Old 04-04-2006, 09:24 PM   #1
gronz
gronz is on a distinguished road
gronz's Avatar
Default back up lights
i have a 99 sl2 and the back up lights no longer turn on when in reverse. i have a 5-speed if that makes any difference. is there a sensor by the stick?
Add to gronz's Reputation
Rate the quality of this post and help gronz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gronz is offline   Reply With Quote
Old 04-04-2006, 10:37 PM   #2
Default Re: back up lights
Reverse switch is most likely bad. It is on top of the trans. Two wire connector.
Add to ssicarman's Reputation
Old 04-05-2006, 04:44 AM   #3
jjsk8r85
jjsk8r85 is on a distinguished road
jjsk8r85's Avatar
1992 SC
something's wrong with mine too. I took the sensor out, and the reverse lights work if I activate the sensor by hand (push the lil ball in) but when it's in the transmission, it just wont work for some reason.
92 SC 5-speed 239k miles
Add to jjsk8r85's Reputation
Rate the quality of this post and help jjsk8r85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjsk8r85 is offline   Reply With Quote
Old 04-05-2006, 10:44 AM   #4
Have you looked into the tranny (thru the hole where you remove the switch) while someone puts the shifter in and out of reverse? That might tell you something.
Add to madpogue's Reputation
Old 04-05-2006, 12:20 PM   #5
jjsk8r85
jjsk8r85's Avatar
1992 SC
no, I haven't, because anything that is wrong inside there is probably going to be bad :P
Old 04-05-2006, 09:12 PM   #6
Replace the reverse switch. You are able to push the ball in further than the lever in the trans.
Back up lights chillin05VUE Vue Tech 2 09-22-2009 09:42 PM
Corner lights are back!!!! redlineit Vue Red Line 2 12-10-2008 03:11 PM
Back-up lights stick86 Ion Tech 4 07-01-2007 05:05 PM
Back-up lights (sometimes) Mr Mike S-Series Tech 4 08-20-2004 07:57 AM
back up lights beasjd S-Series Tech 3 07-11-2001 02:57 PM
