Old 04-01-2006, 09:34 PM   #1
hawaiipens
hawaiipens is on a distinguished road
Default engine knocks at startup
My engine knocks at startup for about 20 seconds and then goes away.. Is that a sign that my engine is going??? Or what can I do to fix this problem...?
Add to hawaiipens's Reputation
Rate the quality of this post and help hawaiipens reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hawaiipens is offline   Reply With Quote
Old 05-20-2007, 01:30 PM   #2
WrenchForce
WrenchForce is on a distinguished road
1995 SW2
Default Re: engine knocks at startup
You need a new ERG valve i had the same problem except mine would die.
Add to WrenchForce's Reputation
Rate the quality of this post and help WrenchForce reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WrenchForce is offline   Reply With Quote
Old 05-20-2007, 08:55 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
Did you check your engine oil level?
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 05-26-2007, 03:15 AM   #4
djmjay
djmjay is on a distinguished road
1991 SC2
1991
My 1991 SC2 has 256,000 miles on it and does the same thing. Keep the oil changed and it solves the problem.
Add to djmjay's Reputation
Rate the quality of this post and help djmjay reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djmjay is offline   Reply With Quote
Old 03-24-2009, 09:23 AM   #5
diplo
diplo is on a distinguished road
diplo's Avatar
my mini has a similar problem. It is probably a lack of oil as stated above.
Add to diplo's Reputation
Rate the quality of this post and help diplo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
diplo is offline   Reply With Quote
Engine ticking on startup almies S-Series Tech 9 05-13-2008 05:31 PM
Engine Startup After Extended Absence 1FUNSUV Vue General 3 04-22-2008 09:02 PM
Engine surges upon startup and idle?? toddo S-Series Tech 2 11-25-2006 08:11 PM
97 SL1 engine startup problem PazzSL1 S-Series General 5 06-13-2004 09:15 AM
rattle from engine compartment at startup... LI 350 S-Series Tech 8 06-02-2000 09:43 PM
