Old 11-08-2005, 02:35 PM   #1
sosnpk
sosnpk is on a distinguished road
Default Fixed dragging caliper, ABS light still on, need tool to clear?
So I was finally able to diagnose and fix my dragging driver's side rear caliper on my 93 SL1, replaced the pad mounting bracket and caliper pin sleeves, I think I had mangled the bracket when attempting to break its bolt loose. Now both wheels turn freely but my abs light is still on even after disconnecting the battery.
Is a scan tool required to reset the code or do I probably still have a problem? The abs was fine before I changed the rear brakes. The light comes on after the vehicle is moved.
What is the typical cost I should expect to pay to read the code, I've heard that most auto part stores can't read Saturn abs codes.
Add to sosnpk's Reputation
Rate the quality of this post and help sosnpk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sosnpk is offline   Reply With Quote
Old 11-09-2005, 12:13 PM   #2
JS593
JS593 is on a distinguished road
JS593's Avatar
1992 SL1
Default Re: Fixed dragging caliper, ABS light still on, need tool to clear?
I somewhat had the same issue. try topping off your fluid, make sure the switch for the light (right on the e-brake, take center consol off to see it) is not being touched as well. let me know what happens.
92 SL1 SOHC TBI
Custom intake
Alpine deck, speakers, amp
JBL Sub
Ultimate amp
Volometer gauge mounted in dash
Magnaflow exhaust
....DEAD.... Car towed away Jan 18 2007. RIP
Add to JS593's Reputation
Rate the quality of this post and help JS593 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JS593 is offline   Reply With Quote
Old 11-09-2005, 12:15 PM   #3
eljefino
eljefino's Avatar
1995 SW1
sounds like you screwed up the speed sensor on the wheel(s) you worked on.
Add to eljefino's Reputation
Old 11-09-2005, 02:53 PM   #4
sosnpk
Are the sensors pressed in or can they be removed, can they be cleaned or just need to replace?
I remember checking abs sensors with an ohm meter to determine if they were bad, should I try this procedure?
Old 11-10-2005, 11:38 AM   #5
BarnOwl
BarnOwl's Avatar
If it's a sensor, it's built into the hub and the hub has to be replaced. From my reading on here, it's more common for the wiring to go than the sensor particularly the wiring to the right rear sensor. You can find a break by pulling on the wires and seeing where the insulation stretches.
Add to BarnOwl's Reputation
Tip: Bleeding a Delphi VI ABS System Without A Scan Tool The Critic S-Series Tech 8 10-02-2014 04:42 PM
ABS sensor and check engine light come on at odd times, and how this was fixed. boffin S-Series Tech 1 07-01-2007 03:19 PM
ABS light on constant - ABS not working Frank3 S-Series Tech 8 10-20-2005 09:19 PM
Scan Tool and Rear ABS Calipers Red97sc2 S-Series Tech 4 04-14-2005 10:55 PM
camcover gasket is fixed: maybe this will clear everything up joyrider S-Series Tech 20 04-05-2005 09:36 AM
