Old 03-29-2006, 04:06 AM   #1
Jetfixer10
Jetfixer10 is on a distinguished road
Attention 98 sl2 - turn signals not working / hazards working normal
I have a 98 Saturn sl2. All 4 turn signals aren't working. Both turn signal indicator lights in the instrument panel don't work as well.
I checked all 4 turn signal light bulbs and they were good. All fuses in the engine compartment were also good. When the hazard switch is pressed all 4 turn signal bulbs flash and both turn signal indicator lights in the instrument panel flash.
If the hazards work and the turn signals don't, could the combination flasher unit (relay) be bad? Also could it be a bad turn signal stalk switch? Another thing I noticed was the the hazard switch sticks and is hard to turn on and off.
Thanks for the help everyone.
Add to Jetfixer10's Reputation
Rate the quality of this post and help Jetfixer10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jetfixer10 is offline   Reply With Quote
Old 03-29-2006, 10:03 AM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: 98 sl2 - turn signals not working / hazards working normal
I'd start with the flasher module. Is the 98 a 3 or 4 pin module? I may have to check my 98 FSM's when I get home.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 03-29-2006, 10:10 AM   #3
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
Don't be baffled that the hazards work and the turn signals don't. They are completly different circuits. Start with checking the turn signal flasher unit.
03 GMC Envoy XL
99 Isuzu Rodeo V-6, 4WD, Rebuilt 3.2L with 3.5L internals
63 Mercury Comet Convertible
Add to Cat Fuzz's Reputation
Rate the quality of this post and help Cat Fuzz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cat Fuzz is offline   Reply With Quote
Old 03-29-2006, 10:47 AM   #4
Jetfixer10
Mike, The 98 has a 3 pin combination flasher unit.
Old 03-29-2006, 09:55 PM   #5
Jetfixer10
I just installed a new combination flasher unit. The turn signals still don't operate. The flasher I changed was located behind a panel inboard of the driver floor pan area. Basically below the center console/shifter. I believe the flasher controls both the hazard lights and the turn signals. What next?
Old 03-29-2006, 10:10 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
I'd double check the two fuses. IGN4 30amp maxi fuse in the underhood fuse box or the 7.5amp mini fuse in the interior fuse box.
Mike
-2000 Saturn SC2
Old 03-29-2006, 11:29 PM   #7
wolfman
wolfman's Avatar
Bet he missed that one....
Add to wolfman's Reputation
Old 03-30-2006, 01:22 AM   #8
Jetfixer10
Mike,
I found the interior fuse panel and sure enough there was a blow 10amp mini fuse marked turn sgnl. Changed the fuse and everything works fine. In the trunk I found 2 bare turn signal wires which had been cut and then twisted together with no insulation. I'm sure one of them had just shorted out. My friend just got the car loaned to her 2 days ago. It was my first time working on a Saturn so I didn't know about the fuse panel on the passenger side of the center console. Also the fact that the glove box was missing the owners manual didn't help matters either.
Thanks again
Old 03-30-2006, 10:09 AM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
Cool. At least it was something simple.
Mike
-2000 Saturn SC2
Old 10-30-2016, 04:30 PM   #10
strnlvr
strnlvr is just really nicestrnlvr is just really nicestrnlvr is just really nicestrnlvr is just really nice
2000 SC1
Hey guys i have a 2000 Saturn SC1 and just last night while driving on a country side road with the headlights on, all of a sudden my indicators stopped working (i noticed when i wanted to make a right turn.
the indicators do NOT flash in any gear
the indicators do NOT flash when Hazard button is set to on position
none of the bulbs are bad (all bulbs cannot go bad at the same time, would be such a coincidence if they did...)
anyone help please?
Add to strnlvr's Reputation
Rate the quality of this post and help strnlvr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
strnlvr is offline   Reply With Quote
Old 10-31-2016, 11:55 AM   #11
toggenburg
toggenburg's Avatar
Location: Beautiful Blue Ridge Mountains of Bedford, Virginia
Since you revived a 10 year old post, have you done what the OP was asked to check for? Fuses?
Same advice still applied today.
Old 10-31-2016, 12:04 PM   #12
strnlvr
2000 SC1
yes sir i checked the small 10amp fuses and they all seem to be just fine...
anything else?
Old 10-31-2016, 01:39 PM   #13
strnlvr
2000 SC1
i pulled out every single fuse from under the hood and near the gear box (on the front passenger side). Nothing seems to be blown or out-of-whack!
i watched RichPin's video and there he talks about the Flasher Module for his Saturn. but i had a different car, i have a 2000 Saturn SC1 but has the same flasher module though. could that be the problem? If so, how can I tell if that relay is NOT working? any easy way?
please see the image of that relay/flasher combination/module i took the picture of from my 2000 Saturn SC1 car.
File Type: jpg 9442893 COMBINATION FLASHER OMRON DUALTEC 24 LAMP.jpg (87.1 KB, 19 views)
Old 10-31-2016, 02:49 PM   #14
1-Is the 10a turn signal fuse blown?
2-Can you turn on night time driving lights (not headlights)? A right forward lamp splice pack grounds marker and front turn signals. A rear ground splice pack grounds rear lights.
3-Yes, the flasher module controls turn signals and for way hazards lights. Replace it if in doubt.
Old 10-31-2016, 03:10 PM   #15
strnlvr
2000 SC1
1-is the 10a turn signal fuse blown?
no
2-can you turn on night time driving lights (not headlights)? A right forward lamp splice pack grounds marker and front turn signals. A rear ground splice pack grounds rear lights.
yes
3-yes, the flasher module controls turn signals and for way hazards lights. Replace it if in doubt.
OKAY
Turn signals not working. Hazards work cwills2 L-Series Tech 17 03-20-2016 07:37 PM
91 sl2 turn signals hazard not working speed racer S-Series Tech 0 03-19-2009 03:59 PM
Turn signals are not working??? Daredevil6534 S-Series General 1 01-26-2009 10:01 PM
94 SL2, hazards disable turn signals My Range S-Series General 3 11-21-2005 05:53 PM
turn signals and hazards just stopped working renadena S-Series General 6 05-14-2005 03:14 PM
