Old 06-07-2006, 02:28 AM   #21
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Default Re: "S" Series automatic transaxle fluid/filter change
Originally Posted by wolfman
I no longer work for Saturn, so I gain nothing by recommending OEM parts.
Whats up with that?
That being said, understand that if I recommend a particular item such as the transaxle filter be obtained from a Saturn dealer, there IS a reason.
Cant agree more. Have seen a few trans problems solved by changing fluid and using stock trans filter over aftermarket..... reason maybe?
Add to Bigdaddy94sc2's Reputation
Rate the quality of this post and help Bigdaddy94sc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-07-2006, 02:31 AM   #22
Bigdaddy94sc2
2006 ION-2 Sedan
Originally Posted by madpogue
Now let's do the math with the autotranny and Mobil 1 ATF.
So Mobil 1 is $6/qt. How much is conventional, maybe $2/qt? So, a difference of $4/qt, times 7 qts, is $28. Over a 30,000 use interval, that's about $0.001 per mile. A tenth of a penny. Maybe a nickel a day, perhaps a dime if you drive a LOT. The food energy to fire the brain cells to think about this is worth more.
With that logic, you could change the trans fluid and filter every 12-15k instead with regular dex, will still be clean, and serve the same purpose.... Regular Dex3 is fine, when changed regularly.... If you are going to change it every 30k or so, Mobil1 ATF wont make that big of a difference to justify the expense..... now if you want to stretch it to 60k or so, then feel free. Mobil1 atf is good stuff, dont get me wrong. Just isnt needed in a saturn trans if changing it regularly.
Old 06-08-2006, 03:41 AM   #23
wolfman
wolfman's Avatar
This is perhaps so...but tis Dextron 3 even changed at the 30K intervals that nets more than a few folks sticky valvebody actuators and the dreaded reverse slam...that can loosen the input shaft nut etc.. etc..
Its Mobil 1 ATF and at 30k changes, factory filters.... and still trouble free at 110k+ for me.
Add to wolfman's Reputation
Old 06-08-2006, 10:29 PM   #24
Not to mention the added expense of twice as many trans filters, and the time to do the procedure.
Add to madpogue's Reputation
Old 08-19-2006, 08:43 PM   #25
bgates2b
bgates2b is on a distinguished road
bgates2b's Avatar
2007 AURA XR
Wolfman, I've used aftermarket Fram tranny filters (bows head in shame) on my car since the OEM filter said "Made by Fram" I no longer have that magnet. If I order an OEM filter, does it come with a new magnet? Do I still need one?
"Congratulations on your brand new 2007 Acura" - Tenisha, the On*Star rep that handled my call during the Aura's delivery
Add to bgates2b's Reputation
Rate the quality of this post and help bgates2b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bgates2b is offline   Reply With Quote
Old 08-31-2006, 09:57 PM   #26
Norseman
Norseman is on a distinguished road
I want to know also.
I had my trans serviced and a non-Saturn filter was used. I won't know if the magnet is there until I go change the fluid. I have a new OEM filter and it does not include a magnet. Can you get the magnet from the dealer?
Add to Norseman's Reputation
Rate the quality of this post and help Norseman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Norseman is offline   Reply With Quote
Old 09-01-2006, 07:34 AM   #27
wolfman
wolfman's Avatar
Yes, (maybe?) but after the initial fluid change at 30k miles, the magnet is more extra insurance than necessary. You can accomplish essentially the same thing with one of those readily available external "oil filter magnets" if you so desire.
Old 09-06-2006, 06:39 PM   #28
CND_SC1
CND_SC1 is on a distinguished road
CND_SC1's Avatar
1994 SC1
I'm buying an ATF filter tomorrow. I'm going to stop by a Saturn dealer first, does anyone know wha the part number on the box should be so I can know for sure that I'm getting the good, original OEM filter and nor something cheaper that Saturn may have switched to in Canada?
Add to CND_SC1's Reputation
Rate the quality of this post and help CND_SC1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CND_SC1 is offline   Reply With Quote
Old 09-09-2006, 02:45 PM   #29
hockeygoalie29
hockeygoalie29 is on a distinguished road
First off, great how-to Wolfman!
The question I have is about a do-it-yourself flush of the fluid. From what I have read, removing the cooling line to allow the old fluid to drain while adding new fluid in equal amounts should flush out the remaining old fluid left during a regular drain. I'm about to swap the fluid on my wife's SL1 which has about 115,000 miles on it and I don't believe it's ever been changed so I figured that a complete change is in order.
Any advice or warnings would be appreciated!
Add to hockeygoalie29's Reputation
Rate the quality of this post and help hockeygoalie29 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hockeygoalie29 is offline   Reply With Quote
Old 09-09-2006, 06:39 PM   #30
wolfman
wolfman's Avatar
The "S" series has an external spin on filter and drains from the differential sump. NO FLUSH IS NEEDED. I highly recommend AGAINST flushing an MP6/MP7 TAAT autotransaxle.
Old 09-09-2006, 07:49 PM   #31
hockeygoalie29
Wow, that makes it so much easier...and a lot less messy. I noticed that this afternoon as I was crawling underneath to take a look and didn't see a pan like I expected. Instead, it simply drains. Gotta love it. Thanks again!
Old 01-29-2007, 10:29 AM   #32
SHARPMACHINE
SHARPMACHINE is on a distinguished road
Not just a bump to the top.
