Old 01-28-2006, 02:08 AM   #21
ttreibel
ttreibel is on a distinguished road
ttreibel's Avatar
2006 ION-2 Quad Coupe
2002 SL1
Default Re: What are the possible reasons for a Service Wrench light going on?
Wolfman Thanks again for the hint toward the fan circuit. I bet you will be right on this one. If you save me that 45 mile drive to the dealer you can have my first born.
1995 SL1 oil burner school commuter looks nice...1997 SL1 Gold 5-speed with new junk yard wheels and tires just got 40.4 MPG....2002 SL1 sometimes 45 MPG on a spring highway drive
Add to ttreibel's Reputation
Rate the quality of this post and help ttreibel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ttreibel is offline   Reply With Quote
Old 01-28-2006, 09:28 AM   #22
BarnOwl
BarnOwl's Avatar
Originally Posted by Old_Coot
That would be under the last resort column for the wrench light, and obviously my comment was 98% sarcastic.
So was mine. I forgot the smiley.
Add to BarnOwl's Reputation
Old 01-28-2006, 02:46 PM   #23
bigc791
bigc791 is on a distinguished road
bigc791's Avatar
1994 SL1
burnt out ses light will turn on the wrench light if remember correctly on the old ones.
Carmen
1998 2.4L swapped Plymouth neon is my ride.
Add to bigc791's Reputation
Rate the quality of this post and help bigc791 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigc791 is offline   Reply With Quote
Old 02-01-2006, 08:14 AM   #24
srponies
srponies will become famous soon enough
(FYI- longish post)
Well I finally bit the bullet and took mine in. I happened to be running a bunch of errands and was passing a Saturn dealer (not my local one). I asked the service writer about scanning for codes. He said sure - $99, and that charge will be applied towards any repairs you have done. I said "the dealer I usually go to (if I really have to) would do it for $40." He said "How about $47.50?" "Fine"
So I let them work on the car while I checked out the new goodies in the showroom. They found the following codes: P0341, P1650, P1651, and the service guy said that the codes were there because my SES light wasn't working. He said this might be because my EL Glo white face gauges were flickering intermittently and this may be causing a problem in the cluster. I told him the gauges were wired on a separate circuit, and the factory gauge lighting worked fine... probably just a bad bulb. I paid my $50 and then finished running my errands. I figure that at least now I have the codes (and they did wash the car). Sometime in the next few weeks I'll pull the cluster and check everything out (I have a new EL glo gauge kit on the shelf just waiting).
Thanks for all the info and for letting me ramble,
Steve H.
Add to srponies's Reputation
Rate the quality of this post and help srponies reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
srponies is offline   Reply With Quote
Old 02-20-2006, 09:49 PM   #25
donedds
donedds is on a distinguished road
donedds's Avatar
1996 SC1
Originally Posted by srponies
I've got the Service (wrench) light now after changing plugs, wires, cleaning EGR, replacing ECTS and connector. I just swapped the fan relay with the A/C relay, but the light persists. The car runs great, though. Any ideas here?
Thanks,
Steve H.
I've got the exact same problem as mine WAS throwing a P1046 code at the emissions center. I did all you did and am still also getting the Service/Wrench light. I went to two, count em two, Autozones and both tested out with no codes, passed. I can't go through emissions with a light on or they will fail it. More suggestions?
Add to donedds's Reputation
Rate the quality of this post and help donedds reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
donedds is offline   Reply With Quote
Old 02-20-2006, 09:57 PM   #26
Old_Coot
Old_Coot is on a distinguished road
Old_Coot's Avatar
Black electrical tape behind cluster.......................................Did I type that outloud???
Add to Old_Coot's Reputation
Rate the quality of this post and help Old_Coot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old_Coot is offline   Reply With Quote
Old 02-21-2006, 01:28 AM   #27
donedds
donedds's Avatar
1996 SC1
And that fixes a mechanical problem?
The light wasn't on the first 1,000 miles I had it. It then came on a few days from emissions test. Got the light off with some gas treatment put it still threw a P1406 code, so it failed. Even if I had taped the light up then, it would have failed.
I'd rather find out if there is a reason for this before I hide the warning light with tape... but thanks for the thoughtful suggestion...
Old 02-21-2006, 10:01 AM   #28
cheapybob
cheapybob will become famous soon enough
2000 SC1
On mine the light went out on its own. No clue why it was on or why it turned off. The car was getting great gas milage and was running fine, so there was no way I was paying a dealer $50 to tell me there was no problem.
I'd suggest that if the emissions people are so stupid as to fail a car for emissions when the definition of the light is "non-emissions related" problem, then I think old coot's black tape behind is a perfectly valid solution. Anyway, their OBD II code reader won't see an error, either, because its generic, just like mine and the ones at Autozone.
just my humble guess/opinion...
Add to cheapybob's Reputation
Rate the quality of this post and help cheapybob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cheapybob is offline   Reply With Quote
Old 02-21-2006, 11:47 AM   #29
wolfman
wolfman's Avatar
(FYI- longish post)
They found the following codes: P0341, P1650, P1651, and the service guy said that the codes were there because my SES light wasn't working. ... probably just a bad bulb
Umm... don't you know exactly what is wrong now? So just go buy and replace the 89 cent light bulb already!
Add to wolfman's Reputation
Old 02-21-2006, 11:55 AM   #30
wolfman
wolfman's Avatar
DTC P1406 EGR Valve Pintle Position Circuit
How about you just FIX the EGR valve instead? It'll take a lot less effort than pulling apart the cluster to tape over the light....
Old 02-21-2006, 11:34 PM   #31
donedds
donedds's Avatar
1996 SC1
I cleaned the EGR valve per the instructions on this website. I did pass emissions today... no codes... though the list still remains on. I'm leaving the battery cable off tonight. I'll see if that fixes anything.
Thanks!
Old 02-22-2006, 01:44 AM   #32
donedds
donedds's Avatar
1996 SC1
Thanks!
(typo on "list") Actually meant the light still stays on... but I put black electrical tape over my left eyeglass lense and it is helping me not see the light.....
Service/wrench Light need help! 3500srw S-Series Tech 16 06-29-2016 12:55 PM
service light and wrench? Rivernut Vue Tech 37 11-19-2008 09:42 PM
Service light (wrench) and poor dealer service Speedy L-Series General 15 04-19-2005 03:00 PM
Service (Wrench) Light marcusa S-Series Tech 0 03-16-2005 08:26 PM
Service Light with Wrench oh no! MadAdam S-Series General 4 03-09-2005 01:00 PM
