Old 03-13-2006, 04:31 AM   #1
jtk
jtk is on a distinguished road
Mad '98 SL1 engine to SC2 trans trouble
I recentle swapped th SOHC engine from my wrecked '98 SL1 into a '98 sc2 which had the DOHC. The engine runs great, but when driving it the trans will not shift unless the I let off the gas completely, then when I try to give it gas it upshifts. Could this be due to different PCMs?
Add to jtk's Reputation
Rate the quality of this post and help jtk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jtk is offline   Reply With Quote
Old 03-13-2006, 06:30 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: '98 SL1 engine to SC2 trans trouble
You cannot use an automatic transmission from a DOHC with an SOHC engine. The PCM controls the shifting and the gear ratios are different. You must have put the PCM from the SOHC or the engine wouldn't run.
Add to BarnOwl's Reputation
Old 03-14-2006, 06:00 AM   #3
jtk
Actually the SOHC engine runs perfectly with the DOHC computer. The only problem I have is that the trans won't shift properly. When I replaced the speed sensor with the old one from the SL1-which is in poor shape-it still had the same basic problem, except that it stayed in second for a little longer. All of the shops I ran this by said the speed sensor was the most likely culprit, and the PCM next. I am going to replace the speed sensor first, and then move on to the PCM.
Old 03-14-2006, 06:02 AM   #4
jtk
BTW I did not hook the DOHC trans to the SOHC engine. I left the original on it seeing as how it was recently rebuilt.
95 sc2- Engine Trouble Codes RalliArt16 S-Series Tech 5 07-04-2008 02:49 PM
removing engine on 96 sc2 (car has manual trans)... from top w/o removing trans??? DJboozeAlot S-Series Tech 4 02-02-2007 09:18 PM
92 sl1 used engine pull can use auto/manual trans? MacExperts S-Series Tech 3 10-20-2006 07:49 PM
1995 SL1 5sp Trans, 94 SC2 Parting Out gsieg Classifieds 15 12-30-2005 01:01 AM
97 SC2 Engine and trans 56K saturn obda Classifieds 1 01-17-2003 02:53 AM
