Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 11-02-2005, 09:18 AM   #1
enviroko
enviroko is on a distinguished road
Default Flashing battery light not fixed by new battery.
I went for the easy fix by buying a new battery but that didn't do it. Before I go pulling the alternator could a loose wire cause the battery light to flicker on and off? I know this may be an obvious question but I guess I really wondering if this might be a common issue with Saturns.
95 Saturn SL2
141,000 mi
Thanks!
Add to enviroko's Reputation
Rate the quality of this post and help enviroko reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
enviroko is offline   Reply With Quote
Old 11-02-2005, 12:55 PM   #2
RalliArt16
RalliArt16 is on a distinguished road
RalliArt16's Avatar
1996 SC1
Default Re: Flashing battery light not fixed by new battery.
Did you get the battery tested before you bought a new one? Advance auto parts or autozone should test it for free...
You can also get the alternator tested in the vehicle.. once again for free at AAP or autozone.
1996 SC1
Add to RalliArt16's Reputation
Rate the quality of this post and help RalliArt16 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RalliArt16 is offline   Reply With Quote
Old 11-02-2005, 01:16 PM   #3
amazinghl
If the alternator is orignal, change it.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 11-02-2005, 02:54 PM   #4
96GSL1
96GSL1 is on a distinguished road
96GSL1's Avatar
1996 SL1
I'm with amazinghl. A loose wire could do it, but with that milage; I would not doubt if your alt. **** the bed.
96 SL1 202k
98 Windstar 123k
Add to 96GSL1's Reputation
Rate the quality of this post and help 96GSL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
96GSL1 is offline   Reply With Quote
Old 11-02-2005, 03:39 PM   #5
eljefino
eljefino's Avatar
1995 SW1
Read up on what the "battery" symbol means in your owner's manual.
Hint: It's a battery charging problem.
Yes it could be a loose wire, but at both the alt and battery they screw/bolt on rather securely. My bet is on the alternator itself.
Add to eljefino's Reputation
Old 12-17-2015, 01:05 PM   #6
Under_b
Under_b is on a distinguished road
2001 L-Series 2.2L Wagon
2004 VUE 2.2L
Hey i had the same issues on my 2001 saturn LW200 and its the cable near the alternator the plugs into the Alternator, that is loose, that gives you the light, near the front of the alternator is a wire that you need to check, that its pluged
Saturn LW200 2.2L
Spec-D Intercooler
CXRacing Intercooler Piping
HKS Wastegate
TurboXS BlowoffValve
CXRacing T3/T4 Turbocharger
Forged Crankshaft
Forged Connecting Rods
Forged Pistons
Add to Under_b's Reputation
Rate the quality of this post and help Under_b reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Under_b is offline   Reply With Quote
Possible alternator problem - flashing battery light, 96 SC2 96sc2_green S-Series Tech 10 07-08-2008 02:41 AM
Battery light flashing over 5500 rpms 2003MercMaraude S-Series Tech 12 05-22-2008 10:01 AM
Temp & Battery light Flashing...what does it mean? pasha S-Series Tech 5 01-19-2006 08:42 PM
Intermittent flashing of low battery / temp light enganeer S-Series Tech 7 10-28-2002 01:52 PM
Low battery/Temp light flashing intermittently cron S-Series Tech 4 05-07-2000 08:38 PM
