what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Categories > General Saturn Discussion
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 10-29-2005, 07:59 PM   #1
geepondy
geepondy is on a distinguished road
Default Opinions wanted on two tires discovered at Sam's Club
Was at Sam's club today researching 185/65/14 tires. Discovered two brands in particular that looked promising. One was a BFGoodrich 70000 Pro 85T for $52.04 a tire, $248 for all four installed. The other was a Goodyear Allegra T for $61.12 per or $285.48 installed. Both have 70k tread warranty. Thing is I go to both Goodrich and Goodyear web sites and I don't see either of these tires mentioned. Does anybody have any information opinion of these tires? Are they exclusive to Sam's Club only. As mentioned in another thread, I'm looking for either all season tires that are good in snow or some snow tires exclusively.
Oh one more opinion wanted. At Saturn dealer they wanted to change my two tires and I wouldn't pay their rediculous high price but they said one tire had a nail in it. I was unaware of that and it seems to be holding air fine. Do you think it's safe to drive a month or two more with the nail present?
Add to geepondy's Reputation
Rate the quality of this post and help geepondy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geepondy is offline   Reply With Quote
Old 10-29-2005, 09:17 PM   #2
Citation84
Citation84 will become famous soon enough
Citation84's Avatar
2005 ION-1 Sedan
Default Re: Opinions wanted on two tires discovered at Sam's Club
Get a second opinion on the nail. Get it fixed for your own peace of mind.
Sam's Club, Goodyear and Goodrich may have contracted with an outside supplier for these tires like Kelly Springfield did my Monarch 185/70R 14s on my 95 SL1. Those ran approx. 56-58 apiece installed at 'Just Tires". They are made in Brazil .
You may have better luck getting information on those tires from the Sam's Club site itself. The price is certainly right for 70,000 mile treads.
Add to Citation84's Reputation
Rate the quality of this post and help Citation84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Citation84 is offline   Reply With Quote
Old 10-29-2005, 10:02 PM   #3
futurevue
futurevue is on a distinguished road
2002 SL1
I had a nail in my tire once for about 5 months or so. I would notice the air was low and would just add air. When I took it in for an oil change the Firestone people noticed the nail (it was huge too about 3-4 inches long) and took it out and plugged the hole. I would say as long as your tire isn't going flat that you can keep adding air and wait a while to fix it if necessary. I had to put air in mine about once a month or so, depending on how much I drove. Now I have tires installed from Bell Tire with a lifetime warranty so no more worry about flats or holes.
Add to futurevue's Reputation
Rate the quality of this post and help futurevue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
futurevue is offline   Reply With Quote
Old 10-29-2005, 10:53 PM   #4
flippedgazelle
flippedgazelle is on a distinguished road
2006 ION-3 Sedan
Yup. Check out http://www.goodyeartires.com/faqs/sams_club.html
Add to flippedgazelle's Reputation
Rate the quality of this post and help flippedgazelle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flippedgazelle is offline   Reply With Quote
Old 10-29-2005, 11:53 PM   #5
geepondy
Hey thanks for that info. I wonder if that means there is a drop off in quality with these tires?
Old 10-30-2005, 09:35 AM   #6
Citation84
Citation84's Avatar
2005 ION-1 Sedan
Mine are not the grippiest in the wet, but they are quiet, which is fine with me.The quality differences may only be in the type of tire you want to have: performance, touring, all season. Reading the data on the sidewall helps you figure speed load and temp rating [A, B, C], but I have never been able to decipher it properly. All things being equal between a Sam's tire and a Goodyear, they should perform the same IMHO.
I chose a similar more low noise and ride oriented tire for the Cavalier I had as well, also from Just Tires. A different "brand" but also manufactured by Kelly Springfield.I loved the difference it made in the ride and noise level, but that's me.
They are probably the same quality, they just don't have the overhead that a Goodyear shop or Firestone tire would have to cover. Sort of like a store brand. A lot of stores contract with brand name companies for their own in house products. Same quality [in most instances], just a different label.
Old 10-30-2005, 10:29 AM   #7
eRic 02sc2
eRic 02sc2 will become famous soon enougheRic 02sc2 will become famous soon enough
eRic 02sc2's Avatar
Location: Professional Driver on a Closed Course: Do Not Attempt.
no it's not safe. eventually that nail will be pushed further into the tire or it may pull out of the tire and leave a hole so air will escape and the tire will deflate. get it fixed asap. you can fix it yourself if you want to save a buck. buy a tire repair kit that includes a rope like material and a tool to poke into the tire after you pull out the nail. or find a discount tire co and they'll fix it for free. would you walk around with a nail in your shoe and keep adding blood when it dripped out of your foot? probably not. you'd get the nail removed and get stitches to close the wound.
eRic 02sc2 fka eRic 96sc2
Detroit SCCA Solo 2001,2002 1st DSP
Waterford Hills 2007 Fun Run 1st
Detroit SCCA 2008 Triathalon 1st PF
Detroit SCCA Solo 2009 2nd ST
Old 10-30-2005, 03:18 PM   #8
geepondy
Dang, if there's a nail in there it's hidden well. We finally had a decent day so I was out inspecting the tire and without actually removing it, I can't see any nail and it's not losing any air. I have next Friday off and will stop at a local tire place to have it inspected and repaired if nail can be found. I assume Saturn was telling me the truth but I wasn't present at the shop when this nail was "discovered".
Old 10-30-2005, 05:20 PM   #9
rossao1
rossao1 is on a distinguished road
rossao1's Avatar
2006 ION-3 Sedan
Check all of your tires. Some people don't know their left and right too well. May the tech or the service advisor may have just guessed at the tire afterwards while doing the paper work. At least 50-50 chance when you know front or rear.
Either way replace the tires in at least pairs. Four is better but more costly.
Peace.
A Saturn owner since 10/91.
'92 SC, '91 SL2, 95 SW1, '06 ION3
Add to rossao1's Reputation
Rate the quality of this post and help rossao1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rossao1 is offline   Reply With Quote
Old 11-14-2005, 07:34 PM   #10
PaulGraz
PaulGraz is on a distinguished road
PaulGraz's Avatar
2001 L-Series 2.2L Wagon
We bought a set of 4 Goodyear Allegras from Sams Club for my 01 LW200 - and we're very happy with them. They are clearly stamped "MADE IN USA" and they've been working great - we have no complaints...
Add to PaulGraz's Reputation
Rate the quality of this post and help PaulGraz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PaulGraz is offline   Reply With Quote
Old 11-15-2005, 12:39 AM   #11
marcusa
marcusa is on a distinguished road
marcusa's Avatar
1997 SL1
I'd check the ratings on the Tirerack website and see if it's what you need, can't beat 1000's of opinions. I got a high rated tire from there (Sumitomo) for dirt cheap which I would have not gotten otherwise since it was a lesser-brand. Saved me from spending a fortune on new Michelins like the ones I had, and they turned out to be better tires.
Add to marcusa's Reputation
Rate the quality of this post and help marcusa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marcusa is offline   Reply With Quote
Opinions WANTED!!!! nu2saturn S-Series General 12 03-03-2008 03:59 PM
Opinions wanted: Considering a Saturn Outlook SteelerXR Outlook General 39 02-18-2008 10:54 AM
Brake Inspection - Opinions Wanted TXSaturn02 S-Series Tech 22 07-03-2007 10:21 PM
Opinions wanted on warranty MyVUEofTheWorld Vue General 10 08-24-2006 02:43 PM
Sam's Club won't install car batteries for Saturns Arnel S-Series General 28 06-11-2005 04:58 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
