Old 03-26-2006, 10:51 AM   #1
dbruce
dbruce is on a distinguished road
Default 2000 SL2 with a P0410 code
Just got a code on my SL2. P0400 which is a the secondary air something or other pump. I found the pump at the front of the engine and checked all the connection etc and everything looked fine.
How do I tell the pump is working? Does it make noise when the key is first turned before start?
I also read somewhere that the metal tube that connects to the exhaust manifold can get clogged.....though I can't find the post again. How hard it is to remove the pump?
Anything else you can think of to get rid of the code.
Thanx in advance.
Add to dbruce's Reputation
Rate the quality of this post and help dbruce reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbruce is offline   Reply With Quote
Old 03-26-2006, 01:44 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: 2000 SL2 with a P0410 code
it'll come on after you start the car if it's cold out, below freezing ish. You can feel the little thing vibrate if its whine gets mixed in the din under the hood.
A friendly dealer can also reflash your computer to a 99 model year with 49 state emissions.
Add to eljefino's Reputation
Old 03-26-2006, 03:03 PM   #3
saturnhacker
saturnhacker is on a distinguished road
the first thing is the check fuse in underhood junction block near battery. i think its a large 30 amp fuse, not sure, if you can unplug connector at the air pump and attach a test light it should illuminate for 30 seconds or so after starting a cold engine, if not then wiring fault possible, from junction block to pump, or even internal in junction block , if power to pump then bad pump. when it runs you can hear/feel it, makes a high pitched whine
Add to saturnhacker's Reputation
Rate the quality of this post and help saturnhacker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnhacker is offline   Reply With Quote
Old 03-26-2006, 06:09 PM   #4
dbruce
When I started the car I didn't notice anything.....but it was 40 or so outside. What's the cost to replace the pump assuming the worst case?
Thanx for the suggestions everyone.
Old 04-10-2006, 06:18 AM   #5
pete123
pete123 is on a distinguished road
Is the code p0400 or p0410? The posts refer to both numbers so I was confused.
About the metal line to the intake, I think you might have come across my post earlier last month:
http://www.saturnfans.com/forums/showthread.php?t=72453
If you do indeed have the p0410, I can almost definetly help you out. I have a 99sl2 and went through the same thing.
Add to pete123's Reputation
Rate the quality of this post and help pete123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pete123 is offline   Reply With Quote
Old 04-10-2006, 09:12 PM   #6
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
Thats not too smart since 99 is delco controlled and 00 is motorola controlled.
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
P0410 error code - HELP mx103 S-Series Tech 10 11-20-2012 08:49 AM
2000 SL2: P0410, No power to air pump pdxsl2 S-Series Tech 9 09-03-2012 04:54 PM
P0410 Error Code pgp_protector S-Series Tech 5 08-18-2009 11:12 AM
p0410 code storm_amoure S-Series General 3 11-10-2007 02:12 PM
Code P0410 Yellow Hornet S-Series Tech 2 01-25-2005 09:25 PM
