Old 01-04-2006, 06:42 PM   #1
kitar77
kitar77 is on a distinguished road
Wrench Remote Start for 2005 Saturn Vue
Wow, this forum is freakin awesome!
I'm in the hopes that someone can answer one question for me.
I recently installed a designtech remote start in my 99 Mitsubishi Montero Sport and 2005 Saturn Vue and everything works great. Headlights, doorlocks,
Great start up and everything! All connections were tested and soldered and there are no security or service icons lit up on the dash. Again, everything works.
However, every once and a while the saturn Vue won't shut off with the key after it has been started with the remote. I'm pretty sure that is will shut off if I use the keyto start it, just not if I use the remote.
I used their universal bypass module 29402, measured and tuned in the resistance fine.
The remote start model is Ready Remote 23927
Add to kitar77's Reputation
Rate the quality of this post and help kitar77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kitar77 is offline   Reply With Quote
Old 01-04-2006, 09:55 PM   #2
IMkenNY
IMkenNY is on a distinguished road
Default Re: Remote Start for 2005 Saturn Vue
It sounds like a faulty designtech (ignition control relay arcing closed perhaps)
By any chance will it shut off with the brake pedal applied after its still running with the key removed?
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
Old 01-04-2006, 11:54 PM   #3
wolfman
wolfman's Avatar
I believe the 23927 has an optional "Turbo Timer" Check the user/installer manual under "OPTIONS PROGRAMMING". If the Turbo Timer is set, that may be what is keeping the car running after the key is turned off under certain conditions. (What it is actually supposed to do)
Add to wolfman's Reputation
Old 01-05-2006, 03:43 PM   #4
kitar77
Thanks for the super fast response! The vue will shut off when the break is pressed. So you think it could be a faulty unit!
Old 01-05-2006, 03:51 PM   #5
IMkenNY
If the brake shuts it down the wiring is good! Sounds like the Designtech is the culprit as long as that turbo timer feature isnt programmed and your not accidently hitting the remote start button when turning off the ignition switch.
Old 01-05-2006, 04:00 PM   #6
kitar77
There is no turbo time feature. I checked the manual. I'm waiting on the phone now with the company. Hopefully it won't take an hour like last time. thanks again for the info!
Old 01-05-2006, 09:21 PM   #7
wolfman
wolfman's Avatar
Nice thing about Design tech, is the LIFETIME WARRANTY.
2008 Vue OEM Remote Start Range Extender robs810 2008 Vue 8 12-15-2009 10:07 PM
Saturn Aura Remote Start dgaugler Community Center 0 11-24-2008 07:22 AM
2005 Vue - remote start updates? buxton Vue General 0 12-17-2007 07:20 PM
Remote Start issues with 2004 AWD V6 Vue My 1st Ute Vue Tech 11 03-03-2005 10:46 PM
2004 Vue alarm w/remote start KJB Vue General 9 07-29-2004 06:36 AM
