Old 10-17-2005, 09:23 PM   #1
Ryan L300
Ryan L300 is on a distinguished road
Default Clicking Noise After Engine Start
Recently, I've noticed random clicking noises after starting the engine on my '03 V6 L300. The noise is located somewhere around the steering column and almost sounds like an electrical relay. After a couple minutes, the noise goes away until the next time I start the engine. I also noticed that the noise is more prevalent in the morning when it's cold.
Somehow, I don't feel this is a serious problem, but I would like to figure out what it is. Any ideas? Thanks in advance.
Add to Ryan L300's Reputation
Rate the quality of this post and help Ryan L300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ryan L300 is offline   Reply With Quote
Old 10-18-2005, 05:50 AM   #2
2001L300
2001L300 is on a distinguished road
2001L300's Avatar
2001 L-Series 3.0L Sedan
Default Re: Clicking Noise After Engine Start
Could it be the ABS system doing it's self check?
2001 L300
Add to 2001L300's Reputation
Rate the quality of this post and help 2001L300 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2001L300 is offline   Reply With Quote
Old 10-18-2005, 07:54 PM   #3
Ryan L300
You make a good point. However, this is something I have never heard before. Furthermore, the clicking noises continue even after I have been driving for a minute or two.
Old 10-18-2005, 10:33 PM   #4
Are you sure the noise is from inside the car? Checked for TSB's for clicking and found nothing but I did find this.
Tick Noise From Engine
2001-2005 Saturn L-Series
with 3.0 Engine (RPO L81)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s).
Condition/Concern:
Technicians may find a noise from the lifter area that may be intermittent. Lifter noise may be caused by one of two areas. Air may become trapped in the lifter which can be purged during engine operation. Operating the engine at higher engine RPM for roughly 10 minutes may help remove the air from the lifter. The second area may be debris inside the lifter which can become stuck in the ball seats within the lifter or between the piston and outer sleeve within the lifter resulting in the lifter being noisy from excess lash in the valve train.
Add to ssicarman's Reputation
Old 10-19-2005, 08:41 AM   #5
s3nfo
s3nfo has a spectacular aura abouts3nfo has a spectacular aura abouts3nfo has a spectacular aura about
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Lifter going bad with a leak would allow the pressure to bleed off everytime the engine was shut off and would show these symptoms. Everytime the car was shut off, and enough time had elapsed to bleed pressure in the lifter.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 11-06-2005, 06:13 PM   #6
Ryan L300
It is not the "engine ticking noise" that's being talked about. That is a more serious issue. The noise I'm getting is actually inside the cabin behind the panel where the steering column is located.
I can replicate the clicking noise by pushing the "thumb button" on the shifter while pressing my foot down on the brake. The problem is that, even after I shift out of park, that same clicking noise continues uncontrollably.
Could it be that this shifter/brake mechanism is going bad?
Old 11-06-2005, 06:18 PM   #7
tackepj
tackepj will become famous soon enough
tackepj's Avatar
2008 Astra XE
Sure sounds like the brake/shift interlock...maybe just a loose connection.
Add to tackepj's Reputation
Rate the quality of this post and help tackepj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tackepj is offline   Reply With Quote
Old 11-07-2005, 12:48 AM   #8
hugh
hugh will become famous soon enough
Tackepj;
Off the topic......is that an Ercoupe 415C I see?
Add to hugh's Reputation
Rate the quality of this post and help hugh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hugh is offline   Reply With Quote
engine noise at start up bills01 Astra Tech 10 07-26-2013 03:21 PM
LOUD clicking noise from engine HFHEARD S-Series Tech 2 12-16-2008 08:50 PM
Loud Clicking Noise Coming from the engine of my 1999 Saturn SW2 Wagon courtneyscottus S-Series Tech 5 08-05-2007 01:11 PM
no start, clicking noise, security light on maroman84 S-Series General 7 12-23-2005 11:15 AM
clicking noise when engine runs shortyjacobs S-Series General 4 01-13-2005 12:02 PM
