Old 10-18-2005, 01:42 PM   #1
zallen777
zallen777 is on a distinguished road
zallen777's Avatar
2007 AURA XE
2007 AURA XR
Default Difficult To Put Into First Gear
From a dead stop it is often difficult to put the vehicle into first gear. It often times feels like I have to jam it into gear!
Is this normal? And if not, what should I request that the Techs at my dealer check for?
I have a 2005 Manual Vue with only 7000 miles on it.
Its pretty much done this since purchase I think, and seems to be getting a little worse, although that could just be my perception and not accurate.
Thanks
[url]http://www.zallenmusic.com[/url]
[url]http://zallenart.googlepages.com[/url]
2007 Aura XE
2007 AuraXR
05 Vue 5 spd manual
03 ION 3 Sedan Cranberry
03 ION 2 Sedan Black
99 SC2 Blkberry
95 SC2 Red
Add to zallen777's Reputation
Rate the quality of this post and help zallen777 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
zallen777 is offline   Reply With Quote
Old 10-18-2005, 02:01 PM   #2
fatabbot
fatabbot is on a distinguished road
fatabbot's Avatar
Default Re: Difficult To Put Into First Gear
Try shifting into 2nd then shifting it into 1st gear. Many manuals are hard to get into first from 3-4-5 or 6th gears.
Add to fatabbot's Reputation
Rate the quality of this post and help fatabbot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fatabbot is offline   Reply With Quote
Old 10-18-2005, 02:14 PM   #3
zallen777
zallen777's Avatar
2007 AURA XE
2007 AURA XR
I have sort of tried that, seems to help a little.
What I'm talking about is sitting still with the car in nuetral, which is usually what I do when sitting at a light.
2007 Aura XE
2007 AuraXR
05 Vue 5 spd manual
99 SC2 Blkberry
95 SC2 Red
Old 10-18-2005, 02:18 PM   #4
fatabbot
fatabbot's Avatar
Exactly. While sitting still at the light, do a couple of 2nd to first shifts while stepping on the clutch. The shift into first should be much easier than going from 5th to neutral, then to first.
Old 10-19-2005, 07:24 AM   #5
oldcar1
oldcar1 is on a distinguished road
oldcar1's Avatar
2007 VUE 2.2L
I had the same issue with a 2004 ion and the dealer tech said it was the way I drove the car. I'm sure it was a syncro. My wifes 2004 ion did not do it. I also had trouble downshifting from 3rd to second. We traded both in for 2005 vue's and have no trouble with the trannys. BTW the ion did the shifting problem from delivery. Ofcourse the dealer could not duplicate the problem.
Add to oldcar1's Reputation
Rate the quality of this post and help oldcar1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oldcar1 is offline   Reply With Quote
Old 10-19-2005, 07:46 AM   #6
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
I had the exact same problem with my 2004 VUE. Took it in and they replaced the shifter cables. Problem went away for awhile but now it's starting to return.
It's under warranty, take it in. Talk nice to the service writer and get a loaner car and go beat on that.
--Tom
Not a Saturn.
Add to Tom92SCm's Reputation
Old 10-21-2005, 12:44 PM   #7
saturnjoe
saturnjoe is on a distinguished road
I had the same problem with my 2005 Vue. It was especially bad during the winter. After about 15,000 miles it loosened up and became what I would consider normal for a cable shifter.
Add to saturnjoe's Reputation
Rate the quality of this post and help saturnjoe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnjoe is offline   Reply With Quote
5-speed difficult to get into first gear higleyjp S-Series General 16 04-06-2009 08:31 PM
Couldn't put manual in gear this morning. mgordon1100 S-Series General 8 03-01-2009 09:39 PM
Hard to put in gear sensehumor S-Series Tech 4 02-11-2008 10:14 AM
hard to put in gear americanbulldog S-Series General 5 06-18-2006 02:05 PM
Very bad bogging when put in gear???.. Chris93SL2 S-Series Tech 10 03-27-2003 04:35 AM
