there is a plastic housing permanently attached to the engine block which holds this replaceable pleated filter. So, to change the oil filter in these engines, one just simply removes a large plastic nut on top of the plastic housing, pulls out the old cartridge,drops in a new cartridge, replaces the nut, and refills the engine oil.
The strange thing is that the replaceable pleated cartridge is more expensive than typical metal housed oil filters.One would think it should be cheaper, as the metal housing is not required.
Add to bigbird's Reputation
Rate the quality of this post and help bigbird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird is offline
Old 02-22-2002, 10:08 AM   #3
Harry
Harry is on a distinguished road
Harry's Avatar
2001 L-Series 2.2L Wagon
Arrow
Economy of scale. Right now there aren't a lot of metal-less filter cars around. Once the sales of ECOTECH engines go up, the price should hopefully go down.
Add to Harry's Reputation
Rate the quality of this post and help Harry reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Harry is offline
Old 02-22-2002, 12:34 PM   #4
ricksLS1
ricksLS1 is on a distinguished road
ricksLS1's Avatar
Default
For the L 4 cly at the dealer (Dealer prices vary) $4.99; for the STP 9018 (FOR THE 4 ONLY) at Autozone $3.50. That's not bad. The STP is made in Korea.
Add to ricksLS1's Reputation
Rate the quality of this post and help ricksLS1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ricksLS1 is offline
Old 02-23-2002, 05:15 PM   #5
Qlara
Qlara's Avatar
Idea
Corrections though: Both Ecotec 4 and V6 are using cartridge filters, but they're not in the same location. Ecotec is located in the top part of the engine (Best location ever!) and it has a plastic cap cover to house it. The V6 filter is located horizotally in the front (next to the front exhaust manifolds.....) and it's using a metal cap cover though.
Both filters are very easy to replace. Ecotec is a no brainer as it's on top, but the V6 you'll need to crawl under and drain out the residual oil carefully before you can take the used one out.
Add to Qlara's Reputation
Qlara is offline
Where is the oil filter on the 2.2 Vue? allsaturn Vue General 9 08-20-2006 11:59 PM
Oil filter on VUE?? AtlantaMike Vue General 15 11-03-2004 12:52 AM
2.2 Oil Filter on VUE ricksLS1 Vue Tech 7 12-23-2002 09:15 AM
Ecotech Cartridge Oil Filter? Maritime Storm Ion Tech 17 10-10-2002 11:32 PM
LS Oil Filter or Rather Oil Cartridge HobokenKid L-Series Tech 4 04-19-2000 09:58 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
