#1 | ||||
![]() Join Date: Aug 2005
hi to all, glad to find this forum.
i have a 93 sl2 saturn, with no a/c. checked the relay to the clutch,it comes on ok. checked the a/c hi pressure switch with an ohmmeter looks like the switch is open. the wire to the switch reads 12v when the a/c on the dash is pushed. do i need to replace the switch? if so how is it done without the freon leaking out the switch? thanks, hobbs
#2 | ||||
Have you checked to make sure that you have enough of a charge in the system to run the AC? The switches in the AC lines have valves in them so that when the switch is removed the refrigerant does not come out.
... A lousy day in paradise is still a day in paradise.
| Thread Tools | |
| Display Modes | |
| a/c pressure switch bypass | paulbol | L-Series Tech | 3 | 06-15-2009 11:53 AM |
| Oil Pressure Switch | SLAPSHOT | Vue General | 3 | 01-10-2009 08:18 AM |
| 98 SW2 A/C pressure switch | Donny | L-Series General | 2 | 03-10-2008 01:15 AM |
| Bad A/C pressure switch? | strongboy2005 | S-Series Tech | 9 | 02-22-2007 04:27 PM |
| Oil Pressure Switch | Steve96SL2m | S-Series General | 2 | 09-03-2003 10:23 PM |
