Old 02-21-2006, 02:40 AM   #1
Rhoads62
Rhoads62 is on a distinguished road
Default security code reset
I replaced ignition lock on 2002 sc. Now the security light comes on and it wont start. Is there a reset using the key? Any info would be helpful. Thanks
Add to Rhoads62's Reputation
Rate the quality of this post and help Rhoads62 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rhoads62 is offline   Reply With Quote
Old 02-21-2006, 09:39 AM   #2
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
Default Re: security code reset
You could get the new lock re-done to match your old keys or get the dealer to program your new keys into the system.
Add to RangerRover's Reputation
Rate the quality of this post and help RangerRover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RangerRover is offline   Reply With Quote
Old 02-21-2006, 09:54 AM   #3
wolfman
wolfman's Avatar
This may sound like an obvious question, but did you plug the PasslockII wiring harness connector back into the new ignition lock?
Add to wolfman's Reputation
Old 02-21-2006, 09:54 PM   #4
You will need to perform the 30 minute passlock relearn after replacing the ignition cylinder. Basicly three rounds of turning the key to the crank position, release to run and letting it sit for 10 minutes or the security light goes off. Normally the light doesnot go off. Turn key off and repeat. After the third time the car should start.
Add to ssicarman's Reputation
Old 02-21-2006, 11:21 PM   #5
wolfman
wolfman's Avatar
I had forgotten about that. To clarify:
1. Turn the key to START briefly and then back to "RUN" (the car will not start)
2. Once you have done this, leave the car in "RUN" (NOT ACCESSORY and DO NOT turn it to "LOCK!"!) for ten minutes, or until the Security light goes out (which ever happens first)
3. Turn the key to "OFF" and then return to step #1.
4. Repeat a total of 3 times (total elapsed time 30+/- minutes)
5. When you have completed the above, the car should start and run normally and will continue to do so from then on.
NOTE: If at any time the car DOES actually start and run, you are DONE and do not need to continue to repeat the sequence.
(I forgot the ignition switch itself is what holds the security code (resistance value) in the PasslockII system. (Thanks Ssicarman!)
Old 02-22-2006, 01:34 PM   #6
wolfman
wolfman's Avatar
Use this procedure after replacing:
Passlock™ sensor
BCM
PCM
Learn Procedures
There are 2 available methods to perform the programming procedure:
A 10-minute procedure which requires a Tech 2 and a techline terminal.
A 30-minute procedure which does not require the use of any tools.
10-Minute Learn Procedure
Tools Required
Tech 2
Techline terminal with current Service Programming System (SPS) software
Connect the Tech 2 to the vehicle.
Select "Request Information" under "Service Programming".
Disconnect the Tech 2 from the vehicle and connect it to a techline terminal.
On the techline terminal, select "Theft Module Re-Learn" under "Service Programming".
Disconnect the Tech 2 from the techline terminal and connect it to the vehicle.
Turn ON the ignition, with the engine OFF.
Select "VTD Re-Learn" under "Service Programming".
Attempt to start the engine, then release the key to ON, vehicle will not start.
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF, the vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK.
Turn OFF the ignition, and wait 5 seconds.
Start the engine, the vehicle has now learned the password.
With the Tech 2 scan tool, clear any DTCs.
30-Minute Learn Procedure
Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
Repeat steps 1-4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock™ Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
Important
The vehicle learns the Passlock™ Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
Start the engine. The vehicle has now learned the Passlock™ Sensor Data Code and/or password.
With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
Old 01-15-2011, 04:25 PM   #7
Homoudont
Homoudont is on a distinguished road
2004 ION-3 Sedan
Just wanted to add that I followed the instructions on this website / forum and have had no problems replacing the ignition switch. Good luck.. its well documented on this website what you have to do to replace it.
Thanks everyone for all your help.
Add to Homoudont's Reputation
Rate the quality of this post and help Homoudont reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Homoudont is offline   Reply With Quote
Old 05-04-2012, 10:31 PM   #8
stoney11771
stoney11771 is on a distinguished road
I am glad to have confirmation on here of what the service guy at a dealership told me! They wanted $295 to replace a ignition cylinder! I can find it online for $48!
