Old 01-16-2006, 03:24 AM   #1
tgparker
tgparker is on a distinguished road
tgparker's Avatar
1997 SW1
Dizzy Replacing Front Flex Exhaust Pipe on SL1 Help Pls. ?!?!?
Replaced the midsection exhaust pipe and cat on my SL1 and I must say that the car's performance has really improved.
I noticed that the front flex pipe is looking a little frayed and I ordered a replacement.
Replacing that section looks very tricky as at least one of the bolts looks totally innaccesible... do I really have to remove the header as well to remove the front flex-pipe?
I tried searching around in the How-To section but couldn't find a "How To" on replacing the front exhaust flex pipe section....
I'd be grateful for some Help and advise...
thanks in advance,
Tony
Add to tgparker's Reputation
Rate the quality of this post and help tgparker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tgparker is offline   Reply With Quote
Old 01-16-2006, 03:46 AM   #2
Token
Token is on a distinguished road
Token's Avatar
1994 SW2
Default Re: Replacing Front Flex Exhaust Pipe on SL1 Help Pls. ?!?!?
The down pipe and flex pipe are the same pipe. One end is bolted to a flange at Cat and the other is bolted at a flange on the bottom of header.
"Some days your the dog, some days your the hydrant."
Add to Token's Reputation
Rate the quality of this post and help Token reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Token is offline   Reply With Quote
Old 01-16-2006, 04:22 AM   #3
tgparker
tgparker's Avatar
1997 SW1
Dizzy Re: Replacing Front Flex Exhaust Pipe on SL1 Help Pls. ?!?!?
I know what my Front Flex or "Down" pipe is. MY problem is how to remove/replace it.
Do you actually know how to remove the flex pipe or "down" pipe as you call it? If so please advise.
Thanks in advance,
Tony
Old 01-18-2006, 12:20 PM   #4
willy_g
willy_g is on a distinguished road
Tony, where did you get your flex pipe from? I'm looking to replace mine as well.
Bill
Add to willy_g's Reputation
Rate the quality of this post and help willy_g reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
willy_g is offline   Reply With Quote
Replacing flex pipe paromano32 S-Series General 2 03-31-2013 01:59 PM
Exhaust leak at flex-pipe:93 SL1 johnholl S-Series Tech 1 09-29-2007 10:24 AM
What size exhaust pipe for the flex pipe? turbobuick33 S-Series Tech 4 03-10-2007 03:46 PM
Down Pipe/Header Pipe/Flex Pipe/Front Pipe Carriere S-Series General 6 05-12-2006 07:44 PM
Exhaust Flex Pipe Questions joshjani S-Series Tech 18 04-10-2005 03:41 PM
