Old 12-21-2005, 02:06 AM   #1
So.CalifsJnRe24
So.CalifsJnRe24 is on a distinguished road
So.CalifsJnRe24's Avatar
1993 SC2
Default Normal Engine Temp Gauge??????
Is it normal for my temp gauge to read 3/4 while driving at high speeds on fwy? I have replaced and tried it all. Everything is functioning properly. Is it a minor problem I am overlooking?
[/url][/CENTER][/IMG]
Add to So.CalifsJnRe24's Reputation
Rate the quality of this post and help So.CalifsJnRe24 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
So.CalifsJnRe24 is offline   Reply With Quote
Old 12-21-2005, 02:24 AM   #2
stanleyr
stanleyr is on a distinguished road
stanleyr's Avatar
1992 SL2
2003 ION-3 Sedan
Default Re: Normal Engine Temp Gauge??????
Originally Posted by So.CalifsJnRe24
...Is it normal
Normal for your car? Could be. Typical? Definitely not!
What year SL is this? List what you've "replaced and tried."
Add to stanleyr's Reputation
Rate the quality of this post and help stanleyr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stanleyr is offline   Reply With Quote
Old 12-21-2005, 02:45 AM   #3
stanleyr
stanleyr's Avatar
1992 SL2
2003 ION-3 Sedan
Gotta go now. If you want to check your gauge, find the connector to your coolant temp sensor and unplug it. Place a 220 ohm resistor across the connector and key on your ignition. The gauge should indicate near the 1/2 mark.
Old 12-21-2005, 11:59 AM   #4
willfxp
willfxp is on a distinguished road
1997 SW2
Maybe your engine is overheating?
1997 Saturn SW2
Add to willfxp's Reputation
Rate the quality of this post and help willfxp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
willfxp is offline   Reply With Quote
Old 12-22-2005, 08:07 AM   #5
Saturn-Eh!
Saturn-Eh!'s Avatar
3/4 on the highway is definitely not normal for a Saturn, under any circumstances...
Things to check:
1) is the lower air delfector in place? If not, then the rad will not get enough air at highway speeds, and will run hot.
2) are you low on coolant? what is the condition? check that the coolant is at the proper level
3) condition of the Rad? The factory aluminum rad is quite robust, but can leak from the side tanks. If it has been replaced with an aftermarket copper unit, check so see if you have any rotten cooling fins.
4) Check the Thermostat. If all of the above checks out, you may need a new t-stat. These are not easy to check in the car, you should just replace it to be on the safe side
5) COoolant temp sensor (ECTS) they can crack and give bad readings, but usually cause the car to run rich and register low when they fail (opposite of your condition). However, depending on the year of your car, you should replace it no matter what, as early sensors almost all fail, and they are relatively cheap and easy to replace.
Good luck
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline   Reply With Quote
2003 Vue Engine Temp Gauge flatline n8wudz Vue Tech 3 09-17-2009 03:30 PM
Temp gauge "normal" zone? MikeNW S-Series Tech 9 04-17-2008 04:47 PM
Engine Temp Gauge Doesn't Work-Update ExMiata S-Series General 4 01-27-2008 10:04 PM
Engine Temp Gauge Doesn't Work ExMiata S-Series General 20 01-27-2008 05:26 PM
Engine Cooling Fan and Temp Gauge Mike H S-Series General 1 03-18-2004 12:45 PM
