Old 03-04-2006, 07:31 PM   #1
randyl68
randyl68 is on a distinguished road
Default sl1 manual input shaft seal leak
I have a 1996 Saturn SL1 with a 5 speed manual transmission. I have taken the transmission out because the clutch was slipping. I bought all of the new clutch parts ready to replace the clutch plate, pressure plate and throw out bearing. My problem is that when I got the transmission out, I found that the only problem was the input shaft seal on the transmission is leaking which is dripping the atf fluid onto the clutch causing it to slip. My question is this: can I replace just the input shaft seal on the transmission without taking the tranmission apart? If not, is there an easy way to separate only part of the transmission to only allow access to this seal? Is it a major job? I am quite mechanical, but have no experience with the internals of transmissions, is there anything I need to worry about, or is this a job best left to a transmission shop. Any advise would be appriciated. Thanks
Add to randyl68's Reputation
Rate the quality of this post and help randyl68 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
randyl68 is offline   Reply With Quote
Old 03-05-2006, 07:54 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: sl1 manual input shaft seal leak
I'm going to tell you straight up front, I've never done this, but I believe you are talking about the quill bearing seal. If so, you have to pretty much pull the tranny apart to get to it. Different Racing has the best guide to doing this that I've seen. Here's a link to that. While you're at it, you should probably get the diff pin welded.
Add to BarnOwl's Reputation
Old 03-05-2006, 10:36 AM   #3
amazinghl
If it is like my dodge tranny, all you do is remove that throw-out bearing, then unbolt three bolt to get the seal housing out, replace the seal and the install is the reverse.
Try to e-mail the http://www.differentracing.com/ guys, they should be able to help you rather quickly.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
input shaft seal quantumech S-Series Tech 0 06-30-2009 02:43 PM
Shifter Shaft Seal Leak p-ROCK S-Series General 3 01-28-2008 08:37 PM
Input shaft seal installation? speedy45 S-Series Tech 1 08-03-2007 11:42 AM
Replacing input shaft seal/bearing Khandyman S-Series Tech 1 01-16-2007 03:18 AM
Transmission Input Shaft Seal RJ_95SC2 Miscellaneous Tech 13 04-21-2003 08:31 AM