Add to stoney11771's Reputation
Rate the quality of this post and help stoney11771 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stoney11771 is offline   Reply With Quote
Old 06-01-2016, 09:51 AM   #9
Benny6565
Benny6565 is on a distinguished road
2002 VUE 2.2L
Roll Eyes Re: security code reset
This does not work on a stick shift.. Any ideas?? I try with the clutch down the entire 3 cycles, without the clutch engage For 3 cycles .. Nothing appears to work.. I have a2002 vue with a 2.2l motor.. Changed out fuel pump, computer (engine section), ome, replace injectors check fuel Pressure the Rail pressure is there, even changed the filter on the fuel rail, a new battery.. So if anyone has an idea please help.. Thank you
Add to Benny6565's Reputation
Rate the quality of this post and help Benny6565 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Benny6565 is offline   Reply With Quote
Old 06-01-2016, 10:34 AM   #10
spacetrace33
spacetrace33 is on a distinguished road
spacetrace33's Avatar
I have done this before. One weird thing that happened to me. (probably goofed the first time, idk) is it took four times vs the three.
Edit. Mine is a stick, with safety bypassed, and didn't have to use the clutch at all. It was an auto before....
00 SL1 Daily Driver
98 SL2 race car-not street legal by any means
01 SC2 race car-not street legal by any means
00 SL2 aka boom boom pow
99 SL2. 99 problems
Add to spacetrace33's Reputation
Rate the quality of this post and help spacetrace33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spacetrace33 is offline   Reply With Quote
Old 06-01-2016, 10:54 AM   #11
Benny6565, why was the engine computer replaced? As mentioned, there are a total of four(4) ignition switch cycles with the first three cycles each needing ten minutes with ignition on. The last (forth) try is actually starting the engine when the fuel password is learned. Pressing the clutch pedal down isn't needed for this since you're not in gear.
Old 06-01-2016, 11:00 AM   #12
spacetrace33
Aha fdryer.
My mystery solved.
00 SL1 Daily Driver
99 SL2. 99 problems
Old 06-01-2016, 02:16 PM   #13
pbrev
pbrev is on a distinguished road
2001 SL2
I have tried to follow these instructions (3 step, 30' reset) but my security light does not turn off after ten minutes. Tried waiting longer, and it still stayed on. Suggestions?
Add to pbrev's Reputation
Rate the quality of this post and help pbrev reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pbrev is offline   Reply With Quote
Old 06-01-2016, 02:45 PM   #14
00_SL1
00_SL1 is on a distinguished road
00_SL1's Avatar
2001 SL2
Read post #5, Step 2, again by Wolfman, should clear up that question for you
Add to 00_SL1's Reputation
Rate the quality of this post and help 00_SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
00_SL1 is offline   Reply With Quote
Old 06-01-2016, 05:19 PM   #15
pbrev
2001 SL2
I tried the method just using time and that did not work. The 'security' light stayed lit, and the car would still not start. Any other steps that need taking in order to get the system to reset?
Old 06-01-2016, 08:33 PM   #16
spacetrace33
Maybe it's time to find somebody with a tech II.
00 SL1 Daily Driver
99 SL2. 99 problems
Old 06-02-2016, 04:56 AM   #17
Benny6565
2002 VUE 2.2L
When I started reading these strings I went and began replace parts to find the problem ( why this car won't start and what cause it to just shut down on the highway for no reason). The fuel pump was first, followed by the sensors (clean all 4) then the ome sensors, then the rail, the injectors, the little filter on the rail, my battery starting dieing out with nothing on, I replaced it. Then one night I notice the light on my vue flicking in short Burst ... Then one day my tires locked up.. Just locked up... When I replaced the computer I found rust on the contacts.. Then I read about the key and security system and this is were I'm at now. Again I'm sorry for any confusion.. I'm just trying everything I can before I'm force to take the lost and loss my beloved vue.. Thank you all for reading this..
2000 sl2 1.9 dohc security light reset duke73 S-Series Tech 11 03-05-2013 09:32 PM
2000 sl2..wrench and security light reset? duke73 S-Series Tech 3 10-09-2009 10:46 PM
Smog check code reset herrtodd S-Series Tech 3 01-18-2006 09:12 PM
How do I reset factory Security Sys. on '98 SL2? TGP S-Series Tech 4 02-28-2005 10:14 AM
Reset for Satrun Security System? badtzbuzz General Saturn Discussion 8 11-03-2002 06:54 PM
