Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky Red Line
Old 04-08-2006, 01:01 AM   #1
Aeain
Aeain is on a distinguished road
Aeain's Avatar
2004 ION Red Line
Default Something about the SKY Red Line.
Why did GM decide on an Air-to-Air Intercooler when the Air-to-Water intercooler(From ION Red Line) is more efficient?
Andrew
2004 ION Red Line
Add to Aeain's Reputation
Rate the quality of this post and help Aeain reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Aeain is offline   Reply With Quote
Old 04-08-2006, 01:42 PM   #2
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
Default Re: Something about the SKY Red Line.
Probably coolant routing. Everything under the hood is cramped, so I guess air->air was the only (or most economical) choice. Also, maybe the front air dam allows more airflow on the SKY - who knows!
Toyota: Moving Forward... off a cliff at a high rate of speed.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline   Reply With Quote
Old 04-09-2006, 05:33 AM   #3
SKYGAZR
SKYGAZR is on a distinguished road
SKYGAZR's Avatar
In looking at their configuation and the increased size of the from air dam & side inlets... take a look at the pic...
Add to SKYGAZR's Reputation
Rate the quality of this post and help SKYGAZR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SKYGAZR is offline   Reply With Quote
Old 04-11-2006, 08:06 AM   #4
Red_Line Ion
Red_Line Ion is on a distinguished road
Red_Line Ion's Avatar
who told you air to water is more efficient?Air to air is more efficient, but air to water is more compact!
Whenever you can have a large front mount air to air it will cool the charge a heck of a lot faster than water that is packed in somewhere...
ambient temp will aways be lower than the water due to the water heat soaking and such, why do most if not all HP turbo cars use air to air if water is more efficient?
Add to Red_Line Ion's Reputation
Rate the quality of this post and help Red_Line Ion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Red_Line Ion is offline   Reply With Quote
Old 04-11-2006, 08:07 AM   #5
Red_Line Ion
plus air to water adds WEIGHT! Pumps, fluid, heat exchanger etc
Old 04-11-2006, 08:54 AM   #6
Ben98gs
Ben98gs is on a distinguished road
2001 SC1
Somewhat true... BUT, the air to water is more efficient for "short" performance. Fill a air to water IC setup with ice water and it will be more efficient then an air to air... But for what 10 min??? Good for the drag strip, but not good for road racing. An air to air on the other hand is better for longer more "enduring" performance. So on a daily car that is really made for the road course rather than the drag strip the air to air is the obvious good choice.
Add to Ben98gs's Reputation
Rate the quality of this post and help Ben98gs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ben98gs is offline   Reply With Quote
Old 04-11-2006, 09:10 AM   #7
Red_Line Ion
correct, but we are talking production not drag racing specific...but yes fill a air to water with ice water and bam!
Unfortunatey ours have coolant which screws that idea, lol
Altho I am working on putting a cold can just for that purpose in the water ic system...
Old 04-11-2006, 09:44 PM   #8
Aeain
Aeain's Avatar
2004 ION Red Line
The ION Red Line air-to-water intercooler is 80% efficient the most efficient most Air-To-Air setups is %50-60 efficient.
Andrew
2004 ION Red Line
Old 04-12-2006, 07:45 AM   #9
Red_Line Ion
the limits of the rl intercooler are very low without easily upgrading the system, all in all most if not all still prefer the air/air.
"Each type of intercooler has its strength and weakness. Air-to-air units tend to require longer ducting to route the air from the turbo through the intercooler then back to the engine; this extra tubing might increase lag slightly on some engines and may also present interesting packaging challenges. Air-to-water units, however, can have significantly shorter intake plumbing; the intercooler can be placed in hot underhood areas where no airflow is present since the liquid coolant circulates to its radiator. This allows for simpler installation but at an expense of reduced cooling efficiency. Note that both kinds cool better when air is flowing through the intercooler (air-to-air) or the radiator (air-to-water); both kinds can benefit from the installation of a fan for low-speed operation. "
"air-to-water intercoolers are used either for convenience--to eliminate the possible ducting nightmare of the intake--or for drag-only vehicles where a "one shot" setup uses ice to actually drop charge air temps below ambient... for a very short while. I think it is telling that a number of street cars which featured air-to-water intercoolers from the factory--such as the GMC Syclone and Typhoon--are almost always converted to air-to-air units when upping performance is the goal. Check out an issue of Turbo magazine; you'll see these cars with huge air-to-air units mounted below the front bumber (or else behind the grill and in front of the radiator). There's a message here somewhere.... "
sorry Aeain, these are pretty much the accepted facts.....
Old 04-12-2006, 09:07 AM   #10
Ben98gs
2001 SC1
Very good post, and oh so true... If air to water were SOOO much better then why do all of the high horsepower turboed cars run air to air (look at the Supra's, Skylines, etc.).
Old 04-12-2006, 04:12 PM   #11
Aeain
Aeain's Avatar
2004 ION Red Line
Because most car companies don't spend the money for that cause they are cheap. And Most people don't even know what an Air-to-Water intercooler is.
Though, 80% Efficiency is greater then what you'd see with a Air-To-Air setup. The Air-To-Water intercooler is not limited. It'll handle 350hp easily before you would really want to upgrade then.Water conducts about 9 times the amount of heat as air. Simple chemistry tells us that an Air-To-Water is more efficient and would be better than an Air-to-Air unit.
The Lightning, Cobra, and Ford GT all use Air-To-Water intercoolers and the Ford GT has 500 base horsepower. Now superchargers put out less heat but, it applys to turbo cars.
The SKY Red Line would just need a higher flow pump (ION Red Line's is rated at 7 Gallons Per Minute), more Laminova coils and a larger exchanger. It'd be fairly low cost since they could use a smaller car radiator an existing Intake Manifold from an ION Red Line and run a brand new Coolant Pump
Check out the site for the Laminova Coils that are used in the ION Red Line.
http://www.opcon.se/index.asp?sPage=1&langID=2&cID=15
Andrew
2004 ION Red Line
Old 04-12-2006, 04:25 PM   #12
SaturnPlanet
SaturnPlanet is on a distinguished road
SaturnPlanet's Avatar
you sound like an expert....how many car companies do you run?
Add to SaturnPlanet's Reputation
Rate the quality of this post and help SaturnPlanet reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnPlanet is offline   Reply With Quote
Old 04-12-2006, 06:04 PM   #13
Aeain
Aeain's Avatar
2004 ION Red Line
So since I'm not an expert it gives you the right to judge my opinions?
Andrew
2004 ION Red Line
Old 04-12-2006, 06:53 PM   #14
SaturnPlanet
of course, you have the right ot your own opinion, however, one can judge the validity of your claims and this will affect the validity of your overall argument.
hope that helps.
Old 04-12-2006, 07:19 PM   #15
Red_Line Ion
Love Laminova's ECHOtech research....
Aeain, efficiency and practical use are 2 different things, in the applications these are for an air to air is preferable pure and simple.
ck your Ic fluid temp while you are driving....not too cool....
Sky Red Line is Fun, Pretty Charlie Sky Red Line 1 07-07-2009 09:13 AM
2009 Saturn Sky Red Line Ruby Red Limited Edition Charlie Sky Red Line 2 04-19-2009 09:01 AM
More SKY Red Line Pics Charlie Sky Red Line 0 09-29-2006 10:56 PM
Barry's Sky Red Line On The Way Barry Sky Red Line 0 09-19-2006 09:02 PM
SKY Red Line FOR SALE! Spazie Sky Red Line 15 09-15-2006 11:01 AM
