Old 11-09-2005, 06:15 PM   #1
saturn2wagon
saturn2wagon is on a distinguished road
1998 SW2
Default temp gauge not working in sw1
Hello everyone Iam new here but not new to Saturns, In the past I have owned a 94 SL1, 98 SL1, and a 99 SC2 3DC. I currently own a 98 SW2 (which is my current project) a 95 SC1 and i just bought my wife a 95 SL1.
Now for my problem The guy i just bought my 95 SL1 from blew up the original engine and had the engine and trans. from a 01 SL1 installed. Well ive noticed that the temp gauge doesn't work in it, after a little investication i found out that the coolant temp sending unit (not the ECTS) is unplugged. simple fix right? WRONG the 01 motor doesnt have a temp sending unit (at least its not in the same place as the 95's is). I called the local Saturn dealership and they told me i would have to change the head to the older style, but im not going to do that to a motor that only has 25,000 miles on it just for a gauge. Im puting all aftermarket gauges in my SW2 and i know that that is an option in this car too, but is it my ONLY option?? i hope not i really dont want to do that. Any help would be greatlly appreciated. And if this is already in another thread i'm sorry I did a search to no avail.
Add to saturn2wagon's Reputation
Rate the quality of this post and help saturn2wagon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn2wagon is offline   Reply With Quote
Old 11-09-2005, 06:50 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: temp gauge not working in sw1
Drill a hole and tap it where the gauge sender would have gone on your 95. There'll be pics in someone's gallery of an earlier SOHC. If all else fails JB weld the sender to something warm.
The 00- and-older motors are better, stronger blocks, less oil burning, so don't get rid of any of that over any silly gauge.
Add to eljefino's Reputation
Old 11-09-2005, 07:45 PM   #3
dansl2
dansl2 is on a distinguished road
dansl2's Avatar
2000 SL2
It may be possible to tap into the ECTS wiring to send a signal to the gauge? Not sure on that, just an idea.
Check this thread:
http://www.saturnfans.com/forums/showthread.php?t=64415
Experience is something you don't get until just after you need it.
Add to dansl2's Reputation
Rate the quality of this post and help dansl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dansl2 is offline   Reply With Quote
Old 11-10-2005, 08:55 AM   #4
BarnOwl
BarnOwl's Avatar
Seen a few "fixes" suggested for this all involve putting a tee somewhere and putting the sensor there. I believe it's 1/4" pipe threads. Locations suggested:
heater hose
the elbow where the coolant goes into the manifold
where the sensor is now
I haven't done any of the above, but I have seen some posts about it.
Add to BarnOwl's Reputation
Old 11-10-2005, 02:55 PM   #5
saturn2wagon
1998 SW2
i guess im just gonna put a tee in the head where the ects is and stick them both there thank you everyone for your help!!
Old 11-10-2005, 03:04 PM   #6
eljefino
eljefino's Avatar
1995 SW1
I would worry about anything that gets the ECTS out of the direct flow of water.
If the Tee sticks out, cool antifreeze might linger around the ECTS as the car warms up.
This will have a subtle effect on your economy.
If there is a compromise made, it should only effect the gauge.
Old 11-10-2005, 08:56 PM   #7
dansl2
dansl2's Avatar
2000 SL2
Thats why I was wondering about splicing into the wiring instead of putting a T there.....is that even feasible, or would it draw off too much signal to the cpu?
Old 11-11-2005, 12:32 AM   #8
No. Don't so that.
Proper method would be to drillout the flat just underthe rad hose fitting and tap the right threads into the hole for the gauge temp sender.
Tapping into the metal colant line to the surge tank will get you by.
Add to ssicarman's Reputation
air cond. fuel gauge and temp gauge not working. Help?? brielle L-Series General 12 09-14-2016 08:07 PM
'99 SW1 Working Out Just Fine Coaster S-Series General 0 08-22-2009 06:26 AM
'99 SW1 Working Out Well Coaster S-Series Tech 1 08-20-2009 12:03 PM
1996 SW1 engine temp issue BWPerdue S-Series General 3 08-22-2008 03:28 PM
Temp gauge not working bwcistheman1 Miscellaneous Tech 1 04-30-2001 10:31 PM
