Go Back   SaturnFans.com Forums > Models > Saturn Ion > Ion Mods
Old 01-17-2006, 02:55 AM   #1
Pyrate
Pyrate is on a distinguished road
Default Drum to Disc conversion
Anyone know where to find detailed info on a drum to disc conversion for an 03 coupe?
Thanks
Add to Pyrate's Reputation
Rate the quality of this post and help Pyrate reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pyrate is offline   Reply With Quote
Old 01-17-2006, 03:36 AM   #2
DSLaBuda
DSLaBuda is on a distinguished road
DSLaBuda's Avatar
2005 ION-1 Sedan
1997 SL1
Default Re: Drum to Disc conversion
Thanks
http://www.gravanatuning.com/applica...isc_Conversion
other than that kit, i don't believe anyone has swapped discs onto a non-rl ion. not sure about the other delta chassis cars (cobalt & hhr) if any of them had rear discs as an option. if available, they'd be the only real bolt on.
otherwise to swap the redline brakes on you'd also need the wheels (it's a 5-lug) for the rear and most likely alot more for the front.
i know the ion shares a bolt pattern with the s series, but i don't know if anything is compatible. the ion is a heavier car though.
lastly, failing all else; find a rotor that fits and have a caliper bracket fabricated.
-DS
"I'm a product, of my environment
So don't blame me, I just work here"
But I want to **** it all up!!"
Offspring - Americana
Add to DSLaBuda's Reputation
Rate the quality of this post and help DSLaBuda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DSLaBuda is offline   Reply With Quote
Old 01-17-2006, 12:48 PM   #3
Pyrate
How about installing a complete redline rear end?
Old 01-17-2006, 02:58 PM   #4
slo96sl2
slo96sl2 is on a distinguished road
2003 ION-3 Quad Coupe
I want to do a rear disc swap also, for $1165 it might be cheaper to swap in a RL rear
Does anyone know what the differences between the RL rear and my '03 QC3? If I can put Toyota axles under a Suzuki Samurai I can do this. There can't be to much of a difference between the two rear suspensions.
'03 Red QC3
Add to slo96sl2's Reputation
Rate the quality of this post and help slo96sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slo96sl2 is offline   Reply With Quote
Old 01-17-2006, 03:27 PM   #5
jerm1
jerm1 is on a distinguished road
jerm1's Avatar
2004 ION-3 Quad Coupe
wouldn't you have to change the front to 5 lugs as well? It would cost alot..I would think
- Jerm
04 Ion QC3 - Electric Lime
-HKS Exhaust
-AEM CAI
-Eibach Springs
-Strut Tower Brace
http://img150.imageshack.us/img150/6624/ion0049wo.jpg
Add to jerm1's Reputation
Rate the quality of this post and help jerm1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jerm1 is offline   Reply With Quote
Old 01-17-2006, 03:57 PM   #6
opposingreality
opposingreality is on a distinguished road
opposingreality's Avatar
2005 ION-2 Quad Coupe
You wouldn't have to swap the front. Besides you wouldn't need to swap the whole rear anyway, just the hub. If I am not mistaken the hub costs around $120 a side, then of course you would need the brakes and rims. If you were willing to go all (ebay)aftermarket, I would guess you could complete the rear disc conversion for around $700 including rims/tires.
There are no stupid questions, but there are a lot of inquisitive idiots.
Add to opposingreality's Reputation
Rate the quality of this post and help opposingreality reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
opposingreality is offline   Reply With Quote
Old 01-17-2006, 04:04 PM   #7
opposingreality
Stiffer shocks, 5 bolt hub, brake lines.....thats about it
Old 01-17-2006, 05:09 PM   #8
saturn_69
saturn_69 will become famous soon enough
saturn_69's Avatar
All prices are from Saturnparts.net
RL front hubs....131.85 each
RL rotors..........91.14 each
RL calipers........150 R / 162 L (don't know why....kinda odd, eh?)
Pads................67.60
RL rear hubs......126.87 each
RL R/rotors........73.15 each
RL R/calipers......116.72 each
Pads.................103.03
Total................1562.09
That's before fluid, labor - if you can't do it yourself - miscellaneous parts that may or may not be interchangeable such as ABS sensors, hoses, clips, parking brake cables, etc. Then, you need to buy 4 5x105 wheels, or find a wrecked Malibu, 9-3, G6, RL or Cobalt SS and get the wheels from it. Of course, you could just have the front hubs replaced with the 5 lug, have the rotors redrilled to match and buy only the rear rotors, hubs, calipers and save some money. Or, put the S-series rear discs on there, keep your stock bolt pattern and lower the cost a whole lot. Sleeper look maintained.
"That government is best which governs not at all; and when men are prepared for it, that will be the kind of government which they will have" - H.D. Thoreau
Add to saturn_69's Reputation
Rate the quality of this post and help saturn_69 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn_69 is offline   Reply With Quote
Old 01-17-2006, 05:47 PM   #9
IonNinja
IonNinja is on a distinguished road
IonNinja's Avatar
2005 ION-2 Sedan
in other words its not worth it.
the rear does not do enough of the braking to justify the cost anyway...
