Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 11-11-2005, 10:41 PM   #1
THX712517
THX712517 is on a distinguished road
THX712517's Avatar
Default Bore/stroke question
Alright, I've got the 2.2 Ecotec, I'm envious of displacement, I was thinking I would get the pistons, connecting rods, and crankshaft from a 2.4, bore the 2.2 out, and swap the parts. Only problem is, that's gonna be wicked expensive. When I ran the parts numbers, we're talking well into the four digit range. So my new question, is it worth it to bore the engine from 86 to 88 millimeters? It's a bump in displacement from 2.2 to 2.3, to be sure, and less expensive...
Before you even say anything, I don't want to hear about supercharging, turbocharging, or nitrous oxide. I am asking this question ONLY about being able to justify an increase in bore from 86mm to 88mm, increasing displacement from 2.2 to 2.3 liters.
2003 Saturn Ion
2001 Mazda Miata
1997 Saturn SC1
Add to THX712517's Reputation
Rate the quality of this post and help THX712517 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
THX712517 is offline
Old 11-11-2005, 11:12 PM   #2
twosaturns
twosaturns's Avatar
Default Re: Bore/stroke question
have you got that ecotec performance book? I haven't seen it, but if all I hear is true, it will tell you ALL you need to know about your mill. and maybe posting on an ecotec forum will get you better answers. you've been here long enough to know that most people here are just into the LLO.
from previous experience w/ other engines, I don't think that your slight bore increase will do much. you're still looking at a big expense (new pistons) and all that work.you'd have to stroke it and raise the comp as well, and now you have computer/emissions issues.
Add to twosaturns's Reputation
Rate the quality of this post and help twosaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twosaturns is offline
Old 11-12-2005, 12:05 AM   #3
Tycho
Tycho is on a distinguished road
Tycho's Avatar
In general, usually stroking has greater benefits than boring given the same increase in displacement. It does make your rod ratio worse however.
Disadvantages of boring include: weaker sleeves, less gasket mating area, increased probability of knock (longer distance for the flame front to travel).
Disadvantages of stroking include: less favorable rod ratio, higher piston acceleration.
If you really want to look into the plusses and minuses of each I'd suggest looking at the work Intrinsic Performance Solutions has done with the Honda K series:
http://www.intrinsicperformance.com/
http://www.k20a.org/
Engines don't know "what" they are (be it Ecotec, 1.9, or K series) so restricting yourself to the "expert" opinions on ecotec would probably be short sighted. IPS has built K motors from 2.0 L all the way up to 2.65 (with variants in the 2.1, 2.2, 2.3, 2.4, and 2.6 L range) with similar heads and manifolding. They've posted a number of dynos and comments on reliability and longevity as well (I think they've gotten near every combination over 300 HP...obviously with very different characteristic torque curves). I'm sure much of it would translate over to your application.
Forced induction is rape.
Add to Tycho's Reputation
Rate the quality of this post and help Tycho reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tycho is offline
Old 11-12-2005, 12:19 AM   #4
THX712517
THX712517's Avatar
Cool, thanks for the info.
2003 Saturn Ion
2001 Mazda Miata
1997 Saturn SC1
Higher MPG with 2-stroke oil?? mjo S-Series Mods 48 03-11-2006 10:54 AM
Bore or stroke orbits3 Ion General 6 02-26-2006 02:25 PM
bore,stroke,Compression Ratio....... sc2dave S-Series Tech 5 02-28-2005 11:53 PM
SaturnFans having a stroke? silverblueL200 Community Center 16 11-09-2004 09:10 AM
Stroke up THX712517 Mods and Performance 3 11-15-2003 09:34 PM
