Old 11-21-2005, 12:06 AM   #1
My Range
My Range is on a distinguished road
Question 94 SL2, hazards disable turn signals
I have a 94 SL2, the turn signals work perfectly,
But when I try to use the hazard lights, they do not work,
and it disables the turn signals, until I restart the car.
I just replaced the flasher relay, but it didn't fix the problem,
Also are there 2 or 3 signals per side.
Thanks for the help.
P.S. I love my saturn, 243,000 Miles and still running fine.
Add to My Range's Reputation
Rate the quality of this post and help My Range reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
My Range is offline   Reply With Quote
Old 11-21-2005, 09:53 AM   #2
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
Default Re: 94 SL2, hazards disable turn signals
The hazard switch just blinks all of the turn signals, so of course they won't work when both turned on at the same time. My guess is a short (or lack on contact) in the hazard switch or wiring.
Toyota: Moving Forward... off a cliff at a high rate of speed.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline   Reply With Quote
Old 11-21-2005, 10:19 AM   #3
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
I am thinking the same. Take off the cover for the stering column and take a look in there, see if there are any wires shorting out to either another wire, or some kinda ground. repair any wire that is cut. Other then that, make sure the FUSE in the fusebox (lower passenger side center consol) is not burnt out, because i bleive they run on a seperate circuit.
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
Add to JS593's Reputation
Rate the quality of this post and help JS593 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JS593 is offline   Reply With Quote
Old 11-21-2005, 06:53 PM   #4
My Range
Thanks, all the fuses are good,
I will try opening the column this weekend. it must be a short.
I love my Saturn,
Still going strong, after, 240k Miles, Hit to left rear side, 2 new alts, new H20 pump,
and after 2 years sitting, started up like a champ, still the most reliable car I ever had.
98 sl2 - turn signals not working / hazards working normal Jetfixer10 S-Series Tech 14 10-31-2016 04:10 PM
Turn signals not working. Hazards work cwills2 L-Series Tech 17 03-20-2016 08:37 PM
sc turn signals and hazards wont work faf112 S-Series Tech 4 03-20-2016 07:07 PM
Turn signals don't work, hazards do a7x_audiojunkie S-Series Tech 2 06-03-2009 05:03 PM
turn signals and hazards just stopped working renadena S-Series General 6 05-14-2005 04:14 PM
