Old 02-15-2006, 11:20 PM   #1
kb96sc2
kb96sc2 is on a distinguished road
Default saturn sc2 dash lights
i have no idea exactly what they mean but i have 2 lights that sometimes flash like above my temp gauge. one looks like the temp thing and the other looks like a bottle with a down arrow on it
anyone have a clue or a book to help me my car does not run hot?
Add to kb96sc2's Reputation
Rate the quality of this post and help kb96sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kb96sc2 is offline   Reply With Quote
Old 02-15-2006, 11:51 PM   #2
DarrylLeeOHS30
DarrylLeeOHS30 is on a distinguished road
2001 SL2
Default Re: saturn sc2 dash lights
That's the low coolant light. You should add some antifreeze (50/50 mix of coolant to water) that should take it away.
-Darryl
Add to DarrylLeeOHS30's Reputation
Rate the quality of this post and help DarrylLeeOHS30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DarrylLeeOHS30 is offline   Reply With Quote
Old 02-15-2006, 11:56 PM   #3
kb96sc2
ok ty. do you by chance know where the knock sensor is on the sc2's? the car starts to make an annoying noise between 1800-2500 rpm's i had the cat changed out thinking it was exhaust noise and still there. all my lifter and rods seem to be fine
Old 02-16-2006, 12:33 AM   #4
DarrylLeeOHS30
2001 SL2
nope, i dont know about that one, sorry. but what year is your sc2? if its a PRE-2001, you'll need to replace the ECTS. They are made out of plastic (before 2001 year model) and crack and cause a bunch of problems.
edit: judging from your name, a 96. you'll need to do the ECTS if you haven't already.
-Darryl
Old 02-16-2006, 12:48 AM   #5
dansl2
dansl2 is on a distinguished road
dansl2's Avatar
2000 SL2
Although that's a good suggestion to change out your ECTS, it probably isn't the cause if your noise. Are you running platinum plugs? That could do it, most Saturns just don't like platinums. If so, replace them with NGK's (highly recommended, as they are OEM) or some AC Delcos. Not sure of knock sensor location, but if you start another thread with that question, someone will be able to point it out. Or you could try a search first.
Experience is something you don't get until just after you need it.
Add to dansl2's Reputation
Rate the quality of this post and help dansl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dansl2 is offline   Reply With Quote
Old 02-16-2006, 07:00 AM   #6
BarnOwl
BarnOwl's Avatar
You don't mention what kind of transmission you have but that flashy light thing can be caused by the TTS (Transmission Temperature Sensor autos only) getting a completely different reading than the ECTS (Engine Coolant Temperature Sensor). If you've never changed the ECTS, that's probably the problem.
The knock sensor can be seen from underneath the car. It's on the passenger side a little up and to the right of the oil pressure sender. However, I doubt very seriously that it's the cause of your noise.
Add to BarnOwl's Reputation
Old 02-16-2006, 10:39 AM   #7
DTDSasquatch
DTDSasquatch is on a distinguished road
1997 SW2
Why would you guys recommend replacing parts based only on the description of...
...an annoying noise between 1800-2500 rpm's i had the cat changed out thinking it was exhaust noise and still there. all my lifter and rods seem to be fine
Could you describe the noise in better detail?
Internet message boards: The demise of the English language.
Add to DTDSasquatch's Reputation
Rate the quality of this post and help DTDSasquatch reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DTDSasquatch is offline   Reply With Quote
Old 02-16-2006, 10:56 AM   #8
BarnOwl
BarnOwl's Avatar
I don't believe I did. I recommended replacing the ECTS based on...
I also said I doubted the knock sensor was related to...
No parts recommendations for that at all.
1995 Saturn SL1 dash lights, please help! Gump S-Series Tech 4 11-02-2009 05:49 PM
What are these dash lights? 1997 SC2 kjh S-Series Tech 11 01-12-2009 10:11 PM
1998 saturn sl1 dash lights gregmiller06@co L-Series Tech 1 10-22-2008 06:22 PM
SC2 Dash Lights PlutoZePlin S-Series General 0 05-24-2006 01:52 PM
Saturn Vue dash lights Wayne Smith Vue Tech 1 04-03-2005 09:04 AM
