Old 03-21-2006, 10:11 PM   #1
Norseman
Norseman is on a distinguished road
Default Burning smell
I began noticing a burning smell from my 1996 SC2 last Sunday. I thought it was from my front driver side brakes. I checked the front brakes today. I did not remove the caliper but just rotated the wheel. There was no rubbing between the brake pads and rotor.
The smell is noticiable when I'm kneeling down between the window and ground. The smell would waft up. I could not smell anything while looking under the car (probably due to the breeze). I turned the car around and smell occurred on the passenger side.
So now I speculating the smell is from underneath the car. It's not coming from underneath the hood. Could it be my exhaust system? It's not a rotten egg smell so does that rule out the catalytic converter? I don't smell it at the tailpipe.
I believe I see three main sections to the exhaust system. From the engine, first the catalytic converter?, then an enlarged "torpedo" like tube, then the muffler. What is that "torpedo" looking thing in the middle of the system?
Any ideas what is causing the smell? I can't really describe the smell. It just smells like a "hot" smell. I do notice it when I come to a stop at the light and idle.
Add to Norseman's Reputation
Rate the quality of this post and help Norseman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Norseman is offline   Reply With Quote
Old 03-21-2006, 10:28 PM   #2
Uzzy
Uzzy's Avatar
2002 SC1
Default Re: Burning smell
"torpedo" = resonator
How closely did you look under the car? Could it be a plastic bag or something caught up on the hot exhaust?
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 03-21-2006, 10:32 PM   #3
Norseman
Resonator? What is it for? A sound baffle?
Everything seem clean underneath. The smell is not a plastic smell.
Old 03-21-2006, 10:39 PM   #4
Uzzy
Uzzy's Avatar
2002 SC1
Yes sound baffle. Umm maybe some other sort of debris? I'm not sure, but I'll give you the advice that I gave my friend when she complained of a burning smell in her Ford Escape. "If it does catch fire, pull over, get clear of it, and let it get good and burnt before you call the fire department. You want it well past written-off, 'cause you won't want it back." It still hasn't caught fire, and I doubt yours will. I don't know what else it could be.
Old 03-22-2006, 12:37 PM   #5
sierrap615
sierrap615's Avatar
check and smell your fluids, start with ATF and coolant
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
sierrap615 is offline   Reply With Quote
Old 03-22-2006, 04:06 PM   #6
saturnsctwo
just make sure the car has the best insurance policy on it before that "procedure" you mentioned. actually i would do the same thing! lol! people who owned those old pontiac fieros know what i'm talking about & i'm sure they had their techniques honed to high perfection.........
Old 03-22-2006, 05:16 PM   #7
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
What does your temp gauge show? Is it overheating at all?
You can tell Linux is made by geeks.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 03-22-2006, 08:13 PM   #8
justin_zink
justin_zink is on a distinguished road
1995 SL
Is it a burning oil smell, a break smell or something else?
Add to justin_zink's Reputation
Rate the quality of this post and help justin_zink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
justin_zink is offline   Reply With Quote
Old 03-25-2006, 09:56 PM   #9
steve-o
steve-o is on a distinguished road
steve-o's Avatar
1996 SL
3 fieros, over 200k miles between all of 'em and no fires.
if it smells like 'heat' could it be the cat overheating?
run it for a bit at nite, then park in a dark area and look underneath.
one of my fieros ( ) had a dis problem and turned the exhaust cherry red, but could only see it at night.
Add to steve-o's Reputation
Rate the quality of this post and help steve-o reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
steve-o is offline   Reply With Quote
Old 03-25-2006, 10:07 PM   #10
Norseman
Temp gauge is fine. It's not overheating.
I can't describe the smell. At first I thought it was the brake dragging but the smell wasn't similar to a brake smell. I checked the oil level and transmission oilmotor and they are fine. Did not check the coolant bottle.
The smell seemed to have faded a little today. I'll have to see the next couple of days. No sweet coolant smell from the heater.
I'll check into the cat heating up. It is a "hot" or "hot metal" smell.
Old 03-25-2006, 10:25 PM   #11
Sky King
Sky King's Avatar
If everything else you have checked is fine and the smell is fading, sounds to me like you may have had some debris caught on the exhaust and it has either come loose or has burned off for the most part. I would still keep an eye on it.
I second the "catch on fire" thing. The only thing a fire extinguisher in a car is good for it to hit people with it that try to put the fire out. (on a serious note, unless there are people trapped in the car). But if there is no hazard to anybodys safety, let it burn. I have never heard of a vehicle that was ok after a fire.
Add to Sky King's Reputation
Rate the quality of this post and help Sky King reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-19-2015, 10:34 AM   #12
rdaniels775
rdaniels775 is on a distinguished road
Hi Saturn Fans. I probably should have started a new thread, but I cannot figure out how. Anyway I would love some advice. I have been trying to get a 94 sw1 ready for my daughters first car. A few days ago I drove it up the street, turned if off and they a few minutes (30) later tried to start it. The car acted as if the batter was dead. I turned the key several times and noticed a electrical burn smell, but the car ended up starting. Please advise.
Thank you.
Add to rdaniels775's Reputation
Rate the quality of this post and help rdaniels775 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rdaniels775 is offline   Reply With Quote
burning plastic smell amlk1975 S-Series Tech 4 07-15-2009 06:22 PM
Burning Smell blackeagle1 S-Series Tech 4 03-08-2007 12:17 PM
New brakes - burning smell jambra1 S-Series Tech 8 06-02-2006 06:33 PM
Redline has burning smell JDRedline Ion Red Line 9 12-09-2004 01:32 AM
burning smell under the hood therapist Miscellaneous Tech 2 01-22-2002 09:17 PM
