Old 02-09-2002, 10:51 PM   #1
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
Default Alarm/Door Switch/Dome Light Problems
OK, this problem has been discussed before, but no solution was ever reached.
Today my car started acting strange. While driving down the road, the dome light (set to "door") would flicker. We opened and shut every door, and a few minutes later it did it again. I came out of a store, and my dome light was on, and hitting the unlock button caused the horn to honk three times (what does that mean?). I came out of Wal-Mart later to find my alarm going off. I got home, and my alarm went off twice within an hour.
I turned off the dome light and locked the doors using the door lock button (I assume this will not arm the alarm).
I wiggled every door switch. Didn't help. Alarm still went off.
Any solutions? I'm kinda discouraged since I bought this car three weeks ago ('97 SL2) and just got a new fuel pump put on yesterday at the retailer.
Thanks for all the help!
-Spencer
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline
Old 02-10-2002, 04:14 AM   #2
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default
Since the dome light and alarm are set off by open doors, it sounds like you have one or more bad door pin switches. I'd start by inspecting the rubber boots over the switches to see if any have cracked, exposing the switch to the elements.
Add to Heartbeat - '95 SL2's Reputation
Rate the quality of this post and help Heartbeat - '95 SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Heartbeat - '95 SL2 is offline
Old 02-10-2002, 11:08 AM   #3
spencerb
spencerb's Avatar
2008 Astra XR
Default
The only variable out of ordinary was getting my fuel pump replaced on Friday and getting a car wash yesterday. Maybe the high pressure wash shot water into a switch?
The dome light has the delay off, so it's very hard to wiggle a door pin switch to see if it's failing.
spencerb is offline
Old 02-10-2002, 01:37 PM   #4
Default
Like Heartbeat said one or more of your door switches is bad. The most likely one is the drivers door (gets used the most) then the passenger door. The horn beeping three times indicates that the security system is not setting due to an open door or trunk. Try the wiggle test on the switches with the engine running or the key in the run position, this should eliminate the delay feature. Worst comes to worst you'll have to pull out the switches to do a visual inspection on them.
Add to ssicarman's Reputation
ssicarman is offline
Old 02-10-2002, 02:18 PM   #5
Nuke-Em
Nuke-Em is on a distinguished road
Nuke-Em's Avatar
Default
Sounds to me like it's demon possessed--I'll help perform the exorcism!
Matt:o:
If God had intended driving to be boring, he would have given us all Toyota's
Add to Nuke-Em's Reputation
Rate the quality of this post and help Nuke-Em reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nuke-Em is offline
Old 02-10-2002, 02:37 PM   #6
spencerb
spencerb's Avatar
2008 Astra XR
Default
It beeped three times when I returned to my car and pressed unlock. I had successfully armed it when I went into the store. I assumed that it mean that the alarm went off in my absence.
How do I remove the door switches? Do they just rotate off?
I don't like this problem in that is is intermittent. I don't want the alarm to be going off all night, waking the neighbors. I don't want to leave the car unarmed, since I have an aftermarket CD player that theives may want. It was cheap, but still a possibility.
spencerb is offline
Old 02-10-2002, 03:08 PM   #7
Swizelman45
Swizelman45 is on a distinguished road
Default
well if you unlock the car with the remote and it beeps 3 times, that's a sign that the alarm went off since it's been armed. A least that's mine, but I don't know if the changed them at all in the 2000 refresh, I doubt they did though.
If I were you, i'd go to the dealer and to see what's wrong, until then, you might have to lock it with your key from now on (not arming the alarm)
Add to Swizelman45's Reputation
Rate the quality of this post and help Swizelman45 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Swizelman45 is offline
Old 02-11-2002, 02:29 AM   #8
spencerb
spencerb's Avatar
2008 Astra XR
Default
I'm excited, because I think I've found the problem. Since it's intermittent, I have to wait until it surfaces. Today I didn't have any problems, so I thought I was in the clear, but at the last minute decided not to arm the alarm tonight. Good thing, because I would have woken the neighbors (my carport is 20 feet from the next door neighbor's bedroom window).
Just before heading for bed, I peered out the window to find my dome light on! Yeah! I turn the car on, and first tried the driver's door switch. Nothing. Next was the passenger's door. As I opened the door, the light (which has not gone off yet) flickered. I pressed the switch a few times, and it began to work fine.
My problem does seem to be the passenger's door switch. Now, how do I fix it? I can't seem to figure out how to remove the switch (I didn't try real hard, though). Tomorrow I'll call the Saturn retailer that I just visited on Friday to check on the part price. I hope they can mail it to me; I'm an hour away. And I hope it's cheap.
Oh, and I did turn the dome light off to prevent a dead battery.
spencerb is offline
Old 02-11-2002, 11:17 AM   #9
spencerb
spencerb's Avatar
2008 Astra XR
Default
Update:
I talked to my retailer, and the part (door jam switch) costs $5.36. I talked to a tech about how to replace the switch. It has a plastic retaining clip on either side. I'll probably just destroy the switch that's installed now since it's bad anyway. Once I get the part I can also see exactly how it's made (they are shipping it to me).
spencerb is offline
Old 02-11-2002, 09:22 PM   #10
Default
The easiest way to get the switch out is to use a small (1/4 wide) flat blade screw driver to pry the switch up and out of the hole. Once out just disconnect it and plug the new one in and push it into place to reinstsall. Don't loose the connecter into the door or you'll be doing some disassembly to retrieve it.
Power Locks, Dome Light and Alarm Problem CORROSIONMAN S-Series Tech 2 01-17-2017 04:00 AM
Alarm/Dome Light Problem 04Ion2 Ion Tech 7 12-13-2009 02:24 PM
Dome Light Switch FoamieOmie S-Series General 4 08-30-2007 06:14 PM
Dome Light Switch Broken jshalla S-Series Tech 6 08-07-2006 10:31 PM
97 SL1 Won't start, no alarm (remote doesn't work) and dome light off if door open pauldsr S-Series Tech 8 01-27-2006 04:13 PM