I just bought a 96 sl2 with 75,000 miles on it. The trans fluid was changed 1000 miles and 1.5 years ago (not many miles the last few years on this car). My question is how long will the fluid be good, maybee put another 10,000 miles on the oil, then change it to be safe?
thanks
Add to SHARPMACHINE's Reputation
Rate the quality of this post and help SHARPMACHINE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SHARPMACHINE is offline   Reply With Quote
Old 02-11-2007, 10:09 AM   #33
myolbug
myolbug will become famous soon enough
myolbug's Avatar
98 SC2: For the past 3 filter changes, and one drain/refill, I have used Wix tranny filters, but I don't think I have used that great of fluid. It shifts great, no problems whatsoever, and the fluid is so clean, it is hard to read on the dipstick. The only problem I have is that when you put it in park/neutral, after a few seconds, you can feel the tranny "release" a bit. And, the other day, when I was in park, it felt like the car was trying to move forward, and relaese, then move forward and release when it was in park, after having driven for a short while, albeit subtley.
Recommendations? I can get a Saturn filter, but I no nothing about this magnet. I can get one of those filter magnets, from whom?
If it is OK to disarm law abiding citizens to reduce crime, then it stands to reason to disarm the military to prevent war!
Add to myolbug's Reputation
Rate the quality of this post and help myolbug reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
myolbug is offline   Reply With Quote
Old 02-11-2007, 12:06 PM   #34
Uzzy
Uzzy's Avatar
2002 SC1
The magnet isn't really required after the first filter change, but some do keep it in there. The reason for the OE filter over aftermarket, I believe has to do with flow, and how the filter openings line-up with the tranny passages.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 06-19-2007, 07:50 AM   #35
CND_SC1
CND_SC1's Avatar
1994 SC1
Originally Posted by bgates2b View Post
...I've used aftermarket Fram tranny filters (bows head in shame) on my car since the OEM filter said "Made by Fram" ...?
98 SC2: ...
For future reference, the filter I bought from a Saturn dealership here in Canada was a FilTech brand, part #21003361 ($18.10 CND). It didn't come with a magnet and as Woolfman already posted, you don't really need it anymore.
Old 07-05-2007, 11:07 PM   #36
daoyee
daoyee is on a distinguished road
Originally Posted by oogy View Post
Suggestions on reading the dipstick?
Maybe I'm a fool but I seriously cannot tell where the level is on the dipstick.
I too am curious of this. I was checking my fluid this evening. I could not even tell where the line was. The fluid on the rag was light red. But seemed translucent on the dip stick.
124,400 Miles
Add to daoyee's Reputation
Rate the quality of this post and help daoyee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daoyee is offline   Reply With Quote
Old 10-02-2007, 11:00 AM   #37
SW2Fiddler
SW2Fiddler is on a distinguished road
SW2Fiddler's Avatar
1999 SW2
2005 RELAY-2
Idea 2.5 Gallon Drain Pan, Free, plus spigot
I've been preparing to change the fluid (and run the Wolfman Reverse Slam Cure) and have been watching for an appropriate catch pan. Want one that's easy to pour from, into the empty bottles...
My wife wants me to do something with these empty big rectangular Spring Water bottles. One was repurposed to hold dirty fry oil. Another two had the back ends removed which became nice little marinating trays.
I will slice off the top of another 2 1/2 gallon bottle and drain my ATF into it. The spigot should make the filling of empties practically painless.
If it turns out to not be a big enough opening, I will report back right here...
@=(=I-)
Add to SW2Fiddler's Reputation
Rate the quality of this post and help SW2Fiddler reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SW2Fiddler is offline   Reply With Quote
Old 10-08-2007, 07:46 AM   #38
Commando44
Commando44 is on a distinguished road
Commando44's Avatar
2001 SL2
1994 SL1
7 quarts of clean ATF (Mobil 1 synthetic ATF HIGHLY recommended)
Replacement transaxle filter (Buy it from SATURN, not the autoparts store)
If I use a replacement filter from the autopart store, what happens? Can jiffy-lube change my oil? I don't have the time to do it myself.
'94 SL 1
Add to Commando44's Reputation
Rate the quality of this post and help Commando44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Commando44 is offline   Reply With Quote
Old 10-08-2007, 07:04 PM   #39
It'll take less time to change your own oil than it will to contact the BBB, your state's Attorney General's office, your attorney, etc. etc. after they fail to tighten your drain plug, put the wrong product in, fail to do a service for which they charge you, overtighten something, or any of the other host of things for which they're notorious for doing. I wouldn't trust them to change my Christmas tree air freshener.
Old 11-05-2007, 02:48 AM   #40
CND_SC1
CND_SC1's Avatar
1994 SC1
'94 SL 1
Don't go to any corporate chain or franchise type place. They have fixed prices they have to charge for an ATF service based on dropping the pan or going thorugh the cooler lines and they probably aren't allowed to make exceptions.
Instead, buy the ATF & Filter yourself and find an independent shop that's not to busy and doesn't b#tch about customers being in the garage to oversee the work.
Phone to get their labor charge on an oil change with customer supplied parts. Then go and offer them the job for the same money plus a $5 or $10 tip - it's the same procedure except it takes a few minutes longer to pour the ATF in slowly and be more careful with the filter removal.
If they don't believe you at first (it happens...), open the hood and show them the external spin-on filter.
As you may have seen for yourself, with a SOHC there is no need to do any disassembly - the filter can be reached by hand in between the block and the Air Intake duct without removing anything.
S-Series Automatic Transaxle "Reverse Slam Cure-All" plastic torpedo How-To Library 200 03-17-2017 08:57 AM
Plastic Torpedo's S-Series Automatic Transaxle "Reverse Slam Cure-All" Question sdasilva S-Series General 7 08-28-2016 04:34 PM
Automatic Transaxle Fluid & Filter Change TXSaturn02 S-Series General 11 04-04-2007 03:31 PM
Excellent "S" series engine/transaxle pictures wolfman S-Series Tech 4 08-20-2005 03:30 PM
Best "S" Series Engine and Transaxle Pictures wolfman How-To Library 0 08-20-2005 05:04 AM
