Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 11-03-2005, 06:41 PM   #1
cloud819
cloud819 will become famous soon enough
cloud819's Avatar
Default WBO2 questions
Exhaust goes on Monday!!!!!! Yippie!!!!
I have a transmission, flywheel, clutch upgrade after that.
Then this winter I make the electronics dive. MDS Dis-2, Apexi S-AFC 2 and WBO2 senser.
Finally I get the N20.
I'm gunning for 200 on N20 and close to 150 N/A. There are other small mods happening through these larger ones, but they are large changes, mostly handling.
This question has to do with the WBO2 sensor though. Does this sensor replace the one directly behind the cat? Or should I have a seperate bung put on my exhaust this Monday and have it plugged for the upcoming WBO2 upgrade?
Add to cloud819's Reputation
Rate the quality of this post and help cloud819 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cloud819 is offline
Old 11-03-2005, 09:00 PM   #2
getz999
getz999 is on a distinguished road
getz999's Avatar
Default Re: WBO2 questions
people will argue this one out
if you buy a pre heated sensor then most will reccomend that you place the sensor at least 18 inches from the head...
also depending on the year it may also fit in the stock o2 in the header...thats where i placed mine.
Add to getz999's Reputation
Rate the quality of this post and help getz999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
getz999 is offline
Old 11-03-2005, 09:08 PM   #3
93 saturn sl2
93 saturn sl2 is on a distinguished road
1993 SL2
I doubt that you will get 150 N/A...
93 sl2
mp3 swapped
bolt on's
black interior
Add to 93 saturn sl2's Reputation
Rate the quality of this post and help 93 saturn sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93 saturn sl2 is offline
Old 11-03-2005, 09:10 PM   #4
mars_volta
mars_volta is on a distinguished road
mars_volta's Avatar
what are your plans to achieve 150 whp n/a?
2005 Legacy GT LTD
94 SL2
95 SC2
Add to mars_volta's Reputation
Rate the quality of this post and help mars_volta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mars_volta is offline
Old 11-03-2005, 09:34 PM   #5
getz999
getz999's Avatar
yea 150 is kinda high ambitions IMO
140 was achieved by SDA ... but with some SERIOUS work and know how
getz999 is offline
Old 11-03-2005, 09:42 PM   #6
cloud819
cloud819's Avatar
150 crank not wheel.
AEM Cold Air intake
OBX header
2.5 inch Magna flow cat
2.5 inch mandrel bent exhaust
2.5 inch muffler
Apexi S-AFC 2
MSD DIS-2
Lightweight flywheel
And at some point
A shaved head with a P&P job
I'm saying 150 SAE corrected at the crank. This is not that far out. I won't be disappointed if I only hit ~140HP. But I think it could be possible to find the engine at 150. The cold air, exhaust and S-AFC 2 will probably net me an Ok amount of HP on the high end; I'm expecting around 12 total, but who knows. The flywheel should free some power. The MSD probably won't do too much. I had a 6AL on a very modified engine once and enjoyed the slightly smoother idle it gave me. Shaving the head to up the compression and a P&P job will certainly get me into the 150 range.
Considering the setup will closely match the old 21HP package sold by SPS I think I should be playing in that league. That would be awfully close to my target of 150.
I know to get to 200 I have to use a power adder of some sort. But 150 is not out of the question for N/A on a stock bottom end.
cloud819 is offline
Old 11-04-2005, 06:42 AM   #7
Bigbadbert
Bigbadbert is on a distinguished road
Bigbadbert's Avatar
Add in a decent set of cams and you might just hit 150 crank with that setup. The Safc II will definitely add a nice seat of the pants feeling alone. Also, what year is your car? If you have a 3rd gen, opening up the exhaust ports on the head will free some power for sure. Those stupid things are about the size of my pinky, if that.
'01 SC2 - sold
Add to Bigbadbert's Reputation
Rate the quality of this post and help Bigbadbert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bigbadbert is offline
Old 11-04-2005, 10:52 AM   #8
cloud819
cloud819's Avatar
Team SCR reached a tic over 150 on their ITA car with stock parts a shaved head, a slightover bore and some cam timing. They were using a stock exhaust manifold and no engine management it apears.
http://www.teamscr.com/power.html
cloud819 is offline
Old 11-04-2005, 04:33 PM   #9
cloud819
cloud819's Avatar
Found info on the SDA car. They got 147HP N/A at the wheels!!!!!; Pre cam tuning. That is amazing. Now they are running a hot cam, head, intake and most likely a built bottom.
But I'm not talking at the wheels, I looking at crank. I knew I wasn't crazy when thinking 150 crank isn't unbeleaveable without doing bottom end work.
cloud819 is offline
Questions Questions MPG 93 SL2 Labradoofis S-Series Tech 3 09-13-2009 12:01 AM
Going to look at a DOHC. questions questions for the swap. RBrown20 S-Series Mods 7 03-16-2009 06:53 AM
WBo2 Fox Slaughter S-Series Mods 25 12-15-2008 08:00 PM
Lc-1 Wbo2 sps SOHC S-Series Mods 4 12-06-2006 10:32 AM
PLXM 300 WBO2 Setup getz999 S-Series Mods 11 10-15-2005 07:36 PM
