Old 03-18-2006, 03:26 PM   #1
nmsaty
nmsaty is on a distinguished road
1993 SL2
Wrench Idler pulley and/or tensioner pulley replace
Every morning or everytime I start my SL2 I get that annoying squeal noice. I live in WI so that is part of the reason being winter. Anyway is it neccessary to replace the idler pulley and tensioner pulley or one or the other. I don't follow what the difference is between the two. I just want to know how to make that squeal go away. It is a bearing in there that is going I assume?
thanks
Add to nmsaty's Reputation
Rate the quality of this post and help nmsaty reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nmsaty is offline   Reply With Quote
Old 03-18-2006, 04:04 PM   #2
Civic&Saturn
Civic&Saturn is on a distinguished road
Civic&Saturn's Avatar
Default Re: Idler pulley and/or tensioner pulley replace
I just did this job a week ago. If you're replacing the tensioner (about $88 on Saturnparts.com) you might as well replace the idler pulley at the same time. For both jobs you need to remove the serpentine belt, and the idler only costs about $18, so it makes little sense to postpone the idler replacement if you're already doing the tensioner replacement.
The How-To Library has a detailed procedure. Some have recommended removing the upper engine mount to improve access, but I did not need to. I got the idler pulley bolt out with a 13mm, six point box end wrench. The two tensioner bolts were 10mm, and I believe the tensioner pulley bolt was 14mm.
Add to Civic&Saturn's Reputation
Rate the quality of this post and help Civic&Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Civic&Saturn is offline   Reply With Quote
Old 03-18-2006, 11:16 PM   #3
soap
soap is on a distinguished road
You do not have to replace the idlers. You can simply remove them, pop off the bearing seal and clean the bearings then repack them.
--Joe
Add to soap's Reputation
Rate the quality of this post and help soap reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
soap is offline   Reply With Quote
Old 03-19-2006, 06:05 PM   #4
nmsaty
1993 SL2
SO, is it the pulley or the tensioner that is going and causing the sqealing, and whining noise?
HELP!
Old 03-19-2006, 06:10 PM   #5
soap
Just listen closely with the car idling in park. My suggestion is to start with the idler since it only costs you time to remove/clean/repack and reinstall.
If it still makes noise then your next option is the tensioner.
--Joe
Old 03-19-2006, 06:31 PM   #6
Luke
Luke's Avatar
> Fm Joe <
> You can simply remove them, pop off the bearing seal and clean the bearings then repack them <
I actually tried that, however, found that the wear of the bearing, simply did not justify not replacing the actuall bearing. They cost in the 4-8 dollar range.
In my case, I repacked one unit, and found that it did not guide smoothly, as was the case with every new unit.
Add to Luke's Reputation
Luke is offline   Reply With Quote
Old 03-19-2006, 06:49 PM   #7
Uzzy
Uzzy's Avatar
2002 SC1
You can't (shouldn't) re-pack the bearings. They are sealed units and not intended to be serviced. They can be replaced. You can replace just the bearing which is what I would reccommend if the pully is not damaged at all, and if you have the means to. If you try to sevice them, they will not last and fail quickly. I work for Gates, we make the tensioners, and pulleys in question here.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 03-20-2006, 07:57 AM   #8
soap
They are sealed the same way wheel bearings are.......and you have to remove the seals and repack the bearing everytime you do brakes.
What is the difference?
--Joe
Old 03-20-2006, 08:30 AM   #9
Uzzy
Uzzy's Avatar
2002 SC1
According to NTN the manufacturer they are not to be serviced. And they're cheap enough that replacing them isn't a big deal. You can do it if you like, I'm just telling you that they are not intended to be greased. Once that cover is removed it can't be replaced properly and therefore contaminents invade the bearings and they break down quickly. Just letting you know what I was told.
Old 03-20-2006, 09:21 AM   #10
soap
Fair enough.......thanks for the information.
--Joe
Old 03-20-2006, 10:05 AM   #11
Luke
Luke's Avatar
>Fm Uzzy <
They shouldn't be repacked.
>Uzzy<
THAT makes more sense; However, they can be repacked. The issue is, is it worth it.
And the NTN number is # 6203.
Old 03-20-2006, 06:02 PM   #12
saturnmonkey
saturnmonkey is on a distinguished road
2003 VUE 2.2L
turn the engine off and give the belt a tug in upward direction. if the belt hardly moves of moves more than about an inch or so it is time to replace the tensioner. start the engine and put a long screwdriver on the head of the bolt on the idler and listen. if the noise comes through the screwdriver it is time to replace the idler. do NOT try to repack the idler. its only a couple of bucks and is one 13mm bolt. just replace it.
Add to saturnmonkey's Reputation
Rate the quality of this post and help saturnmonkey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnmonkey is offline   Reply With Quote
Are the serp belt idler pulley and tensioner pulley the same part - 93 DOHC?? 93goldsl2 S-Series Tech 6 04-10-2010 01:03 PM
Idler pulley or tensioner? JerryHughes S-Series General 9 02-02-2008 04:53 PM
tensioner pulley=idler pulley? bhall10 S-Series Tech 32 05-24-2004 07:37 PM
new squeak... tensioner/idler pulley? dazz_sc1 Miscellaneous Tech 5 11-06-2003 12:30 PM
Idler or tensioner pulley? RBH S-Series Tech 2 11-27-2001 09:28 AM