Also to whoever said you wouldn't need to swap the front, why the hell would you want to have a 5x110 rear and a 4x100 front? Good luck finding wheels in both patterns...
2005 Saturn Ion 2 Sedan
Add to IonNinja's Reputation
Rate the quality of this post and help IonNinja reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IonNinja is offline   Reply With Quote
Old 01-17-2006, 06:02 PM   #10
saturn_69
saturn_69's Avatar
Exactly, unless you're doing a road-race chassis there's really no way to warrant the expense. Rear brakes don't do a whole lot of work, unless you set up the proportioning valve to apply front and rear equally on a straight stop....but don't do it in a corner at speed...wheeee! Money could be better spent on improved pad and shoe material and larger front rotors.
Old 01-17-2006, 10:14 PM   #11
opposingreality
I didn't say you would want two different bolt patterns, I just said you don't NEED to do a front end swap
Old 01-17-2006, 10:50 PM   #12
eRic 02sc2
eRic 02sc2's Avatar
trade your Ion in for an Ion Red Line. it's easier than swapping brake parts.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-18-2006, 04:59 AM   #13
DSLaBuda
DSLaBuda's Avatar
2005 ION-1 Sedan
1997 SL1
one note about changing the front; wouldn't you possibly need a hybrid axle? the RL and regular ions have two different manual trans's from different manufacturers (iirc on the last part). is it possible that the part of the axle that slips into the hub would be different too? probably larger to handle the additional torque? save swapping the entire trans/axle assm, you would need a hybrid axle custom made with the standard transaxle end and the rl hub end.
all this is speculative on the two models having different axles.
-DS
Old 01-18-2006, 10:25 AM   #14
saturn_69
saturn_69's Avatar
I think the reason the axles are different is a strength issue, since the RL puts out more torque than the 2.2 or 2.4. The knuckle and outer CV joint are the same for all Ions, so I think all you'd need to do is change the hubs, rotors and calipers.
Old 01-19-2006, 01:25 AM   #15
Pyrate
Originally Posted by saturn_69
...Or, put the S-series rear discs on there, keep your stock bolt pattern and lower the cost a whole lot. Sleeper look maintained.
Could you elaborate on that?
Old 01-19-2006, 09:45 AM   #16
saturn_69
saturn_69's Avatar
I'm not sure about the size of the rear hub, but technically, wouldn't the rear rotors from an S-series fit on the Ion? All you need to do is work out a backing plate for the rotor and mount the caliper....bingo, rear discs with the same bolt pattern as the front and a working parking brake. Really inexpensive even if you do buy new rotors and calipers, at least compared to the Redline pieces. My Dad made rear discs for my '78 Sunbird, it wasn't that hard...just took the rear calipers with e-brake from a wrecked Fiero, redrilled the rotors for my 4-lug axles and mounted them up with a 3/8 steel bracket. If you know someone who can cut steel or fabricate the mounting brackets, you could get it done in a day. Trust me, I've thought about it....
Old 01-19-2006, 02:37 PM   #17
slo96sl2
I'll have to look into it. I have a set of S-series rear dics sitting in the garage.
'03 Red QC3
Old 01-20-2006, 10:43 AM   #18
saturn_69
saturn_69's Avatar
Another thing you could do is to buy the RL rear discs, backing plates, calipers, and just re-drill the rotors to match the regular Ion bolt pattern, then you wouldn't need the rear hubs nor would you need to re-do the entire front brakes as well. That'd run you about $500. Much cheaper.
Old 01-20-2006, 11:38 AM   #19
kickerion
kickerion is on a distinguished road
2003 ION-2 Sedan
I heard you could just switch the hubs over to get 5lug. and im probably going to try this setup since the drums suck.
Add to kickerion's Reputation
Rate the quality of this post and help kickerion reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kickerion is offline   Reply With Quote
Old 01-20-2006, 11:44 AM   #20
THX712517
THX712517 is on a distinguished road
THX712517's Avatar
Redline uses a different gearbox from Saab with equal length halfshafts. Regular Ion has unequal length halfshafts. Lots of different parts in there, I believe.
2003 Saturn Ion
2001 Mazda Miata
1997 Saturn SC1
Add to THX712517's Reputation
Rate the quality of this post and help THX712517 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
THX712517 is offline   Reply With Quote
Rear wheel drum to disc brake conversion Flytrap Ion General 5 07-04-2006 11:19 PM
Disc vs. Drum Brakes DualCamCoupe S-Series Tech 22 03-20-2003 04:30 PM
Rear Drum to Disc conversion piratepress Miscellaneous Tech 16 03-18-2003 08:35 PM
DIY Drum/Disc Conversion ... green97sc2 S-Series Tech 5 08-31-2002 10:36 PM
drum to disc evilSL1 S-Series Mods 2 03-28-2001 04:11 PM
